3 Replies Latest reply on Apr 27, 2006 6:23 AM by Newsgroup_User
    Memory Game
    NS5
      Hello,
      I am trying to do a simple Memory Game in Flash 8. The examples I have found are much more complicated than what this game needs to be so I was trying to create my own from scratch. There is no random needed just 8 cards on the screen so 4 matches total. When they get a match the pair visibility turns off and when they are all matched it goes to a finished screen. I have all of that working great but I am having 2 problems.
      Problem 1:
      When the user selects the wrong card that isn’t a match I need it to flip back over and set the variables back to 0. I can’t figure out how to do this without writing a conditional statement for each possible order the user could select them in.
      Problem 2:
      When they select the second card and it is a match the match disappears which is good but it goes so quickly that the user doesn’t even have time to see that they got the match. I would like it to delay so it doesn’t disappear so fast.
      I would really appreciate any help here.
      Thanks so much!!!
      Movie Clips On Stage
      card1a
      card1b
      card2a
      card2b
      card3a
      card3b
      card4a
      card4b
      card1a matches with card1b
      card2a matches with card2b
      card3a matches with card3b
      card4a matches with card4b
      Actions on Root Level
      On Frame 1:
      _global.match1=0
      _global.match2=0
      _global.match3=0
      _global.match4=0
      On Frame 5:
      card1a.onRelease = function() {
      _root.card1a.play();
      card1b.onRelease = function() {
      _root.card1b.play();
      card2a.onRelease = function() {
      _root.card2a.play();
      card2b.onRelease = function() {
      _root.card2b.play();
      card3a.onRelease = function() {
      _root.card3a.play();
      card3b.onRelease = function() {
      _root.card3b.play();
      card4a.onRelease = function() {
      _root.card4a.play();
      card4b.onRelease = function() {
      _root.card4b.play();
      On Frame 6:
      if ((_global.match1 == 2) && (_global.match2 == 2) && (_global.match3 == 2) && (_global.match4 == 2)) {
      _root.gotoAndPlay(10);
      } else {
      _root.gotoAndPlay(_currentframe-1);
      if (_global.match1 == 2) {
      card1a._visible = false;
      card1b._visible = false;
      if (_global.match2 == 2) {
      card2a._visible = false;
      card2b._visible = false;
      if (_global.match3 == 2) {
      card3a._visible = false;
      card3b._visible = false;
      if (_global.match4 == 2) {
      card4a._visible = false;
      card4b._visible = false;
      Actions within Movie Clips
      card1a
      Frame 1:
      stop();
      Frame 5:
      _global.match1 = (_global.match1) + 1
      trace(_global.match1);
      stop();
      Frame 10:
      _global.match1 = (_global.match1) - 1
      card1b
      Frame 1:
      stop();
      Frame 5:
      stop();
      Frame 10:
      card2a
      Frame 1:
      stop();
      Frame 5:
      _global.match2 = (_global.match2) + 1
      trace(_global.match2);
      stop();
      Frame 10:
      _global.match2 = (_global.match2) - 1
      card2b
      Frame 1:
      stop();
      Frame 5:
      stop();
      Frame 10:
      _global.match1 = (_global.match2) - 1
      card3a
      Frame 1:
      stop();
      Frame 5:
      _global.match3 = (_global.match3) + 1
      trace(_global.match3);
      stop();
      Frame 10:
      _global.match3 = (_global.match3) - 1
      card3b
      Frame 1:
      stop();
      Frame 5:
      stop();
      Frame 10:
      card4a
      Frame 1:
      stop();
      Frame 5:
      _global.match4 = (_global.match4) + 1
      trace(_global.match4);
      stop();
      Frame 10:
      _global.match4 = (_global.match4) - 1
      card4a
      Frame 1:
      stop();
      Frame 5:
      stop();
      Frame 10:
        • 1. Re: Memory Game
          Level 7
          NS5,
          99% of games are not simple, even if they're supposed to be.
          I applaud that! You will learn and appreciate to much more if you build
          your own. Just don't think it'll necessarily be easy.
          > Problem 1:
          > When the user selects the wrong card that isn?t a match
          > I can?t figure out how to do this without writing a
          Can you explain these variables? The ones you have to set back to zero,
          I mean. Off the top of my head, I wouldn't use variables so much as
          properties of my movie clip "cards." Give each card an instance name, then
          add a property ... something like this:
          cardA.face = "apple";
          cardB.face = "apple";
          cardC.face = "pear";
          cardD.face = "pear";
          cardE.face = "orange";
          cardF.face = "orange";
          cardG.face = "peach";
          cardH.face = "peach";
          And then when it's time to compare them, simply check this property of
          each movie clip ...
          if (clipReference1.face == clipReference2.face) { ... }
          ... where clipReference1 and clipReference2 refer to whatever movie clips
          were selected. Does that make sense?
          Show us how you're currently comparing two cards.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: Memory Game
            NS5 Level 1
            Thank you for getting back to me. I dont know how to explain my functionality better than what I did so I have uploaded the FLA file to my personal site so you can download it. It is the link below
            http://nmsproductions.com/Downloads/MemoryGame.zip
            Basically I am using the variable _global.match1 and setting it to zero. When the user clicks on one card it sets the variable for that match to its current number plus 1 and if they click it again to turn the card back over it subtracks 1. Then if that variable is equal to 2 the match is made and it is removed from the stage.
            Thanks for the help!!!
            • 3. Re: Memory Game
              Level 7
              NS5,
              Sure.
              As a rule, I prefer not to download files -- mainly because it forces
              the developer to really think through what he/she has done, in order to
              formulate a good question -- but I took a look in this case. Honestly,
              I'm a bit confused by your approach.
              Here are a few quick observations.
              You don't need those _global variables. It's fine to have them, but
              they just aren't necessary, here. If you want variables that are available
              to any ActionScript in the main timeline (where all your code is), then a
              normal declaration will work just fine.
              e.g.
              var myString:String = "some string:
              var myNumber:Number = 5;
              You can use the following in your MovieClip.onRelease handlers ...
              this.play();
              ... which is functionally identical to what you have, but easier to read, I
              think.
              Rather than keep so many variables (four of them), all you really need
              is a single variable that keeps track of what other card, if any, was the
              last one flipped. At the beginning, of course, no cards will have been
              flipped, so you might do this ...
              var lastCardFlipped:MovieClip = null;
              Then the MovieClip.onRelease handler for each card should do the
              following: a) cause the card to play through its animation; b) check if
              another card has been flipped; c) if so, check if the current card's custom
              property (discussed last time) matches the custom property of the last card
              flipped; d) if not (meaning, if no other card has been flipped), note itself
              as the "last card flipped" for next time.
              First, you'll have to give each card an identity via a custom property.
              cardA.id = "card 1";
              cardB.id = "card 1";
              cardC.id = "card 2";
              cardD.id = "card 2";
              cardE.id = "card 3";
              cardF.id = "card 3";
              // etc.
              Then your event handler might be ...
              carA.onRelease = function() {
              this.play();
              if (lastCardFlipped == null) {
              lastCardFlipped = this;
              } else {
              if (this.id == lastCardFlipped.id) {
              // this is a match
              } else {
              // this is not a match, so set lastCardFlipped
              // back to null and start again
              lastCardFlipped = null;
              NOTE: These are off-the-cuff suggestions of mine; I'm not trying to
              dictate how your game should work. Obviously, you may want to add
              features, move/change features, etc. I'm just hoping this at least gives
              you something different to chew on.
              David
