4 Replies Latest reply on Oct 23, 2015 6:38 PM by ottz0
    Using Node NPM
    ottz0 Level 1
      I thought users in this forum might be able to help me.
      Just a question about using node.
      I only have a few dependencies in my node_modules folder in my project but when I install them it seems to install all these other dependencies so I now have about 100 node folders when i'm just installing a few dev dependencies.
      Why is this? Should it install them do my main npm and then link to them?
        • 1. Re: Using Node NPM
          Ken Binney Level 6
          May I suggest this Forum for your question -
          Coding Corner
          • 2. Re: Using Node NPM
            Level 4
            It's most likely because the packages you're installing are dependent on other packages as well. You can delete the node_modules folder and then run npm install to install the packages again. This will install any packages you have configured in package.json and any dependencies on those packages (and dependencies on the dependencies) will load as well.
            best,
            Shocker
            • 3. Re: Using Node NPM
              ottz0 Level 1
              Thanks Kenny...didnt know this forum existed...ill remember that for nex time
              • 4. Re: Using Node NPM
                ottz0 Level 1
                hi the_shocker
                Yes, I thought it would download other dependencies also
                I might be wrong but can't node install dependencies into a global node folder and then Sym link to them from your project folder when configured in package.json? Seems pointless to download hundreds of files each time into your project when you will use them again for other projects?
