0 Replies Latest reply on Oct 16, 2015 10:47 AM by asdfasdfe
    gpusniffer error on after effects cc 2015 startup
    asdfasdfe Level 1
      Yesterday after updating to the latest CC 2015 version: 13.5.1.48
      I now get the following GPUsniffer error on startup of the application:
      It asks to ignore, or report, when I ignore the app finished launching just fine.  But here is the error output.  It looks like it cannot find a library (bolded text).  I would like to fix this as other people using this machine may be freaked out if they see an error like this!
      Process:           AEGPUSniffer [5433]
      Path:              /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/AEGPUSniffer.app/Contents/MacOS/AEGPUSniffer
      Identifier:        AEGPUSniffer
      Version:           ???
      Code Type:         X86-64 (Native)
      Parent Process:    After Effects [5417]
      Responsible:       After Effects [5417]
      User ID:           502
      Date/Time:         2015-10-16 10:32:12.144 -0700
      OS Version:        Mac OS X 10.10.5 (14F27)
      Report Version:    11
      Anonymous UUID:    FF51C5B9-B165-F3B6-DB74-6E890E683DD0
      Time Awake Since Boot: 66000 seconds
      Crashed Thread:    0
      Exception Type:    EXC_BREAKPOINT (SIGTRAP)
      Exception Codes:   0x0000000000000002, 0x0000000000000000
      Application Specific Information:
      dyld: launch, loading dependent libraries
      Dyld Error Message:
        Library not loaded: @executable_path/../Frameworks/liboptix.1.dylib
        Referenced from: /Applications/Adobe After Effects CC 2015/Adobe After Effects CC 2015.app/Contents/AEGPUSniffer.app/Contents/MacOS/AEGPUSniffer
        Reason: image not found
      Binary Images:
      0x7fff675cf000 - 0x7fff67605887  dyld (353.2.3) <B1B370A5-479F-3533-8AD7-97B687D4F989> /usr/lib/dyld
      Model: MacPro6,1, BootROM MP61.0116.B15, 8 processors, 8-Core Intel Xeon E5, 3 GHz, 32 GB, SMC 2.20f18
      Graphics: AMD FirePro D500, AMD FirePro D500, PCIe, 3072 MB
      Memory Module: DIMM1, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D3147394E3120
      Memory Module: DIMM2, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D3147394E3120
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.15.166.24.3)
      Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Ethernet 1, Ethernet, en0
      Network Service: Ethernet 2, Ethernet, en1
      Network Service: Thunderbolt Ethernet Slot 2, Port 2, Ethernet, en11
      PCI Card: AMD FirePro D500, Display Controller, Slot-1
      PCI Card: AMD FirePro D500, Display Controller, Slot-2
      PCI Card: pci17d3,1880, RAID Controller, Thunderbolt@158,0,0
      PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@234,0,0
      PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@233,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@239,0,0
      PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@239,0,1
      PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@239,0,2
      PCI Card: DeckLink Studio 4K, Video, Thunderbolt@79,0,0
      PCI Card: ethernet, Ethernet Controller, Thunderbolt@78,0,0
      PCI Card: pci1b4b,9182, AHCI Controller, Thunderbolt@83,0,0
      PCI Card: pci1b4b,9182, AHCI Controller, Thunderbolt@82,0,0
      Serial ATA Device: APPLE SSD SM1024F, 1 TB
      Serial ATA Device: TOSHIBA DT01ACA100, 1 TB
      USB Device: Hub
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: Hub
      USB Device: Macally Laser Mouse
      USB Device: Hub in Apple Pro Keyboard
      USB Device: Apple Pro Keyboard
      USB Device: FaceTime HD Camera (Display)
      USB Device: Apple Thunderbolt Display
      USB Device: Display Audio
      Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
      Thunderbolt Device: Echo Express III TB2, Sonnet Technologies, Inc., 1, 21.1
      Thunderbolt Device: ARC8050-T2, Areca, 3, 22.1
      Thunderbolt Device: Thunderbolt Display, Apple Inc., 3, 26.2
