2 Replies Latest reply on Oct 15, 2015 7:33 AM by Chence27
    Element 3D particle replicator issue with rotation
    Chence27
      Any advice on how to rotate the entire particle replicator system in Element 3D?
      https://www.youtube.com/watch?v=GA0BETBhg1M'>https://www.youtube.com/watch?v=GA0BETBhg1M
      I tried playing with the replicator rotation settings, but it just seems to rotate each particle, whereas I want the entire particle system to rotate.  I want more diversity in the flow of the particles that I've created, as they seem to be on a loop, repeating the same pattern.  I believe adding random rotation to the system will do the trick, but I can't seem to pull it off.
      The settings that I've altered to achieve the effect thus far are as follows (all other settings remain the default):
      Scene Setup:
      Sphere Model
      Segments = 16
      Normal Threshold = 180 degrees
      Optimize Mesh = On
      Enable Deformation = On
      Group 1:
      Particle count = 5,000
      Replicator shape = Sphere
      Replicator Effects>Position noise>Noise evolution = 0x +88 degrees to 1x +88 degrees (over 5 seconds)
      Replicator Effects>Position noise>Noise amount = 103 to 166 (over 5 seconds)
      Any help would be appreciated, thanks!
