6 Replies Latest reply on Aug 18, 2016 7:33 AM by sreekarthik.k@gmail.com
    Move more then one xml element to particular script labeled textframe
    Level 1
      #include "glue code.jsx";
      var myLabel = "received";// change to label
      var myPage = app.properties.activeWindow && app.activeWindow.activePage;
      var myTextFrames = app.activeDocument.textFrames.everyItem().getElements().slice(0);
      l = myTextFrames.length,
      //____________________ XML RULE SET
      var myRuleSet = new Array (new Move_element);
      with(myDoc){
          var elements = xmlElements;
          __processRuleSet(elements.item(0), myRuleSet);
      function Move_element(){
          this.name = "r";
          this.xpath = "//a";
          this.apply = function(myElement, myRuleProcessor){
              with(myElement){
                 // app.select(myElement);
            //     try{
              while (l--)
                  if (myTextFrames[l].label != myLabel) continue;
                     myElement.placeXML(myTextFrames[l])
                  //   break;
                  myTextframes[l].fit(FitOptions.FRAME_TO_CONTENT);
                     // }catch(e){}
              return true;
      I need to move more than one xml element particular script labeled text frame but At a time I can only move one element.
      Also while move the element script throws the below error message.
      Its removing the next paragraph paragraph style. How to fix thix issue.
        • 1. Re: Move more then one xml element to particular script labeled textframe
          Level 1
          How Places XML content into the story, without replacing the existing content.
          • 2. Re: Move more then one xml element to particular script labeled textframe
            karthiks94217840 Level 2
            HI sreekarthik,
            You have completed in the above coding script?
            Please replay my post: "How can we Move the Contents of an xml element into text frame label in inDesign Script"
            Very urgent friend,
            Thanks in Advance
            KS
            • 3. Re: Move more then one xml element to particular script labeled textframe
              Level 1
              try this
              var myLabel = "a";// change to label
              with(myDoc){
                  this.name = "r";
                  this.xpath = "//a";
                      with(myElement){
                      while (l--)
                          break;
                      return true;
              • 4. Re: Move more then one xml element to particular script labeled textframe
                Hi Karthik,
                Thanks to share this code,
                Still, I have received error report. Please see below screenshot for your reference only.
                Please help friend. very urgent
                KS
                • 5. Re: Move more then one xml element to particular script labeled textframe
                  Here with, i have using "window >> CS6 >> version - 8.0"
                  Error in Application:
                  Ks
                  • 6. Re: Move more then one xml element to particular script labeled textframe
                    Level 1
                    Copy the code below
                    //  $File: //depot/indesign_5.0/gm/build/scripts/xml rules/glue code.jsx $
                    //  Owner: Lin Xia
                    //  $Author: sstudley $
                    //  $DateTime: 2007/02/15 13:37:33 $
                    //  $Revision: #1 $
                    //  $Change: 505969 $
                    //  Copyright 2006 Adobe Systems Incorporated. All rights reserved.
                    //  NOTICE:  Adobe permits you to use, modify, and distribute this file in accordance
                    //  with the terms of the Adobe license agreement accompanying it.  If you have received
                    //  this file from a source other than Adobe, then your use, modification, or
                    //  distribution of it requires the prior written permission of Adobe.
                    //  DESCRIPTION: JavaScript glue code for XML Rules Processing
                    //app.scriptPreferences.version = 6.0;
                    function ruleProcessorObject(ruleSet, ruleProcessor) {
                       this.ruleSet = ruleSet;
                       this.ruleProcessor = ruleProcessor;
                    function __makeRuleProcessor(ruleSet, prefixMappingTable){
                      // Get the condition paths of all the rules.
                      var pathArray = new Array();
                      for (i=0; i<ruleSet.length; i++)
                      pathArray.push(ruleSet[i].xpath);
                        // the following call can throw an exception, in which case
                        // no rules are processed
                        try{
                         var ruleProcessor = app.xmlRuleProcessors.add(pathArray, prefixMappingTable);
                        catch(e){
                        throw e;
                        var rProcessor =  new ruleProcessorObject(ruleSet, ruleProcessor);
                      return rProcessor;
                    function __deleteRuleProcessor(rProcessor) {
                      // remove the XMLRuleProcessor object
                      rProcessor.ruleProcessor.remove();
                      // delete the object properties
                      delete rProcessor.ruleProcessor;
                      delete rProcessor.ruleSet;
                      // delete the object itself
                      delete rProcessor;
                    function __processRuleSet (root, ruleSet, prefixMappingTable)
                        var mainRProcessor = __makeRuleProcessor(ruleSet, prefixMappingTable);
                      // if __processTree() fails with an exception,
                      // delete ruleProcessor and throw e
                      try {
                      __processTree(root, mainRProcessor);
                        __deleteRuleProcessor(mainRProcessor);
                      } catch (e) {
                        throw e;
                    function __processTree (root, rProcessor)
                      var ruleProcessor = rProcessor.ruleProcessor;
                      try
                         var matchData = ruleProcessor.startProcessingRuleSet(root);
                      __processMatchData(matchData, rProcessor);
                      ruleProcessor.endProcessingRuleSet();
                      catch (e)
                      // no longer deleting ruleProcessor within __processTree
                      // deletion occurs either in __processRuleSet, or external
                      // to glue code.
                      throw e;
                    function __processChildren(rProcessor)
                      try
                      var matchData = ruleProcessor.startProcessingSubtree();
                        catch (e)
                            ruleProcessor.halt();
                            throw e;
                    function __processMatchData(matchData, rProcessor)
                      var ruleSet = rProcessor.ruleSet;
                      while (matchData != undefined)
                      var element = matchData.element;
                      var matchRules = matchData.matchRules;
                      var applyMatchedRules = true;
                      // apply the action of the rule.
                      // Continue applying rules as long as the apply function returns false.
                      for (var i=0; i<matchRules.length && applyMatchedRules && !ruleProcessor.halted; i++)
                      applyMatchedRules = (false == ruleSet[matchRules[i]].apply(element, rProcessor));
                      matchData = ruleProcessor.findNextMatch();
                    function __skipChildren(rProcessor)
                      rProcessor.ruleProcessor.skipChildren();
