2 Replies Latest reply on Oct 14, 2015 11:51 PM by shenstoneUK
    Premier elements keeps crashing on windows 10 PC
      running on an I7 with loads of disk and memory, an up to date graphics driver and I have tried reinstalling and still no luck.
      No other software (and I run a lot of photo software) has had any issues at all
      I'm attaching some windows event log items in the hope that someone from adobe is collecting information to come up with a fix. At the moment I am thinking of reverting to PE 12 which runs fine
      Any ideas ?
      Faulting application name: Adobe Premiere Elements.exe, version:, time stamp: 0x55e5a5ad
      Faulting module name: AudioFilters.dll, version:, time stamp: 0x55e5a06c
      Exception code: 0xc0000005
      Fault offset: 0x000000000000709a
      Faulting process ID: 0x1698
      Faulting application start time: 0x01d106bd0ff5fc5a
      Faulting application path: C:\Program Files\Adobe\Adobe Premiere Elements 14\Adobe Premiere Elements.exe
      Faulting module path: C:\Program Files\Adobe\Adobe Premiere Elements 14\AudioFilters.dll
      Report ID: 918c10c4-53f6-428d-ae2c-7bd9004f1538
      Faulting package full name:
      Faulting package-relative application ID:
      Fault bucket 120329908816, type 4
      Event Name: APPCRASH
      Response: Not available
      Cab Id: 0
      Problem signature:
      P1: Adobe Premiere Elements.exe
      P3: 55e5a5ad
      P4: AudioFilters.dll
      P6: 55e5a06c
      P7: c0000005
      P8: 000000000000709a
        • 1. Re: Premier elements keeps crashing on windows 10 PC
          A.T. Romano Level 7
          Please go to
          Local Disk C
          Program Files
          and, in the Adobe Premiere Elements 14 Folder, please find the file name Audio Filters.dll, right click it, and select Properties.
          In its Properties/General, what is the Open With program shown?
          If you go Properties/Security, how are the permissions set up?
          When you did the uninstall reinstall, did you use a cleaner like the free ccleaner  CCleaner - Download  in between the uninstall and reinstall? Did you do the reinstall with antivirus and firewalls disabled?
          I am not Adobe. Just user to user.
          Please consider, and then let us know of your progress as your time permits.
          Thank you.
          • 2. Re: Premier elements keeps crashing on windows 10 PC
            shenstoneUK Level 1
            HI ATR
            thanks for the comments
            The permissions on the file are as I would expect for a proper installation. (full for system and installer read and execute for users), and the software does operate for a while so it is not a permissions issue (which should throw a clean error and not just crash anyway)  it is something that happens within the program whilst running (a malformed call etc. )
            I will not disable the firewall and AV for any installations. no reputable company should put out an install that needs that any more. It has been quite a few years since companies could expect you to do that. if PSE 14 needs that (12 did not) then I will have to revert to12 or use another product, and my registry is OK I do not use that product, but have used similar and PSE actually puts very few keys in the registry anyway.
