3 Replies Latest reply on Oct 24, 2015 11:47 AM by Rick Gerard
    I'm trying to export a video from a DNG sequence.
    simonestaddei
      I recorded a 14 seconds RAW video with a Canon 70D and Magic Lantern latest firmware with a risolution a little lower then 1920x1080 at 30fps. I converted this RAW file in a DNG sequence and then i imported it in AE.
      After set the framerate to 30fps (as recorded) i take a look at the preview; first seconds are fluid and fine then the video starts to be played too fast till the end.
      I tried to export an avi and the problem still exists.
      I even tried to set different framerate (24,23,25) bu nothing change.
      Where am I wrong?
        • 1. Re: I'm trying to export a video from a DNG sequence.
          It's impossible to know whats going on without more details about your workflow. If you import an image sequence, then check the file interpretation to make sure the frame rate is correct, then you create a new comp from the footage and render the comp using any of the standard output module or AME templates your video will be rendered at the same frame rate as the composition.
          If your comp plays back at a constant frame rate as indicated by the info panel but the action speeds up then there is a problem with your original footage. AE will not drop frames or change the timing between frames unless you tell it to do so with one of the time effects. When the video seems to speed up check the movement between frames and see if the motion stays constant by stepping through the comp one frame at a time. I'm just guessing here but I suspect that the camera slowed down as the video was being recorded and the time between each frame changed while you were shooting. I am guessing that Magic Lantern was running into frame buffer problems or write speed problems so the frame rate decreased as more time passed.
          • 2. Re: I'm trying to export a video from a DNG sequence.
            simonestaddei Level 1
            First of all thank you!
            As i come back home i try to put in act your tips.
            Meanwhile I can tell you that i made other 3 video with the same prcedure and same duration and I encounter the same identical problem.
            Could be a problem I'm shooting in NTSC?
