3 Replies Latest reply on Oct 22, 2015 1:38 AM by c.pfaffenbichler
    Make Layers from slices or guides.
    MikeGondek Adobe Community Professional & MVP
      Mac CC 2015. Would like to convert each slice or guided division into an individual layer with the mask.
      Below is an example , where I would want a layer for each slice, including the mask.
      There was an extension called cut & slice me, but cannot even get that to install with CS6.
      Manually doing this is more time consuming in CC2015, as when you float a selection, the layer mask does not go over.
      Is easier for me to mask 1 layer and then make copies, rather than make 25 layers then have to mask 25 layers. The tool & layer swithching and brush sizes changing is a lot more work masking after the 25 layers are made.
        • 1. Re: Make Layers from slices or guides.
          c.pfaffenbichler Level 9
          Could you give this a try?
          // split layer with layer mask according to guides;
          // 2015, use it at your own risk;
          #target photoshop
          if (app.documents.length > 0) {
          var myDocument = app.activeDocument;
          var myResolution = myDocument.resolution;
          var theLayer = myDocument.activeLayer;
          var layerID = getLayerId(theLayer);
          var originalRulerUnits = app.preferences.rulerUnits;
          app.preferences.rulerUnits = Units.POINTS;
          // check guides;
          var theVer = new Array;
          var theHor = new Array;
          var theNumber = myDocument.guides.length;
          for (var m = 0; m < theNumber; m++) {
          if (myDocument.guides[m].direction == Direction.HORIZONTAL) {theHor.push(myDocument.guides[m].coordinate)};
          if (myDocument.guides[m].direction == Direction.VERTICAL) {theVer.push(myDocument.guides[m].coordinate)};
          // sort and add beginning and end;
          theHor = treatGuideArray (theHor, app.activeDocument.width);
          theVer = treatGuideArray (theVer, app.activeDocument.height);
          $.writeln(theHor.join("\n")+"\n\n\n"+theVer.join("\n"));
          // create selections;
          for (var y = 0; y < theHor.length - 1; y++) {
            var Y1 = theHor[y];
            var Y2 = theHor[y+1];
            for (var x = 0; x < theVer.length - 1; x++) {
            try {
            var X1 = theVer[x];
            var X2 = theVer[x+1];
            rectangularSelection([Y1, X1, Y2, X2], false);
          // layer via copy;
            var id14 = charIDToTypeID( "CpTL" );
            executeAction( id14, undefined, DialogModes.NO );
          // add mask;
            intersectedLayerMask (layerID)
            } catch (e) {};
          // reselct layer;
            myDocument.activeLayer = theLayer;
          // reset the ruler units;
          app.preferences.rulerUnits = originalRulerUnits
          ////////////////// the functions //////////////////
          ////// treat array //////
          function treatGuideArray (theArray, theExtreme) {
          theArray.sort(function(a,b){return a - b});
          if (Number (theArray[theArray.length - 1]) != theExtreme) {theArray.push(theExtreme)};
          if (Number (theArray[0]) != 0) {theArray.unshift(new UnitValue(0, "pt"))};
          return theArray;
          ////// rectangular selection //////
          function rectangularSelection (theBounds, add) {
          if (add == false ||  add == undefined) {var idsetd = charIDToTypeID( "setd" )}
          else {var idsetd = charIDToTypeID( "AddT" )};
              var desc55 = new ActionDescriptor();
              var idnull = charIDToTypeID( "null" );
                  var ref11 = new ActionReference();
                  var idChnl = charIDToTypeID( "Chnl" );
                  var idfsel = charIDToTypeID( "fsel" );
                  ref11.putProperty( idChnl, idfsel );
              desc55.putReference( idnull, ref11 );
              var idT = charIDToTypeID( "T   " );
                  var desc56 = new ActionDescriptor();
                  var idTop = charIDToTypeID( "Top " );
                  var idRlt = charIDToTypeID( "#Rlt" );
                  desc56.putUnitDouble( idTop, idRlt, theBounds[0] );
                  var idLeft = charIDToTypeID( "Left" );
                  desc56.putUnitDouble( idLeft, idRlt, theBounds[1] );
                  var idBtom = charIDToTypeID( "Btom" );
                  desc56.putUnitDouble( idBtom, idRlt, theBounds[2] );
                  var idRght = charIDToTypeID( "Rght" );
                  desc56.putUnitDouble( idRght, idRlt, theBounds[3] );
              var idRctn = charIDToTypeID( "Rctn" );
              desc55.putObject( idT, idRctn, desc56 );
          executeAction( idsetd, desc55, DialogModes.NO );
          // by mike hale, via paul riggott;
          function getLayerId(theLayer){
          // http://forums.adobe.com/message/1944754#1944754
          app.activeDocument.activeLayer = theLayer;
          //Assumes activeDocument and activeLayer
              var ref = new ActionReference();
              ref.putEnumerated(charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
              d = executeActionGet(ref);
          return d.getInteger(charIDToTypeID('LyrI'));
          ////// load transparency, ontersect with layer mask ofd another layer, add layer mask //////
          function intersectedLayerMask (layerID) {
          var idsetd = charIDToTypeID( "setd" );
              var desc2 = new ActionDescriptor();
                  var ref1 = new ActionReference();
                  ref1.putProperty( idChnl, idfsel );
              desc2.putReference( idnull, ref1 );
                  var ref2 = new ActionReference();
                  var idTrsp = charIDToTypeID( "Trsp" );
                  ref2.putEnumerated( idChnl, idChnl, idTrsp );
              desc2.putReference( idT, ref2 );
          executeAction( idsetd, desc2, DialogModes.NO );
          var idIntr = charIDToTypeID( "Intr" );
              var desc3 = new ActionDescriptor();
                  var ref3 = new ActionReference();
                  var idMsk = charIDToTypeID( "Msk " );
                  ref3.putEnumerated( idChnl, idChnl, idMsk );
                  var idLyr = charIDToTypeID( "Lyr " );
                  ref3.putIdentifier( idLyr, layerID );
              desc3.putReference( idnull, ref3 );
              var idWith = charIDToTypeID( "With" );
                  var ref4 = new ActionReference();
                  ref4.putProperty( idChnl, idfsel );
              desc3.putReference( idWith, ref4 );
          executeAction( idIntr, desc3, DialogModes.NO );
          var idMk = charIDToTypeID( "Mk  " );
              var desc4 = new ActionDescriptor();
              var idNw = charIDToTypeID( "Nw  " );
              desc4.putClass( idNw, idChnl );
              var idAt = charIDToTypeID( "At  " );
                  var ref5 = new ActionReference();
                  ref5.putEnumerated( idChnl, idChnl, idMsk );
              desc4.putReference( idAt, ref5 );
              var idUsng = charIDToTypeID( "Usng" );
              var idUsrM = charIDToTypeID( "UsrM" );
              var idRvlS = charIDToTypeID( "RvlS" );
              desc4.putEnumerated( idUsng, idUsrM, idRvlS );
          executeAction( idMk, desc4, DialogModes.NO );
          • 2. Re: Make Layers from slices or guides.
            Wow! Almost perfect. Last column seems to get sliced. I even tried again with an extra guide and did the same.
            Here is the image incase you are able to test. Thank you for your time to this.
            http://ftp.kaleidoscopechicago.com/_u5QuwmbcyTgiLR
            FILENAME:   grapes.psd
            26.7 MB
            The URL will expire on Nov 20.
            • 3. Re: Make Layers from slices or guides.
              Sorry, please change
              to
              theHor = treatGuideArray (theHor, app.activeDocument.height);
              theVer = treatGuideArray (theVer, app.activeDocument.width);
              Edit: I tested with a square image, so the effect was imperceptible.
