3 Replies Latest reply on Oct 17, 2015 11:19 AM by A.T. Romano
    the video quality is worse when i put in adobe premiere elements and the sound doesn't worK:(
      im trying to do game movie
        • 1. Re: the video quality is worse when i put in adobe premiere elements and the sound doesn't worK:(
          A.T. Romano Level 7
          We need information/details in order to help you.
          What version of Premiere Elements and what computer operating is involved?
          What are the properties of the video that you are trying to import and edit and export from your version of Premiere Elements?
          If you do not know, can you tell us the brand/model/settings of the camera that recorded the video? You mention "game movie". Are you recording the video audio from one of those game recording devices? If so, which one, and what are the recording settings.
          The whole idea is getting at those video properties to try to determine where the properties are having problems with Premiere Elements.
          Is this the first time you are using Premiere Elements for your video projects? Or, have you used this video before with Premiere Elements and everything was fine then?
          Are you setting the project preset (project settings) for the project yourself manually (File Menu/New/Project) or are you letting the program decide for you based on its analysis of the first file dragged to the Timeline?
          Please consider, supply information, and then we can plan some troubleshooting strategy to get you moving forward with your Premiere Elements projects?
          Any questions or need clarification on any of the above, please do not hesitate to ask.
          Thank you.
          • 2. Re: the video quality is worse when i put in adobe premiere elements and the sound doesn't worK:(
            sharonk22391621 Level 1
            hey thanks for anwsering , I use Adobe Premiere Elemnets 13 ,
            I have Tauros overkill gtx 680 my computers information
            DMI Processor
              manufacturer Intel(R) Corporation
              model Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
              clock speed 3500.0 MHz
              FSB speed 100.0 MHz
              multiplier 35.0x
            Drive 0
              Type Fixed
              Name TOSHIBA DT01ACA200
              Capacity 1863.0 GB
              SMART Support Yes
            Drive 1
              Type Fixed
              Name Samsung SSD 840 Series
              Capacity 232.9 GB
              SMART Support Yes
            Number of adapters 1
            Graphic APIs
            API NVIDIA I/O
            API NVIDIA NVAPI
            Display Adapters
            Display adapter 0
              Name NVIDIA GeForce GTX 680
              Board Manufacturer EVGA Corp.
              Revision A2
              Codename GK104
              Technology 28 nm
              Memory size 2 GB
              Memory type GDDR5
              PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
              Vendor ID 0x10DE (0x3842)
              Model ID 0x1180 (0x2680)
              Performance Level 0
              Core clock 1058.5 MHz
              Memory clock 3004.0 MHz
            Win32_VideoController AdapterRAM = 0x80000000 (2147483648)
            Win32_VideoController DriverVersion =
            Win32_VideoController DriverDate = 10/02/2015
            Monitor 0
              Model DELL E196FP (Dell Computer)
              ID DELA015
              Serial FC99864J10UL
              Manufacturing Date Week 16, Year 2006
              Size 17.1 inches
              Max Resolution 1280 x 1024 @ 60 Hz
              Horizontal Freq. Range 31-80 kHz
              Vertical Freq. Range 56-75 Hz
              Max Pixel Clock 140 MHz
              Gamma Factor 2.2
            Windows Version Microsoft Windows 10 (10.0) Home 64-bit   (Build 10240)
            DirectX Version 12.0
            Im recording with Bandicam its software, so im recording my counter strike video.
            Format settings
            Video H.264- NVENC (VBR)
            full size 30,00fps 100q
            audio mpeg-1 L2
            its my first time useing Adobe premiere Elemens 13.
            But when im record the frag movie with bandicam, and after open with windows media player , picture and the sound is working perfect. .
            • 3. Re: the video quality is worse when i put in adobe premiere elements and the sound doesn't worK:(
              A.T. Romano Level 7
              Thanks for the important and helpful troubleshooting information.
              My initial focus is going to be on the Bandicam source that you are importing into the Premiere Elements 13/13.1 project.  Even though the source may work perfectly in player does not always mean that it will not have its problems in Premiere Elements.
              1. Premiere Elements has its problems with video recorded with a variable frame rate instead of a constant one. The symptoms can range from Timeline audio out of sync to not being able to import the video at all. So, based on the following Bandicam recommendations Bandicam - Official Site, first thing we need to know how did you set for
              FPS Settings
              Use VFR - Variable Frame Rate (Recommended)
              Prefer CFR - Constant Frame Rate
              Falls back on VFR if the encoder's performance is not good enough.
              If variable frame rate is contributing to the Premiere Elements issues, then
              a. Use different Bandicam settings for frame rate when recording your video
              b. Convert the Bandicam video with variable frame rate to a H.264.mp4 with constant frame rate version using the free HandBrake program
              and then use that as your import into the Premiere Elements project.
              2. The other matter is the properties of that Bandicam video in general. It seems to be using the H.264 NVENC video compression. What is
              Frame Size (width and height in pixel units)
              Frame Rate (right now appears to be 30 frames per second as the given)
              File extension (.avi or .mp4)....H.264 NVENC as .avi will probably not import into Premiere Elements whereas H.264.mp4 should.
              Let us start here to work through the troubleshooting. Setting up the Premiere Elements project optimally is the next critical step to get a match between your video and the project settings. I will give you detailed import and export settings once we learn more about the above.
              Thanks for the follow up. Appreciated.
              And, any questions or need clarification on the above, please do not hesitate to ask at any step as we more forward to a solution.
