2 Replies Latest reply on Dec 19, 2006 4:56 AM by Axachi
    Certificate Error when using pub services with IE7
    anthmedia
      everytime i try to use pub services admin console i get the following warning im using IE7 any idea how to stop this nag ? :
      There is a problem with this website's security certificate.
      The security certificate presented by this website was not issued by a trusted certificate authority.
      Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
      We recommend that you close this webpage and do not continue to this website.
      Click here to close this webpage.
      Continue to this website (not recommended).
      More information
      If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting.
      When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com.
      If you choose to ignore this error and continue, do not enter private information into the website.
        • 1. Re: Certificate Error when using pub services with IE7
          Sudharshan.S
          hi,
          IE 7 has changed the way certificates were handled when compared to IE 6. In IE 6, the user gets an option to view the certificate before proceeding to view the site. In the process the user can import the certificate into the browsers trust store.
          Since CPS is deployed with a self signed certificate, in IE 7 we get a certificate error.
          There is currently no workaround for the same, except to deploy cps war file on an application server that has a certificate signed by a signing authority
          thanks,
          sudharshan
          • 2. Certificate Error when using pub services with IE7
            Axachi
            Well not entirely true ther is a way...
            after you get the web site...
            "There is a problem with this website's security certificate.
            The security certificate presented by this website was not issued by a trusted certificate authority."
            Click the Continue to this web site (not recomended)
            Now when you get to this site on the right hand side of the address bar ther is a certificat error click on that and then choos view certificat. then install :)
            go go Microsoft .:(
