1 Reply Latest reply on Oct 14, 2015 4:48 PM by Rick Gerard
    Downconverting pixel question
    creativen61565172 Level 1
      Converting from HD1080 to D1 4x3 0.91 pixel ratio. If I drag in a graphic that is square pixel to my new 4x3 comp, do I need to change the graphic to 0.91 pixel ratio or adjust its size?
        • 1. Re: Downconverting pixel question
          Do not change the PAR of any footage to match the comp. AE will do the conversion automatically. You will have to scale uniformly to fit. It will look distorted unless you turn on PAR corection in the comp panel.
          Personally I would create a NTSC square pixel comp using the comp preset and just drag my hd comp into that and then if needed change to NTSC specs when I render.
