5 Replies Latest reply on Oct 23, 2015 11:38 AM by johnrellis
    Lightroom 6.0 SDK - improvement LrDevelopController
    kichetof
      Dear Power SDK User ,
      Thanks for all new great features insides SDK 6.0 !! In particular LrDevelopController !
      About this new namespace, I've some questions.
      Why we need to be on Develop module to apply developement parameters ? Could it be possible to apply them programmatically instead of "visual programmatically" like Excel Macro ?
      This is what I want (and do actually):
      1. Import new photo above the existing photo
      2. Create a develop snapshop for the new one
      3. Select existing photo
      4. get develop settings of existing photo
      5. select new imported photo
      6. refresh catalog:getTargetPhoto() (if not, the next line apply on the existing photo and not on the new one)
      7. Develop Controller set value for each parameters getted from existing photo
      8. create a new snapshot
      It seems that Develop Snapshot take no effect when it was done programmatically ?
      A snippet is more useful
      local import = catalog:withWriteAccessDo('Import', function(context)
          local photoImported = catalog:addPhoto(newPhoto, existingPhoto, 'above')
          photoImported:createDevelopSnapshot("Before syncing params", true) -- same image after setters no OK (need to be like after imported: empty; not like after setters new values)
          catalog:setSelectedPhotos(existingPhoto, {photoImported })
          local syncParams = existingPhoto:getDevelopSettings()
          --LrSelection.nextPhoto() -- no effect
          --LrSelection.previousPhoto() -- no effect
          catalog:setSelectedPhotos(photoImported , {})
          local convertedPhoto = catalog:getTargetPhoto()
      -- workaround to wait for displaying image :
          while convertedPhoto:getFormattedMetadata("fileName") ~= photoImported:getFormattedMetadata("fileName") do
          end
          for k, v in pairs(syncParams) do
              LrDevelopController.startTracking(k)
              LrDevelopController.setValue(k, v)
              LrDevelopController.stopTracking()
          end
          photoImported:createDevelopSnapshot("After syncing params", true) -- same image after setters OK
      end,
      {timeout = 30}
      What I have noticed:
      If the display isn't finished when you do setSelectedPhotos or nextPhoto(): LrDevelopController.setValue use the existing photo to apply setting and not the new one.
      If you decide to apply them on a lot of picture, it will take a long time to do that because you need to wait the new displayed picture who refresh before set new values.
      Why it isn't possible to do something like that ? (like copy paste settings) without needed to select and reselect and deselect and select ..
      newPhoto:setDevelopSettings(syncParams)
      Maybe I was wrong, but I have not found a "simple" solution to set development values
      Hope you'll have a nice workaround
      Tof
      If you want to try the plugin, you can download source here kichetof / lr_cr2hdr — Bitbucket
