This content has been marked as final.
Show 6 replies
1. Re: Captivate 2 export to Flash 8
Captiv8r Nov 28, 2006 2:10 PM (in response to Nickels55)Hi Flashtard (Probably really takes one to know one! - So there's my deprecating statement)
I wonder if the following would work. I know to create a single .SWF movie, you edit the skin (Project > Skin...) and click the Borders tab, then DE-select the check box for borders. My thoughts are that if this creates a single file with the playback controller as part of that file, maybe, just maybe it will work for Flash Export too.
Just a shot from the hip... Rick
2. Re: Captivate 2 export to Flash 8
Nickels55 Nov 28, 2006 3:05 PM (in response to Nickels55)Did that already - no luck :(
It's odd because I had no problem with the controller showing up when converting over Captivate 1.0 files. Hmmmmmm -
3. Captivate 2 export to Flash 8
Dexterous Nov 29, 2006 6:09 AM (in response to Nickels55)Hi Nickels55,
You can still export the Old skin to flash just as CA 1.01. For this open the skin editor (project -> skin...), from the top left drop down for skin, select BMP Playbar. Save the project and then export to flash. However if you want to see the new playbars also exported to flash you can make feature request by clicking here -
4. Re: Captivate 2 export to Flash 8
Nickels55 Nov 29, 2006 8:10 AM (in response to Nickels55)Mind if I asked how the heck did you figured that out? Great find - thanks for saving me $40 to get tech support on a buggy issue that has NO INFO ANYWHERE ON ADOBE'S SITE. Nice policy they got there - release a buggy product and make you pay for them to tell you it doesn't work. -
5. Re: Captivate 2 export to Flash 8
Captiv8r Nov 29, 2006 8:21 AM (in response to Nickels55)Hi again Nickels55
I'm glad to see you got this sorted. Many thanks to users such as Dexterous that are able to offer advice.
Regarding your question of "How the heck did you figure that out?". I personally believe this underscores the importance and usefulness of a medium such as these forums. Here we have a focal point of many thousands upon thousands of users.
It just takes that one user that has decided to try poking Captivate in just the right spot "just to see what it will do if you do that" to make such discoveries.
At least that's my take on it. I confess, I'm a regular Captivate poker. I sure am glad it isn't a bear!
Cheers all... Rick
6. Re: Captivate 2 export to Flash 8
Nickels55 Nov 29, 2006 9:19 AM (in response to Nickels55)Just noticed that even though it works, using this technique removes the closed captioning. The problems never end...
