7 Replies Latest reply on Oct 18, 2015 7:04 AM by A.T. Romano
    Since upgrading to W10, prem10 fails to recognise burner
    skyrunner355
      I have been using W7 for many years, along with Prem 10, and just the odd issue. However just upgraded to W10, and prepared a couple of projects, one now waiting to "burn". Prem10 fails to recognise the burner, (which hasn't been changed) neither does Bluray, but selecting AVCHD it does now recognise the burner, but my dvd player isn't compatible, so don't wish to use this setting. Never had this issue previously.
        Burner details from the AVCHD are D TSSTcorpDVDWBD SH-B123L is this is of interest. ,
      I selected DVD, and burnt to a selected documents file, and burnt using Nero from this.
        Any suggestions please, as would rather burn direct from Prem10, rather than burning to file and then burning from a file, eg two separate stages?
        • 1. Re: Since upgrading to W10, prem10 fails to recognise burner
          A.T. Romano Level 7
          skyrunner355
          Premiere Elements 10 on Windows 10 64 bit. What video card/graphics card does your computer use?
          Let us go through the usual routine....do you have the latest version of QuickTime installed on your computer along with Premiere Elements 10, and are you running the programs from a user account with administrative privileges. Apple has a problem with QuickTime latest version 7.7.8 and Windows 10. Until Apple works through its problems on that, please download and install QuickTime 7.7.6 for your Windows 10 64 bit computer. That 7.7.6 will meet the Premiere Elements QuickTime 7 requirement even though it is not actually the latest version of QuickTime 7.  QuickTime 7.7.6 for Windows
          You should go for uninstall reinstall following this scenario...
          1. Uninstall the program the usual control panel way
          2. Do a free ccleaner run through (regular and registry cleaner parts)  CCleaner - Download
          3. Reinstall the program with antivirus and firewalls disabled.
          The burner not recognized or media not present are two of the most difficult issues to resolve. But, the uninstall/ccleaner/reinstall with antivirus and firewalls disabled has worked for several. Let us see if it will work for you.
          We will be watching for your progress in the morning morning.
          ATR
          • 2. Re: Since upgrading to W10, prem10 fails to recognise burner
            skyrunner355 Level 1
            Evening ATR
            I hadn't received an email, (which has been sent in the past when asking a question) so only just logged on to view the replies if any. Thanks and will work through your reply and contact soonest.
            Sorry for the delay.
            • 3. Re: Since upgrading to W10, prem10 fails to recognise burner
              A.T. Romano Level 7
              skyrunner355
              Thanks for the follow up.
              If you are used to the email notification that someone has posted a reply in your thread, please verify how you have your preferences set for that feature.
              To get to preferences, the route should be click on your ID above one of your posts to bring up your profile. Look to the top right of the profile to the ID icon. Click on the tiny triangle there to get the drop down menu which includes the preferences and email preferences.
              From time to time the web group updates the Adobe Forums. So, good to check your preferences periodically to make sure that your information was unaffected by the web group's work.
              We will be watching for further developments as your schedule permits.
              ATR
              • 4. Re: Since upgrading to W10, prem10 fails to recognise burner
                Morning ATR.
                  Thanks for this reply, will check later though.
                I have to make contact with my local IT specialists, on Monday morning, as have an issue on my W10, which basically has made three identical folders with all my pictures in each, one in "pictures" "video".and "music" but can't delete any files without all going into recycling bin. This is rather more urgent, so will contact you once I have my tower back in regards the prem10 issue.
                  Thanks for your patience.
                   Jon
                Sent from my iPad
                • 5. Re: Since upgrading to W10, prem10 fails to recognise burner
                  A.T. Romano Level 7
                  Jon
                  Thanks for the update.
                  I went through the Windows 10 64 bit install on two of my computers, one was Windows 7 Pro 64 bit and the other Windows 8.1 64 bit.
                  I never did get the reserved Windows 10 that the Microsoft said would come in days/weeks. So I installed from an online Microsoft web site.
                  If any of those details can help, the following is my description of them
                  ATR Premiere Elements Troubleshooting: PE: Premiere Elements On Windows 10 Daily Discoveries
                  We will be watching for further developments as your situation indicates and time as your schedule permits.
                  Best wishes
                  ATR
                  • 6. Re: Since upgrading to W10, prem10 fails to recognise burner
                    Morning ATR
                    I have followed this reply, (re email replies) and found that under my “preferences” it looks as if it is set to receive email notifications.
                    My pc is away from tomorrow, for those various W10 issues I have which is more important than my prem 10 issue, so once I have pc returned, I’ll contact you again please.
                    Jon
                    • 7. Re: Since upgrading to W10, prem10 fails to recognise burner
                      A.T. Romano Level 7
                      Jon
                      Thanks for the reply.
                      If you are not seeing the email notifications in your Inbox and if you have not already, please look in the Junk email box to determine if those email notifications are getting detoured there.
                      We will be watching for further news of your progress, as your schedule permits.
                      Best wishes
                      ATR
