11 Replies Latest reply on Oct 19, 2015 7:47 AM by ECBowen
    Workstation choice between CPU vs RAM and GPU
    Gino Post
      Since CC 2015 Aftereffects doesn't utilize all the CPU power and the memory to CPU core ratio has been changed.
      I wonder what workstation would be the fasted in CC 2015 and future releases in rendering and preview.
      A HP Z440 with 128GB RAM, Quadro K5200 and 8Core 3.2Ghz CPU
      • 1 x SKU: F5W13AV HP Z440 Workstation 1
      • 1 x SKU: G8T96AV HP Z440 700W 90 Percent Efficient Chassis 1
      • 1 x SKU: J6S73AV Intel Xeon E5-1680v3 3.20GHz 20MB 2133 8C CPU 1
      • 1 x SKU: G8U38AV 128GB DDR4-2133 (8x16GB) RegRAM 1
      • 1 x SKU: J1P74AV NVIDIA Quadro K5200 8GB DL-DVI(I)+DL-DVI(D)+2xDP 1st No cables included Graphics 1
      • 1 x SKU: J3H86AV 512GB SATA 1st Solid State Drive 1
      vs HPZ840 with 64GB RAM, Quadro K4200 and dual 10Core 2.6Ghz CPU.
      • 1 x SKU: F5G73AV HP Z840 Workstation 1
      • 1 x SKU: G8X50AV HP Z840 1125W (1450W/200V) 90 Percent Efficient Chassis 1
      • 1 x SKU: J6F69AV Intel Xeon E5-2660v3 2.6 2133 10C 1stCPU 1
      • 1 x SKU: J6F88AV Intel Xeon E5-2660v3 2.6 2133 10C 2ndCPU 1
      • 1 x SKU: G8X76AV 64GB DDR4-2133 (16x4GB) 2CPU Registered RAM 1
      • 1 x SKU: J1Q21AV NVIDIA Quadro K4200 4GB DL-DVI(I)+2xDP 1st No cables included Graphics 1
      • 1 x SKU: J3K80AV 512GB SATA 1st Solid State Drive 1
      The price difference is €1000.
        • 1. Re: Workstation choice between CPU vs RAM and GPU
          cc_merchant Level 4
          NO way to answer this question without knowing about the application, the source material, the export format and the typical workflow.
          The first system has almost too much memory for an 8-core system, the 2-nd one has not enough memory for a 20-core system. Both have very pricey and underperforming Quadro cards. Both lack sufficient disks. You would be better off (price- and performance-wise) with a custom build PC, instead of these HP systems.
          • 2. Re: Workstation choice between CPU vs RAM and GPU
            Gino Post Level 1
            Source material is camera rushes in HD (XDCAMHD) and 4K(XAVC). The export format is HD in XDCAM HD.
            The workstations are connected to a central NAS for collaboration. Each workstation has a preserved bandwidth over 1 gb to this nas.
            The typical workflow is for broadcast video editing and compositing.
            Would the following be a better balance between CPU, RAM and GPU for Adobe premiere and aftereffects?
            CPU = 2 x 8 core Xeon
            RAM = 64GB
            GPU= NVIDIA QUADRO K6000
            What custom build spec's would you use?
            Gino
            • 3. Re: Workstation choice between CPU vs RAM and GPU
              RoninEdits Most Valuable Participant
              fastest in the crippled cc2015 and fastest in future fixed versions will be two different things. as you stated, AE cc2015 has been changed and the memory usage requirements will be lower going forward, but when AE will fully be ready is unknown. you will also need to decide if doing ram previews or disk cache previews, to determine how much memory you need. if you plan on keeping these workstations a long time, you may want to focus on the best computer for future versions of AE when its fixed. the dual cpu system is a fair amount faster of the two systems you list and should work best if using cc2014 multi-processing to render. if you plan on replacing these systems within a year or two, you may want an i7 based pc to get the highest clock speed. if these are dedicated AE only machines, the graphics card doesn't need to be very powerful unless using third party gpu plugins. the AE team announced they are going to slowly add gpu based processing features, so for now even the quadro k4200 should hold over for a good while, and could be replaced with a gtx when needed.
              • 4. Re: Workstation choice between CPU vs RAM and GPU
                cc_merchant Level 4
                The Quadro range is overpriced and under performing. For a fraction of the price of a K6000 you can buy a GTX 970 that is much faster. Price/performance wise the GTX 970 gives 10 times more 'bang-for-the-buck'.
                Since AE is not good at multi-threading, a single i7-5960X over clocked to 4.5 GHz easily outperforms dual Xeon 8-core systems.
                • 5. Re: Workstation choice between CPU vs RAM and GPU
                  Gino Post Level 1
                  Dear CC_Merchant,
                  For the same reason I've tried the GTX970 card. Even in the GeForce product range this gives the most performance/price ratio.
                  However in practice when using raytracing in AE the application throws errors to the user and doesn't do the rendering.
                  This card GTX970 and any of the GTX9xx series are not tested by Adobe.
                  raytracer_supported_cards.txt
                  GeForce GTX 285
                  GeForce GTX 470
                  GeForce GTX 570
                  GeForce GTX 580
                  GeForce GTX 590
                  GeForce GTX 670
                  GeForce GTX 675MX
                  GeForce GTX 680
                  GeForce GTX 680MX
                  GeForce GTX 690
                  GeForce GTX 760
                  GeForce GTX 770
                  GeForce GTX 780
                  GeForce GTX TITAN
                  GeForce GT 650M
                  Quadro CX
                  Quadro FX 3700M
                  Quadro FX 3800
                  Quadro FX 3800M
                  Quadro FX 4800
                  Quadro FX 5800
                  Quadro 2000
                  Quadro 2000D
                  Quadro 2000M
                  Quadro 3000M
                  Quadro 4000
                  Quadro 4000M
                  Quadro 5000
                  Quadro 5000M
                  Quadro 5010M
                  Quadro 6000
                  Quadro K2000
                  Quadro K2100M
                  Quadro K3000M
                  Quadro K3100M
                  Quadro K4000
                  Quadro K4000M
                  Quadro K4100M
                  Quadro K5000
                  Quadro K5000M
                  Quadro K5100M
                  Quadro K6000
                  Tesla C2075
                  A stable system has it's price when purchasing but costs less in the long run.
                  Gino
                  • 6. Re: Workstation choice between CPU vs RAM and GPU
                    cc_merchant Level 4
                    The GTX 9xx do not work with the obsolete Ray Tracing. If that is important to you, look at the GTX 7xx series.
                    • 7. Re: Workstation choice between CPU vs RAM and GPU
                      ECBowen Most Valuable Participant
                      Adobe is adding support for the 900 series cards in AE Ray Tracer. However they have stated in the past Ray Tracer is basically legacy and they will continue to build on the C4D link. The codecs you list would perform better with higher clock speed with less cores than lower clock speed and greater cores. I would also suggest a 5960X over the Dual Xeons. AE will still use a significant amount of cores and threads depending on the media and FX user. It uses a massive amount of ram even still. So you definitely want atleast 64GB of ram if you use AE quite abit.
                      Eric
                      ADK
                      • 8. Re: Workstation choice between CPU vs RAM and GPU
                        Gino Post Level 1
                        It seems that C4D renders utilizes all the CPU cores.
                        In this case a 5960X will be much slower than a 2 x 8 Core XEON system.
                        Using only an AE composition without C4D the 5960X will be a bit faster.
                        But can we assume that in the future Adobe will un-cripple aftereffects?
                        • 9. Re: Workstation choice between CPU vs RAM and GPU
                          cc_merchant Level 4
                          Wrong. See Tweakers Page - Single or Dual CPU
                          Even the pretty pricey E5-2667v3 (€ 2320 each) will be around 10% slower in dual CPU configuration than a single i7-5960X @ 4.5 GHz in a perfectly multi-threaded world and cost 4.5 times more. AFAIK we're not living in Utopia.
                          • 10. Re: Workstation choice between CPU vs RAM and GPU
                            Gino Post Level 1
                            Ok,
                            Accordingly to this graph a Dual 8 core system with E5-2667v3 CPU is approximately 8% faster than the single i7-5960X.
                            But the BFTB is indeed not completely not comparable.
                            • 11. Re: Workstation choice between CPU vs RAM and GPU
                              If you get Octane for C4D then the GPU acceleration will perform better with the 5960X versus the Dual Xeons. C4D without GPU acceleration will utilize all threads the system provides so a Dual Xeon is the ideal choice without GPU acceleration. However that is one of the few applications where that is the case currently. So if you are building to Adobe and C4D then I would suggest the X99 and 5960X with Octane.
                              Eric
                              ADK
