I have a record set that returns 2 records and I need to show
15 checkboxes which are hand coded. if the either of the two values
match one of the checkbox, i need to disable that checkbox and move
on to the next
the problem with the attached code is it disables the first
checkbox T-03 but it does not disbale T-06 like that is in the
recordset which returns T-03, T-06
Thank you so much! I'm a ASP to CF newb and I played around
with ValueList and could not get it right. I had four different
versions of this going to see what would work, a loop, a query
output, you name it I tried it but thank you very much ...
swhoo!
Mike - If you have a recordset that returns individual
records use the valueList function to get the recordset into a
comma delimited list. If you are returning a comma delimited field
of values than you don't need to use the valueList.
