I am trying to set up a simple Bootstrap menu it works fine except the Active component doesn't work. Meaning, when I load the page into a browser, I can click on the various links in my menu and the browser will take me there, but the "Active" display doesn't change. I'm using bootstrap.css, jquery-1.11.2.min and bootstrap.js. I even tried making a fresh HTML page and loading a fresh bootstrap menu into it -- no luck. I'm at my wit's end, so any help will be much appreciated. Here's my code, HTML and CSS.
<!-- Collect the nav links, forms, and other content for toggling -->
<div class="collapse navbar-collapse" id="defaultNavbar1">
<ul class="nav navbar-nav">
<li class="active">
<a href="inside_page_1.html">Inside Page 1<span class="sr-only">(current)</span></a>
</li>
<li><a href="inside_page_2.html">Inside Page 2</a></li>
<li class="dropdown"><a href="#" class="dropdown-toggle" data-toggle="dropdown" role="button" aria-expanded="false">Dropdown<span class="caret"></span></a>
<ul class="dropdown-menu" role="menu">
<li><a href="#">Action</a></li>
<li><a href="#">Another action</a></li>
<li><a href="#">Something else here</a></li>
<li class="divider"></li>
<li><a href="#">Separated link</a></li>
<li><a href="#">One more separated link</a></li>
</ul>
</li>
</ul>
.navbar-default .navbar-nav > .active > a,
.navbar-default .navbar-nav > .active > a:hover,
.navbar-default .navbar-nav > .active > a:focus {
color: #00B309;
background-color: #FF0004;
It does work if you manually change the location of the active class on each page's menu.
Or you can do it with pure CSS code
Persistent Page Indicator on Menus - http://alt-web.com/
Or do it with JQuery code.
<script>
$(".nav a").on("click", function(){
$(".nav").find(".active").removeClass("active");
$(this).parent().addClass("active");
</script>
Nancy O.
<script>
</script>
Nancy O.
Thanks Nancy O, You have saved my sanity. Thanks especially for giving me 3 methods. I'll do it manually for now because I don't have a lot of pages, but it's great to know the two other methods are there.
Persistent menu highlighting is important when using server-side includes for site wide nav. And I use SSIs on 5 page sites as well as 50 pages sites.
Nancy O.
