• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Drag/Drop: Return to Start if Dropped Outside (not working as desired)
Explorer ,
Oct 22, 2015 Oct 22, 2015
In Adobe Captivate, I can set the drop targets in a drag-and-drop interaction to only accept the correct drag object. Can I do the same in Adobe Presenter 10? I have set up a drag and drop quiz question, but I want each drag object to bounce back to its starting location if it is dropped anywhere outside its correct drop target. I have checked the Return to start if dropped outside checkmark in the Drag Item Options section of the edit panel for the interaction. However, items do not bounce back if dropped onto an incorrect drop target. Is there a way to make them do that in Presenter 10?
Thanks!
   -Ray
TOPICS
Presenter
Views
700
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Oct 25, 2015 Oct 25, 2015
Hi Raymond,
With the option you checked, the drag object will bounce back to its starting location if it is dropped anywhere outside a drop target. That is it will bounce back only if it is dropped outside all the drop objects.
If it is dropped on any wrong drop object, it will not bounce back and is considered as a wrong answer.
However you may give users infinite attempts to get the answer correct .
Alpi Agarwal
Adobe Presenter Engineering Team
Votes
Translate
Translate
Report
Report
Explorer ,
Oct 28, 2015 Oct 28, 2015
Hi Alpi,
Thanks for the reply. You are correct, of course. But my question is: Is there any way to make wrong drop targets reject a drag object in Presenter 10 (or 11)?
Cheers!
    -Ray
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Ray,
Sorry, there is no way to make wrong drop targets reject a drag object in Presenter.
Alpi Agarwal
Votes
Translate
Translate
Report
Report
Community Beginner ,
Nov 24, 2015 Nov 24, 2015
Is it possible in Captivate 9 when using a drag and drop interaction?
Votes
Translate
Translate
Report
Report
Explorer ,
OK, thanks. Please consider adding this as a feature for Presenter 12.
Cheers!
    -Ray
Votes
Translate
Translate
Report
Report
Dec 14, 2017 Dec 14, 2017
LATEST
Yes, please add this function in the next version!
Votes
Translate
Translate
Report
Report
How do you set in to bounce back in Captivate?
Votes
Translate
Translate
Report
Report
Resources
Help resources
