2 Replies Latest reply on Oct 16, 2015 7:25 AM by A.T. Romano
    I am using a Roland V-4EX video mixer to capture...I'm having troubles
    jermisch2000
      When I try to capture the video and audio through the USB I can only see the V-4EX in the audio and no video.  The only option for video is through my webcam...any suggestions?  Is it a driver issue?
        • 1. Re: I am using a Roland V-4EX video mixer to capture...I'm having troubles
          A.T. Romano Level 7
          jermisch2000
          What version of Premiere Elements on what computer operating system.
          The DV and HDV data capture firewire into Premiere Elements capture window are gone in Premiere Elements 13/13.1 and 14. The following Adobe documents gives suggested workarounds for the situation.
          Removed features and unsupported file formats | Adobe Premiere Elements 13
          Firewire, not USB, is the way to go.
          Depending on your computer operating system, there are 3rd party firewire capture programs that will give you the split clips to import into the Premiere Elements project.
          Windows
          Movie Maker
          HDVSplit   HDVSplit 0.77 beta
          WinDV   WinDV
          Please consider and supply more information.
          Thank you.
          ATR
          • 2. Re: I am using a Roland V-4EX video mixer to capture...I'm having troubles
            A.T. Romano Level 7
            jermisch2000
            Add On to post 1....
            Just took a look at Roland V-4EX video mixer, which basically looks like a webcam operation.
            If the device is being recognized by the Premiere Elements Add Media/Get Media Webcam choice and you are getting audio but no video, then
            we need to talk about the properties of the source....
            video compression
            audio compression
            frame size
            frame rate
            interlaced or progressive
            file extension
            pixel aspect ratio
            Are you recording 480p59.94 with that device? Premiere Elements project settings to explore before Webcam choice is selected - you would see File Menu/New/Project Change Settings for setting the project preset manually to
            NTSC
            DSLR
            480p
            DSLR 624 x480p60
            Please consider.
            Thank you.
            ATR
