2 Replies Latest reply on Nov 6, 2008 12:16 PM by Newsgroup_User
    overlapping tiles in a tileList
    bmilesp Level 1
      is it possible to have tiles overlap rather than be adjacent? I've tried a negative padding value with no luck. -b
        • 1. Re: overlapping tiles in a tileList
          Gregory Lafrance Level 6
          Sounds like you may need to extend TileList and do that in updateDisplayList.
          • 2. Re: overlapping tiles in a tileList
            Level 7
            "bmilesp" <webforumsuser@macromedia.com> wrote in message
            news:gev78c$d5$1@forums.macromedia.com...
            If you mess with the measure() function so that when TileList measures that
            first tile it doesn't report correctly, they might overlap depending on how
            your component draws (i.e. if you make it draw outside the measured area).
            Also, if your other tiles are larger than the first tile and, again, you
            draw outside your measured area, you can get overlapping.
            HTH;
            Amy
