3 Replies Latest reply on Oct 16, 2015 5:05 AM by Test Screen Name
    I need to convert SCANNED TEXT only documents into PDF/A. Is there a certain order in the procedure to do this? I use Acrobat X Pro.
    wpth1234
      Is there a certain order in the procedure to do this? I use Acrobat X Pro. These text documents need to be searchable. I've tried diffferent approaches, and always get cannot convert because of "glyphs" or some other reason I am not sure what. Here is what I do, maybe I just need to change my procedure. 1, Scan document 2 redact to remove marks and blemishes 3 Remove Hidden Info 4 embed text, 5 OCR document 6 add meta data 7 run preflight, 8 DO IT AGAIN CAUSE IT WON'T CONVERT??? Please Help Also, it doesn't have to be PDF/A, one of the lower pdf/ such as pdf 1a 0r 2b will work THANKS
