5 Replies Latest reply on Jul 19, 2016 3:40 AM by Drunkano
    Autodesk 3ds max 2015~16 Slate Compositor Link Settings  After Effects error
    Wal3dmi
      After Effects error: internal verification failure, sorry! {No projects open.}
      ( 5027 :: 55 )
      would you please solve this error ? !!!!
        • 2. Re: Autodesk 3ds max 2015~16 Slate Compositor Link Settings  After Effects error
          Krisshoffa
          I cant get past this error: "After Effects error: internal verification failure, sorry! (No projects open.) ( 5027 :: 55 )
          I run 3Ds Max 2015 and After Fx cc 2015.
          Please help me!
          • 3. Re: Autodesk 3ds max 2015~16 Slate Compositor Link Settings  After Effects error
            Krisshoffa Level 1
            See the end of this message for details on invoking
            just-in-time (JIT) debugging instead of this dialog box.
            ************** Exception Text **************
            Adobe.AfterFX.Utilities+AfterEffectsErrorException: 3dsmax After Effects plugin has encountered an error with code: 3
               at Autodesk.Plugins.Adobe.AfterFX.SceneIO.Plugin.GetMainFolderHandle()
               at Autodesk.Plugins.Adobe.AfterFX.SceneIO.Plugin.GetMainCompositionHandle(Boolean createIfDoesntExist)
               at Autodesk.Plugins.Adobe.AfterFX.SceneIO.Plugin.SetProjectLinkData(String filePath, Single globalScale)
               at Autodesk.Max.StateSets.CompositorLink.CompositorLinkSettingsController.set_LinkFilePath(S tring value)
               at Autodesk.Max.StateSets.CompositorLink.CompositorLinkSettings.updateLinkButton_Click(Objec t sender, EventArgs e)
               at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
               at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
               at System.Windows.Forms.Control.WndProc(Message& m)
               at System.Windows.Forms.ButtonBase.WndProc(Message& m)
               at System.Windows.Forms.Button.WndProc(Message& m)
               at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
            ************** Loaded Assemblies **************
            mscorlib
                Assembly Version: 4.0.0.0
                Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
                CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
            Autodesk.Plugins.Adobe.AfterFX.SceneIO.Loader
                Assembly Version: 17.1.0.0
                Win32 Version:
                CodeBase: file:///C:/Program%20Files/Adobe/Adobe%20After%20Effects%20CC%202015/Support%20Files/Plug -ins/AEGP/Autodesk.Plugins.Adobe.AfterFX.SceneIO.Loader.aex
            Adobe.AfterFX
                Assembly Version: 17.1.2.0
                Win32 Version: 17.1.2.0
                CodeBase: file:///C:/Program%20Files/Adobe/Adobe%20After%20Effects%20CC%202015/Support%20Files/Adob e.AfterFX.DLL
                CodeBase: file:///C:/Program%20Files/Adobe/Adobe%20After%20Effects%20CC%202015/Support%20Files/Auto desk.Plugins.Adobe.AfterFX.SceneIO.DLL
                Win32 Version: 4.0.30319.34251 built by: FX452RTMGDR
                CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77 a5c561934e089/System.Windows.Forms.dll
            System.Drawing
                Win32 Version: 4.0.30319.34270 built by: FX452RTMGDR
                CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f1 1d50a3a/System.Drawing.dll
            System
                Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
                CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/ System.dll
            System.Xml
                Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
                CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e 089/System.Xml.dll
            System.Configuration
                Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
                CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03 f5f7f11d50a3a/System.Configuration.dll
            ************** JIT Debugging **************
            To enable just-in-time (JIT) debugging, the .config file for this
            application or computer (machine.config) must have the
            jitDebugging value set in the system.windows.forms section.
            The application must also be compiled with debugging
            enabled.
            For example:
            <configuration>
                <system.windows.forms jitDebugging="true" />
            </configuration>
            When JIT debugging is enabled, any unhandled exception
            will be sent to the JIT debugger registered on the computer
            rather than be handled by this dialog box.
            • 4. Re: Autodesk 3ds max 2015~16 Slate Compositor Link Settings  After Effects error
              shiftey1990
              I'm also struggling with this issue. There is an updated installer from Autodesk for CC 2015, but it doesn't recognize the After Effects installation and so it doesn't install. Why can't we get a manual install zip file or something?
              • 5. Re: Autodesk 3ds max 2015~16 Slate Compositor Link Settings  After Effects error
                Drunkano
                I am still having no fun with this compositor link, it does not seem to like CC 2015.3 at all.
                if anyone has got this to work in 2015.3 please let me know.
                ive tried copying the relevant dlls, but the importer does not appear.
                my current work around is to import 3dsmax camera into CS6, then import that AFX project in 2015.3.
                Nonsense!
