0 Replies Latest reply on Nov 29, 2006 4:40 AM by Oddsy
    Charting: DataTips work, and then don't...
    Oddsy Level 1
      I have a LineChart with its showDataTips property set to true. They appear as they should to start with, but if the axes maximum and minimum values are set subsequently then the data tips no longer appear. I have tried all the NumericAxis descendants as the axes to see if it was just one of them but the same occurred with all. I also tried setting the showDataTips property to true again after setting the maximums and minimums, but that also made no difference. I shall keep digging around to see if I can narrow the problem down but I'm a bit stumped at the moment as to why this would happen.
      Any suggestions?
