9 Replies Latest reply on Aug 24, 2016 11:25 PM by Brucgovn
    Adobe Photoshop CS6 OS X El Capitan
    ISAIAS
      Hello,
      I like to know if Photoshop CS6, Illustrator CS6, After Effects CS6, Audition CS6, Encore CS6 and InDesign CS6 are compatible with OS X El Capitan.
      I need the response please for update my OS X.
      Thanks again.
        • 1. Re: Adobe Photoshop CS6 OS X El Capitan
          Bob deWitt Level 1
          My photoshop broke with El Capitan
          • 2. Re: Adobe Photoshop CS6 OS X El Capitan
            Brucgovn Adobe Community Professional
            We cannot say that CS 6 is completely compatible with EI Capitan , however it should work fine.
            Even Photoshop CC 2014 is not mentioned as compatible with Mac OS X 10.11
            System requirements | Photoshop
            Bob, are you getting any error message?  are you getting error after upgrading to Mac OS X 10.11?
            If possible post a screenshot .
            Note:
            During OS upgrade process , there will be certain changes with System Files which may have affected installed Apps .
            If you could provide exact error message or screenshot , it will be very helpful to find out cause of issue.
            • 3. Re: Adobe Photoshop CS6 OS X El Capitan
              Bob deWitt Level 1
              Photoshop is now working for me with El Capitan. It turned out that the OS didn't break Photoshop after all. Instead, as a result of the OS installation process, El Capitan made the Permissions for Adobe 'Read Only' for some reason. Once I went to the Adobe 'Get Info' and changed the Permissions to 'Read and Write,' Photoshop loaded successfully and now performs fine.
              • 4. Re: Adobe Photoshop CS6 OS X El Capitan
                Clevervieve2
                How do you go to the Adobe 'Get Info' and change the Permissions?
                • 5. Re: Adobe Photoshop CS6 OS X El Capitan
                  It is Ideal to provide Read & Write Access to Adobe folders under both System as well User Library to avoid Permissions related issues.
                  Follow below steps :
                  Step 1 :
                  1) Right click on Finder icon and  select "Go-To" Folder option.
                  2) You will get a text box, type-in below command and then hit 'Return' key.( Do not miss ~ symbol)
                  ~/library
                  3)Then navigate to Application Support>Adobe
                  Right click on Adobe folder and select "GetInfo" option.
                  Expand the Sharing & Permissions section.
                  Click the lock icon in the lower-right corner. Enter your administrator user name and password when prompted, and then click OK.
                  Please click on '+' symbol , it will open list of user accounts. Add Currently logged in user name and Administrator option,
                  Then provide "Read & Write" permission to Currently logged in user name and Administrator option,.
                  Click the Gear icon, and select Apply to Enclosed Item. Close the Get Info dialog box.
                  Step 2:
                  /library
                  Example screenshot :
                  Sharing and Permissions section
                  2 people found this helpful
                  • 6. Re: Adobe Photoshop CS6 OS X El Capitan
                    laurentf44100535
                    I download and install AE CS6 but I can't open it!! I've a message telling (from french translation) " Error during the acces to the files... check files authorization and try again"... what should I do???
                    (sorry but I don t know where to ask questions!)
                    Laurent
                    • 7. Re: Adobe Photoshop CS6 OS X El Capitan
                      This is the correct place to ask questions
                      If possible , please post screenshot of error message.
                      Did you tried providing permissions like mentioned above ?
                      • 8. Re: Adobe Photoshop CS6 OS X El Capitan
                        laurentf44100535 Level 1
                        Hi, I'm not sure I did! Where it is to provide permissions? ( i try to "repaired" permission by using "terminal)
                        • 9. Re: Adobe Photoshop CS6 OS X El Capitan
                          ~/library
                          3) It will open User Library folder  inside locate folder name Preferences.
                          Right click on Preferences folder and select "GetInfo" option.
                          Also Provide Full permissions to Adobe folder under ~/Library / Application Support  and /Library /Application Support .
                          ( I had provided steps  above )
                          Example Screenshot :
                          Image result for mac folder permissions
