2 Replies Latest reply on Oct 16, 2015 7:46 AM by franckl21266413
    CMYK: use custom settings into a script with converttoprofile
    franckl21266413
      Hi all,
      I have a problem to assign custom setting into a script for the converttoprofile function.
      I need to use "Custom CMYK ..." as destination profile.
      In Photoshop, do Edit>Convert To Profile..., then set Destination Space as "Custom CMYK ...", it opens a second window where you can set some more settings like GCR, UCA , ...
      If I use SL, the result of the script is a calculated profile, which is not what I want. I need to set in the script the settings of that second window.
      Is there a way to set GCR, UCA (and other parameters) in the script ?
      var idconvertToProfile = stringIDToTypeID( "convertToProfile" );
          var desc9 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref1 = new ActionReference();
              var idDcmn = charIDToTypeID( "Dcmn" );
              var idOrdn = charIDToTypeID( "Ordn" );
              var idTrgt = charIDToTypeID( "Trgt" );
              ref1.putEnumerated( idDcmn, idOrdn, idTrgt );
          desc9.putReference( idnull, ref1 );
          var idT = charIDToTypeID( "T   " );
          desc9.putData( idT, String.fromCharCode( 0, ...., 0, 255 ) ); // <----- profile calculated with the settings from the second window
          var idInte = charIDToTypeID( "Inte" );
          var idClrm = charIDToTypeID( "Clrm" );
          desc9.putEnumerated( idInte, idInte, idClrm );
          var idMpBl = charIDToTypeID( "MpBl" );
          desc9.putBoolean( idMpBl, true );
          var idsdwM = charIDToTypeID( "sdwM" );
          desc9.putInteger( idsdwM, -1 );
      executeAction( idconvertToProfile, desc9, DialogModes.NO );
      Regards.
