4 Replies Latest reply on Oct 19, 2015 2:13 AM by jonathanweber
    Change parametric sice of rectangle shape to scale from and to the anchor point
    jonathanweber Level 1
      For a current project of mine I am using a lot of shapes - particularly rectangle shapes with rounded corners. To preserve the proportions of the rounded corners when animating size changes, I am using the rectangle path's size property to scale the shape. This seems to work pretty good, except that I can not get After Effects to use the Anchor-Point for this method - the rectangle shape is allways scaled from and to the center of the shape.
      Does this type of "scaling" not support anchor points, or am I missing something here? How do you solve this in your projects?
      Thanks in advance!
