12 Replies Latest reply on Feb 27, 2016 1:15 PM by TᴀW
    CC2015 Refresh Progress Bar
    grg79
      Hi
      I read several post about the subject....
      Why a simple script with a progress bar don't display/refresh progress bar?
      Only  CC-CC2015.
      CS5-CS6 work fine
      #targetengine "progress2"
      app.scriptPreferences.enableRedraw = true
      var found = new Array (50);
      var w = new Window ('palette');
      w.pbar = w.add ('progressbar', undefined, 0, found.length); w.pbar.preferredSize.width = 300;
      w.show();
      for (var i = 0; i < found.length; i++){ w.pbar.value = i+1;
      $.sleep(20); // Do something useful here
      More complex script.... same problem.... don't display/refresh the window.
      #targetengine "progress"
      function ProgressBar(/*str*/title, /*uint*/width, /*uint*/height)
      // Version 2.beta | 12-Nov-2014
      // -- Keep the message centered --see below the new method this.msg()
      // -- Supports message patterns e.g: "Step %1/100" --see the sample code
      // -- Other minor improvements
          (60<=(width||0))||(width=340);
          (40<=(height||0))||(height=60);
          var H = 22,
              Y = (3*height-2*H)>>2,
              W = new Window('palette', ' '+title, [0,0,width,height]),
              P = W.add('progressbar', { x:20, y:height>>2, width:width-40, height:12 }, 0,100),
              T = W.add('statictext' , { x:0, y:Y, width:width, height:H }),
              __ = function(a,b){ return localize.apply(null,a.concat(b)) };
          this.pattern = ['%1'];
          W.center();
          // API
          this.msg = function(/*str*/s)
              s && (T.location = [(width-T.graphics.measureString(s)[0])>>1, Y]);
              T.text = s;
          this.show = this.reset = function(/*str*/s, /*uint*/v)
              if( s && s != localize(s,1,2,3,4,5,6,7,8,9) )
                  this.pattern[0] = s;
                  s = __(this.pattern, [].slice.call(arguments,2));
              else
                  this.pattern[0] = '%1';
              P.value = 0;
              P.maxvalue = v||0;
              P.visible = !!v;
              this.msg(s);
              W.show();
          this.hit = function(x)
              ++P.value;
              ('undefined' != typeof x) && this.msg(__(this.pattern, [].slice.call(arguments,0)));
          this.hide = function()
              W.hide();
          this.close = function()
              W.close();
      //      SAMPLE CODE
      (function()
          var PB = new ProgressBar("Script Title",350,100),
              i, vMax;
          // Quick process
          PB.show("Processing quickly... %1 / 500", vMax=500, i=0);
          for( ; i < vMax ; $.sleep(8), PB.hit(++i) );
          PB.reset("Wait for 800 ms...");
          $.sleep(800);
          // Slow process
          PB.reset("And now slowly (%1%)  |  Stage %2", vMax=13, 0, i=0);
          for( ; i < vMax ; ++i, PB.hit((100*(i/vMax)).toFixed(2), i), $.sleep(400+200*(.5-Math.random())) );
          $.sleep(500);
          PB.msg("The job is done.");
          $.sleep(1500);
          // Quit
          PB.close();
