5 Replies Latest reply on Oct 16, 2015 11:17 AM by Peter Grainge
    Native Mobile App not working ?
    jsem Level 1
      Hi i'm trying to generate native mobile app using robohelp i defined all requirement as i think here is:
      phonegap sdk : C:\Users\admin\AppData\Roaming\npm ; //not sure if this correct
      android sdk : D:\sdk\android-sdk
      jdk : C:\Program Files\Java\jdk1.8.0_05
      ant : D:\sdk\apache-ant-1.9.5-bin\apache-ant-1.9.5
      i got error message "verify jdk /ant paths and refer to out put log" here is my output log
      C:\Users\admin\Desktop\apk>android update project --name "NewProject" --target 1 --path .
      'C:\Windows\system32\java.exe' is not recognized as an internal or external command,
      operable program or batch file.
      ERROR: SWT folder '' does not exist.
      Please set ANDROID_SWT to point to the folder containing swt.jar for your platform.
      Building App NewProject...
      C:\Users\admin\Desktop\apk>ant debug
      Buildfile: C:\Users\admin\Desktop\apk\build.xml
      -set-mode-check:
      -set-debug-files:
      -check-env:
      [checkenv] Android SDK Tools Revision 24.4.0
      [checkenv] Installed at D:\sdk\android-sdk
      -setup:
           [echo] Project Name: NewProject
        [gettype] Project Type: Application
      -set-debug-mode:
      -debug-obfuscation-check:
      -pre-build:
      -build-setup:
      [getbuildtools] Using latest Build Tools: 23.0.1
           [echo] Resolving Build Target for NewProject...
      [gettarget] Project Target:   Android 6.0
      [gettarget] API level:        23
           [echo] ----------
           [echo] Creating output directories if needed...
          [mkdir] Created dir: C:\Users\admin\Desktop\apk\bin\rsObj
          [mkdir] Created dir: C:\Users\admin\Desktop\apk\bin\rsLibs
           [echo] ----------
           [echo] Resolving Dependencies for NewProject...
      [dependency] Library dependencies:
      [dependency] No Libraries
      [dependency]
      [dependency] ------------------
           [echo] ----------
           [echo] Building Libraries with 'debug'...
         [subant] No sub-builds to iterate on
      -code-gen:
      [mergemanifest] Found Deleted Target File
      [mergemanifest] Merging AndroidManifest files into one.
      [mergemanifest] Manifest merger disabled. Using project manifest only.
           [echo] Handling aidl files...
           [aidl] No AIDL files to compile.
           [echo] ----------
           [echo] Handling RenderScript files...
           [echo] ----------
           [echo] Handling Resources...
           [aapt] Found Deleted Target File
           [aapt] Generating resource IDs...
           [echo] ----------
           [echo] Handling BuildConfig class...
      [buildconfig] Generating BuildConfig class.
      -pre-compile:
      -compile:
          [javac] Compiling 3 source files to C:\Users\admin\Desktop\apk\bin\classes
          [javac] warning: [options] source value 1.5 is obsolete and will be removed in a future release
          [javac] warning: [options] target value 1.5 is obsolete and will be removed in a future release
          [javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
          [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:3: error: package org.apache.cordova does not exist
          [javac] import org.apache.cordova.DroidGap;
          [javac]                          ^
          [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:6: error: cannot find symbol
          [javac] public class DefaultActivity extends DroidGap
          [javac]                                      ^
          [javac]   symbol: class DroidGap
          [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:9: error: method does not override or implement a method from a supertype
          [javac]     @Override
          [javac]     ^
          [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:12: error: cannot find symbol
          [javac]         super.onCreate(savedInstanceState);
          [javac]         ^
          [javac]   symbol:   variable super
          [javac]   location: class DefaultActivity
          [javac] C:\Users\admin\Desktop\apk\src\com\company\app\DefaultActivity.java:13: error: cannot find symbol
          [javac]         super.loadUrl("file:///android_asset/www/index.htm");
          [javac]         ^
          [javac] 5 errors
          [javac] 3 warnings
      BUILD FAILED
      D:\sdk\android-sdk\tools\ant\build.xml:716: The following error occurred while executing this line:
      D:\sdk\android-sdk\tools\ant\build.xml:730: Compile failed; see the compiler error output for details.
      Total time: 1 second
      Build failed. Refer to the log above.
