• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
"Operation could not be completed (error 0x00000005). Access is denied" for printer properties after installing Adobe Acrobat DC
New Here ,
Oct 21, 2015 Oct 21, 2015
Hello,
I'm having a problem when I install Adobe Acrobat DC (from my Creative Cloud account), and can confirm it also happens when installing old Acrobat versions (8 and 9, which my school already owns).
After Adobe Acrobat DC is installed, as soon as I try to print to physical printers, I get an error:
I can confirm it happens in every computer I have tried as a troubleshooting method (keeping in abidance with the software license).
My school printers have the following setup:
-Printers are shared by a Linux server using CUPS.
-Printing is billed by PaperCut software.
When we add printers, those are the steps we follow:
-Network printer ("not in the list...").
-Location: https://printerserverfqdn:631/printers/printername.
-CUPS asks for an username and password: username/password.
-The wizard asks for the printer drivers, and then it finishes.
You double-click your printer icon, and the spool is shown.
After installing Adobe Acrobat, when you double click the printer you get the error popup "Operation could not be completed (error 0x00000005). Access is denied".
Fire up printmanagement.msc, navigate to Print Servers -> computer-Name (local) -> Ports. There you'll see the printer port (https://printerserverfqdn:631/printers/printername), right click, select "Configure Port..." and... you'll be asked again for the username/password.
Hence, it seems the Adobe Acrobat installer somewhat resets the printer properties, making them "forget" about the username/password that was setup by the IT team.
Any advice...? Having to reconfigure every printer for prospective Adobe Acrobat users is not an option...
TOPICS
Install update and subscribe to Acrobat
Views
20.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Oct 22, 2015 Oct 22, 2015
Please try the steps mentioned below:
Manually install the PDF Printer
  • Click Start >  Control Panel > Devices and Printers
  • Select Add a printer
  • Select Add a local printer
  • Check Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down.  Click Next
  • Click the Have Disk… button
  • Click the Browse… button
  • Navigate to C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\Xtras\AdobePDF
  • Select AdobePDF.inf from the list, then click the OK button
  • You will see many Adobe PDF Converters in the list, however count six down from the top and click Next (you may need to try this numerous times to find the correct Converter from the list that works with your version of Windows)
  • Name your printer, e.g. Adobe PDF
Abhishek
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks for your reply but those steps are not related with my issue: after I install Adobe Acrobat (the software), every Windows printer set up in my computer is reset and lose the username/password required by the network printer server. How can adding a printer by hand repair what a software installation did??
Votes
Translate
Translate
Report
Report
