Hi All
New customer to CC, cc constantly says that It has lost functionality and to re-install, I've done this several times and used the CC cleaner tool. whats the point in having CC if you cant use any of it?!
Thanks for your reply, But i Spent quite some time with online support yesterday who managed to get me sorted, I did not have an AAM UPDATER file, I couldnt delete the OOBE Folder contents either, I had to rename the creative cloud folder. I was then sent the application manager - which then updated to the new one before I was able to get the apps. Long winded but it worked. I had tried the procedure you have above, just not all of the steps worked for me. Thank you to the support staff member w
...Copy link to clipboard
Hi Nicola,
Please try the below steps and check :
MAC :
1- Force Quit all Adobe related processes from Activity Monitor (eg- Creative Cloud, Core sync, CC library, Adobe Desktop Services, Adobe IPC broker, Adobe Crash daemon etc.)
2- Go To: Finder > Applications > Utilities > Adobe Installer > Uninstall Adobe Creative cloud ( if having trouble uninstalling it Trash it )
3- Go To: Finder > Applications > Utilities > ( Delete these two folders - Adobe creative cloud and Adobe Application Manager )
4- Then run the cleaner tool to remove creative cloud and Adobe Application Manager ( if still left in machine )
5- Right click on Finder icon and select "Go-To" Folder option.
6- You will get a text box, type-in below command and then hit 'Return' key.( " Do not miss ~ symbol " )
~/library ( It will open User Library folder. )
7- Then navigate to Application Support>Adobe> trash OOBE folder and AAM Updater folder as well
8- Again > Right click on Finder icon and select "Go-To" Folder option.> You will get a text box, type-in below command and then hit 'Return' key./library ( It will open System Library folder.)
9- Then navigate to Application Support>Adobe> trash OOBE folder and Adobe Application Manager / after this rename the file SL-STORE as SL-STORE_OLD
10- Run Adobe Cleaner tool. > If present, Select the option "Adobe Application Manager for Mac OS X 10.6" and then click on "Clean up Selected" .
http://download.macromedia.com/SupportTools/Cleaner/mac/AdobeCreativeCloudCleanerTool.dmg
11- Click on the below link and download Creative Cloud Installer file and use the same to install the Creative Cloud Desktop application.
https://ccmdls.adobe.com/AdobeProducts/KCCC/1/osx10/CreativeCloudInstaller.dmg
WINDOW :
1) Uninstall Creative Cloud Desktop Manager :
Creative Cloud Help | Uninstall the Creative Cloud desktop app
2) Delete following folders :
C:\Program Files (x86)\Common Files\Adobe\OOBE
C:\Program Files (x86)\Common Files\Adobe\Adobe Application Manager
C:\Program Files (x86)\Adobe\Creative Cloud Folders
C:\Users\<user_name>\AppData\Local\Adobe\ AAM UPDATER and OOBE both
C:\Program DATA \Adobe\ rename the file SL-STORE as SL-STORE_OLD
3- Run Adobe Cleaner tool : http://download.macromedia.com/SupportTools/Cleaner/win/AdobeCreativeCloudCleanerTool.exe
4- Click on the below link and download Creative Cloud Installer file and use the same to install the Creative Cloud Desktop application.
Download Adobe Creative Cloud apps | Free Adobe CC trial
Let us know if this helps.
Regards,
Bani
Thanks for your reply, But i Spent quite some time with online support yesterday who managed to get me sorted, I did not have an AAM UPDATER file, I couldnt delete the OOBE Folder contents either, I had to rename the creative cloud folder. I was then sent the application manager - which then updated to the new one before I was able to get the apps. Long winded but it worked. I had tried the procedure you have above, just not all of the steps worked for me. Thank you to the support staff member who helped me, I was literally pulling my hair out!
Moving to Creative Cloud Download & Install‌
