2 Replies Latest reply on Oct 22, 2015 8:24 AM by martinl20025075
    Problem with the Flash player 19.0.0.226 msi version VS the web update version
    martinl20025075
      I download the latest .MSI file to be install with SCCM. When the upgraded has been done the flash player stop working. I use the normal download from adobe and install it from the website and it worked correctly. I test using Facebook to look at some video and it work. Can you please verify or upgrade the MSI files on the Adobe Flash Player Distribution | Adobe
      Regards
        • 1. Re: Problem with the Flash player 19.0.0.226 msi version VS the web update version
          maria__ Adobe Employee
          Hi martinl20025075,
          The web version and the MSI versions are the same and both should work fine viewing the same content.  To troubleshoot further, please provide the following information:
          • Your operating system & version
          • Your web browser(s) & version
          • Explain your problem in step-by-step detail if possible
          • A direct link to a page that demonstrates the problem.  Preferably a non-Facebook site.
          • If you get error messages, provide a screenshot: http://forums.adobe.com/thread/1070933
          Thank you.
          Maria
          • 2. Re: Problem with the Flash player 19.0.0.226 msi version VS the web update version
            martinl20025075 Level 1
            HI,
            I use SCCM2012 r2 to deploy the MSI using a application deployment and using this command:
            msiexec /i "install_flash_player_19_active_x.msi" /qn
            My 2 machines I used to test before the deployment where using flash player 18 version 194
            OS: wIndows pro 7 64 bit
            Internet explorer 11.0.23
            I uninstall the older version using this command:
            msiexec /x {901E9B21-CDB1-4C4A-ABFC-61A554912BED} /qn
            Like I said the application packages was deploy and flash was installed. But anything that use flash had a error that flash player not installed or must be updated.
            If I use the website adobe.com and download and install Adobe flash player 19.0.0.226. All my flash application worked.
            Then I uninstall flash player that was install using the web site and re-deploy it using SCCM2012. After that re-installation flash player 226 it worked correctly in internet explorer. I don't understand why it now worked on my machine.
            I will try on 2 other machine using only the MSI and see what will happen.
