2 Replies Latest reply on Jan 2, 2008 9:26 AM by GYorky
    tab order (tabbing )
    kaurj Level 1
      Is there a way we can stop the tab from going out of flex component to Internet explorer. When i tab through my app after the last text field the tab goes to the foot bar of IE and then to header and then to address bar and then back to the main component. Is there a way i can stop it from going out of the flex component. I tried tabIndex but it doesn't seem to work. Please reply with examples.
        • 1. Re: tab order (tabbing )
          gur_sukh
          Has anyone got seamlessTabbing to work for then in flash 9
          • 2. Re: tab order (tabbing )
            GYorky
            Yes
            In your application MXML tag, put the following
            keyFocusChange="appFocusOut(event)"
            Then, inside a <mx:Script> block, add the following function
            private function appFocusOut(event:FocusEvent):void
            // Check that the focus isn't leaving the application
            if (!event.relatedObject)
            event.preventDefault(); //Stop the tab index leaving
            var first:IFocusManagerComponent = focusManager.getNextFocusManagerComponent();
            first.setFocus();
            What this does is check whenever the user presses the tab key to make sure that the application has somewhere to tab to inside Flex. The keyFocusChange event is triggered before the tab moves out of the field, giving you the chance to cancel it
            If event.relatedObject is null, that means that Flex is going to move the tab focus outside the application. To prevent this happening, we call event.preventDefault(). Finally, to make the tabbing loop round, we call focusManager.getNextFocusManagerComponent().setFocus();
