2 Replies Latest reply on Oct 14, 2015 1:39 PM by Willi Adelberger
    Possible Bug with InDesign CC 2015 when exporting PDF
      Running Windows 7 with InDesign CC2015. Have run across instances where I'm trying to fully embed an editable font into a PDF for use in a web to print front end. The PDF profile has been setup to subset at 0% so the font should fully embed. On some fonts such as Calibri, the font will only embed subset the font with identity-H encoding. This PDF will not work properly in the web to print system. If I setup the exact same layout in Illustrator CC 2015, using the exact same PDF profile, the font is fully embedded in the PDF, and works perfectly in the system. Has anyone noticed this behavior in InDesign?
