I stumbled across this tag on the 'Enable other Liquid objects' doc as I was trying to find a solution to customise the HTML output of products so I can use a Masonry layout.
I added the code to the overall layout:
{tag_productlist,,,,,, collection="product-list" template=""}
<ul id="masonry-container" class="row small-block-grid-2 medium-block-grid-4 large-block-grid-4">
{% for item in product-list.items %}
<li class="product-list-masonry">
•• content **
</li>
{%endfor%}
</ul>
It works fine as list view, but nothing renders when clicking to the detail view. Can this tag be used yet? How do I render the product detail layout?
I also tried {module_data} but got into similar issues.
{module_data resource="products" version="v3" fields="id,name,tags,smallImage,largeImage,description,attributes,custom1,custom2,custom3,custom4,isOnSale,canonicalUrl" skip="0" limit="100" order="id" collection="products"}
Any pointers appreciated.
Paul
Hi Paul,
You should use something like this instead:
{% if globals.get.ProductID %} <p>This is the product detail layout</p> {% else %} <ul id="masonry-container" class="row small-block-grid-2 medium-block-grid-4 large-block-grid-4"> {% for item in custom-tag.items %} <li class="product-list-masonry"> {{item.name}} </li> {%endfor%} </ul> {% endif %}
You first need to tell whether you are in the product "large" view or on a catalog listing its products. After you know that you can either build
...Copy link to clipboard
Hi Paul,
You first need to tell whether you are in the product "large" view or on a catalog listing its products. After you know that you can either build the product view or loop the products and build the listing.
Hope this helps,
Mihai
Hey Mihai,
I am trying this as well, and I can get the <p>This is the product detail layout</p> after adding the globals.get.productID, but am stuck trying to figure out how to actually output the content. I've tried a forLoop within and nothing is outputting on the product detail page.
I am using the {tag_productlist,,,,,, collection="product-list" template=""} as above and it is working fine for the small/list view, but not on the large view.
Suggestions?
Aaron
