5 Replies Latest reply on Oct 17, 2015 4:01 AM by c.pfaffenbichler
    Is it possible to get layer, layerset and layer with in layerset status...!!!
    natrev Level 3
      Hi Everyone!,
      Is it possible to get layer, layerset and layer with in layerset status. Since I have faced big problem beyond this.
      I have an one PS document which is contain collection of layer, collection layersets with layer. I need apply function for each layer and layersets and all layers with in layerset.
      Also I tried one code but its getting error. Please help me to out this code...
      -yajiv
      #target photoshop
      app.bringToFront();
      $.level=2;
      var docRef = app.activeDocument;
      var log="";
      var x=0;
      var n=Number(docRef.layers.length)-1;
      for (i=0;i<n;i++){
          var tm=String(docRef.layers[i]);
          var isLayer=tm.lastIndexOf("ArtLayer");
          var isLayerSet=tm.lastIndexOf("LayerSet");
          if(isLayer!=-1){
              Check_LayerStructure(docRef.layers[i],"Layer");
          if(isLayerSet!=-1){
              Check_LayerStructure(docRef.layerSets,"LayerSets");
              x=x+1;
      function Check_LayerStructure(objLayer,objflag,x){       \
          if(objflag=="Layer"){
              LayetStructure(objLayer,objLayer.name,BlendMode.NORMAL,100,100,0,true," Layer ");
          else if(objflag=="LayerSets"){
              LayetStructure(objLayer[x],objLayer[x].name,BlendMode.PASSTHROUGH,100,100,1,true," Set ");
              m=Number(objLayer[x].layers.length)
              for (j=0;j<m;j++){
                  var tm=String(objLayer[x].layers[j]);
                  if(isLayer!=-1){
                      Check_LayerStructure(objLayer[x].layers[j],"Layer");
                  if(isLayerSet!=-1){
                      Check_LayerStructure(objLayer[x].layerSets,"LayerSets",x);
          } // Layerset Loop
      }// I For Loop
      }//Function loop
      function LayetStructure(layerRef,L,bMode,Opt,fillOpt,S,layVisible,Lref){
          if(layerRef.blendMode!=bMode){
                if (confirm (L + Lref+"belend mode was wrong...!!!\n"+"Do you want to change....?")){
                    layerRef.blendMode=bMode;
                    log=log+"- " +L+ Lref+ "belend mode was changed...!!!\n\n";
                    e=1;
         if(layerRef.opacity!=Opt) {
                if (confirm (L + Lref+ "Opacity was "+Math.round(layerRef.opacity)+"%...!!!\n"+"Do you want to change....?")){
                    layerRef.opacity=Opt;
                   log=log+"- " + L + Lref+ "Opacity was changed to 100...!!!\n\n";
                    e=1;
            if(layerRef.fillOpacity!=fillOpt && S==0) {
                if (confirm (L + Lref+ "Fill was "+Math.round(layerRef.fillOpacity)+"%...!!!\n"+"Do you want to change....?")){
                    layerRef.fillOpacity=fillOpt;
                    log=log+"- " + L + Lref+ "Fill was changed to 100...!!!\n\n";
                    e=1;
          if(layerRef.visible!=layVisible) {
                if (L + Lref+ "eye was off..!!!\n"+"Do you want to change....?"){
                    layerRef.visible=layVisible;
                    log=log+"- " + L + Lref+ "eye was turn into on...!!!\n\n";
                    e=1;
