5 Replies Latest reply on Oct 15, 2015 10:27 PM by Qwertyfly...
    Rename active document while saving
    beto correa Level 1
      Hi
      Is there any possibility through script to rename the active document while saving?
      For example:
      Current: 124efg.ai
      To save and exit: 124efg_X.ai.
      Is it possible? Can someone help me?
        • 1. Re: Rename active document while saving
          Larry G. Schneider Adobe Community Professional & MVP
          Beto, take a look at the Java Script sample files. There's a get new name function you can use. Here's an example
          getNewName: Function to get the new file name. The primary
          name is the same as the source file.
          function getNewName()
              var ext, docName, newName, saveInFile, docName;
              docName = sourceDoc.name;
              ext = '.pdf'; // new extension for pdf file
              newName = "";
              for ( var i = 0 ; docName[i] != "." ; i++ )
                  newName += docName[i];
              newName += ext; // full pdf name of the file
              // Create a file object to save the pdf
              saveInFile = new File( destFolder + '/' + newName );
              return saveInFile;
          • 2. Re: Rename active document while saving
            pixxxel schubser MVP & Adobe Community Professional
            Hi beto correa,
            you can do e.g. something like this:
            var theName = app.activeDocument.name;
            theName = theName.replace (/\.ai/,'_X.ai'); // you can use this variable for saving
            Have fun
            • 3. Re: Rename active document while saving
              beto correa Level 1
              Hi Thanks so much
              When you run the script in the plugin script bay name in the footer changes but the document name remains the same and when I try to find the renamed (_x) I can not find. I did something wrong or is it still need to edit and finalize the script?
              • 4. Re: Rename active document while saving
                You can:
                - save as the opened file as a new file with the new name (you get a copy with the new name) or
                - rename the closed file
                IMHO it is not possible to save (and rename) an opened file at once.
                • 5. Re: Rename active document while saving
                  Qwertyfly... Level 4
                  try this.
                  // here is the string to add to the file name
                  var MyAddition = "_X";
                  var doc = app.activeDocument;
                  var docName = String(doc.fullName);
                  var newDocName = docName.replace(docName.substr(docName.lastIndexOf('.')),MyAddition+docName.substr(docName.lastIndexOf('.')));
                  doc.save();
                  doc.close();
                  File(docName).rename(newDocName);
                  app.open(File(newDocName));
