1. Re: Error Lightroom: You can not create the required folder
dj_paige Oct 21, 2015 9:45 AM (in response to viviang72228506)You don't have write permission in your operating system to that specific folder. Change your permissions.
2. Re: Error Lightroom: You can not create the required folder
khatwaniOct 21, 2015 9:48 AM (in response to viviang72228506)
Hi viviang,
Greetings!!!
This is a permission issue.
Try giving permissions to both the Libraries (System Library & user Library) and the Applications folder.
For Applications Folder
Open Finder
On the left panel you will find applications folder -> right click on that (CTRL + Click) and then click on Get Info.
At the bottom you will find sharing and permissions - Click on that
You will find a Lock icon at the bottom right , please click on that lock icon and then it might ask you for your mac password, please put in that.
Now click on the small plus(+) icon and then add the users that you want , Please make sure that you are adding the admin account as well.
Provide read and write permissions to all.
Click on the gear icon at the bottom of the get info window and then choose "Apply to enclosed items " This will pop a message that changes cannot be undone- click OK to that.
This will apply privileges and that might take a bit time depending upon the size of folder.
once done , Click on lock icon and then close the get info window.
Done with applications folder here.
For User Library
Open Finder
Click on Go at the top and then select "Go to folder"
type "~/Library" and press go
Right Click(CTRL + click) on the the Library folder, if you are inside that library you can right click (ctrl + click) at blank space between the folders and then click on Get Info
Done with user library folder here.
For System Library
Open Finder
type "/Library" and press go
Done with System library folder here.
Please let me know if that works
Please Note : Do not just right click on complete MAC HD and provide full permissions that can make MAC in no boot mode.
Regards
Jitendra Khatwani
3. Re: Error Lightroom: You can not create the required folder
viviang72228506 Oct 21, 2015 1:22 PM (in response to khatwani)Thank you very much to all for the help.
I've done everything I said and seems to work properly. The only thing that worries me is that operators yesterday modified files on my Creative Cloud, now appears to be installed in lightroom Creative Cloud and some files appear to be impossible to synchronize.
Not that way change the location of the installation of the hard disk Lightroom my Mac. And not that way synchronize the remaining files, which apparently are more than 10 files.
4. Re: Error Lightroom: You can not create the required folder
khatwaniOct 21, 2015 1:27 PM (in response to viviang72228506)
You are Welcome.
I did not get this question .
Can you please elaborate that ?
Regards
Jitendra
5. Re: Error Lightroom: You can not create the required folder
viviang72228506 Oct 21, 2015 1:37 PM (in response to khatwani)Apologies Jitendra, I do not speak English fluently. I am using a translator.
Now everything seems to work correctly with the program, thank you.
I am concerned is that the operators of Adobe, yesterday modified files on my Creative Cloud. Lightroom is now installed on my Creative Cloud file space, and there are files that are not synchronized (more than 10 program files).
How I can change the installation location of the Lightroom to the hard drive on my Mac? and how I can synchronize the missing files?
Thank you
6. Re: Error Lightroom: You can not create the required folder
khatwaniOct 26, 2015 6:25 AM (in response to viviang72228506)
Hi ,
By default, your Creative Cloud apps are installed in the Program Files folder (Windows) or the Applications folder (Mac OS).
You can change the default install location, although it is not generally recommended. Open the Creative Cloud desktop app and click the gear icon at the top right of the window. Choose Preferences > Apps > Install location > Change. Navigate to the desired location and click Open. Your new install location will appear in the menu.
Also you can put the files in creative cloud files folder and turn the sync on.
Regards
Jitendra
