6 Replies Latest reply on Oct 30, 2015 7:04 PM by shawncolborn
    I'm still having performance issues on my Mac
    shawncolborn Level 1
      Hello,
      I've downloaded the update for Lightroom CC 2015 and I'm still having issues with slow performance and the app crashing requiring a "Force Quit". I'm having no problems with Photoshop CC 2015 or ACR. Adjustment are made quickly with minimal lag time. Here is my system profile.
      Lightroom version: CC 2015.2.1 [ 1046594 ]
      License: Creative Cloud
      Operating system: Mac OS 10
      Version: 10.9 [5]
      Application architecture: x64
      Logical processor count: 2
      Processor speed: 2.0 GHz
      Built-in memory: 4,096.0 MB
      Real memory available to Lightroom: 4,096.0 MB
      Real memory used by Lightroom: 1,114.3 MB (27.2%)
      Virtual memory used by Lightroom: 2,133.2 MB
      Memory cache size: 252.1 MB
      Maximum thread count used by Camera Raw: 2
      Camera Raw SIMD optimization: SSE2
      Displays: 1) 1680x1050, 2) 1024x768
      Graphics Processor Info:
      ATI Radeon HD 2400 XT OpenGL Engine
      Check OpenGL support: Passed
      Vendor: ATI Technologies Inc.
      Version: 3.3 ATI-8.24.17
      Renderer: ATI Radeon HD 2400 XT OpenGL Engine
      LanguageVersion: 3.30
      Application folder: /Applications/Adobe Lightroom
      Library Path: /Volumes/LaCie/Lightroom/Lightroom Catalog.lrcat
      Settings Folder: /Users/shawncolborn/Library/Application Support/Adobe/Lightroom
      Installed Plugins:
      1) Aperture/iPhoto Importer Plug-in
      2) Canon Print Studio Pro
      3) DxO FilmPack 3
      4) DxO FilmPack 3 (64-bit)
      5) Facebook
      6) Flickr
      7) HDR Efex Pro 2
      8) jf PicasaWeb
      Config.lua flags: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Built-in Output
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 8192
      GL_MAX_TEXTURE_SIZE: 8192
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 8192,8192
      GL_RED_BITS: 8
      GL_RENDERER: ATI Radeon HD 2400 XT OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: ATI Technologies Inc.
      GL_VERSION: 2.1 ATI-8.24.17
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
      Here is one of the system reports:
      Date/Time:       2015-10-21 19:35:41 -0400
      OS Version:      10.9.5 (Build 13F1112)
      Architecture:    x86_64
      Report Version:  18
      Command:         Lightroom
      Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
      Version:         Adobe Lightroom [1046594] (6.2.1)
      Parent:          launchd [181]
      PID:             253
      Event:           hang
      Duration:        1.27s
      Steps:           12 (100ms sampling interval)
      Hardware model:  iMac7,1
      Active cpus:     2
      Fan speed:       999 rpm
      Free pages:      12228 pages (-2600)
      Pageins:         107 pages
      Pageouts:        0 pages
      Swapins:         0 pages
      Swapouts:        0 pages
      Process:         Adobe Lightroom [253]
      UID:             501
      Task size:       300312 pages (+7)
      CPU Time:        0.581s
      Note:            Suspended for 5 samples
        Thread 0x864      DispatchQueue 1          priority    0-45   cpu time   0.580s
        12 start + 1 (libdyld.dylib) [0x7fff8b8f65fd]
          12 main + 953 (Adobe Lightroom) [0x106f779a9]
            12 NSApplicationMain + 940 (AppKit) [0x7fff82c67783]
              12 -[NSApplication run] + 646 (AppKit) [0x7fff82c7c9f9]
                12 ??? (AgUI + 477582) [0x10706098e]
                  12 -[NSApplication sendEvent:] + 2021 (AppKit) [0x7fff82e2c5d4]
                    12 ??? (AgUI + 171047) [0x107015c27]
                      12 -[NSWindow sendEvent:] + 11296 (AppKit) [0x7fff82e8da58]
                        12 ??? (AgUI + 156040) [0x107012188]
                          12 ??? (AgUI + 154619) [0x107011bfb]
                            12 ??? (AgUI + 150509) [0x107010bed]
                              12 lua_call + 37 (AgKernel) [0x106f94f36]
                                12 ??? (AgKernel + 40781) [0x106f9cf4d]
                                  12 ??? (AgKernel + 100791) [0x106fab9b7]
                                      12 ??? (AgKernel + 98947) [0x106fab283]
                                        12 ??? (AgKernel + 40079) [0x106f9cc8f]
                                          12 ??? (AgSubstrate + 9486) [0x1070fa50e]
                                              12 ??? (AgKernel + 40764) [0x106f9cf3c]
                                                  12 ??? (AgUI + 161700) [0x1070137a4]
                                                            12 ??? (AgSubstrate + 9606) [0x1070fa586]
                                                              12 lua_pcall + 100 (AgKernel) [0x106f94fb7]
        12 ??? (AgKernel + 41380) [0x106f9d1a4]
        12 ??? (AgKernel + 38378) [0x106f9c5ea]
        12 callObjectSelectorWithLuaStateStartingAtIndex + 304 (AgSubstrate) [0x107114896]
        12 -[NSInvocation invokeWithTarget:] + 54 (CoreFoundation) [0x7fff8869c466]
        12 -[NSInvocation invoke] + 308 (CoreFoundation) [0x7fff885f9814]
        12 __invoking___ + 140 (CoreFoundation) [0x7fff885f99ac]
        12 ??? (AgUI + 428904) [0x107054b68]
        12 ??? (AgUI + 428729) [0x107054ab9]
        12 ??? (AgUI + 427568) [0x107054630]
        12 ??? (AgUI + 426748) [0x1070542fc]
        12 ??? (AgUI + 435572) [0x107056574]
        12 ??? (AgUI + 446206) [0x107058efe]
        12 -[NSView addSubview:] + 364 (AppKit) [0x7fff82c9d7d4]
        12 -[NSView _setWindow:] + 2899 (AppKit) [0x7fff82ca0190]
        12 ??? (AgUI + 399100) [0x10704d6fc]
        12 ??? (AgUI + 180312) [0x107018058]
        12 ??? (AgUI + 398825) [0x10704d5e9]
        12 ??? (AgUI + 178410) [0x1070178ea]
        12 ??? (AgUI + 174353) [0x107016911]
        12 ??? (AgUI + 174900) [0x107016b34]
        12 -[NSWindow setContentView:] + 511 (AppKit) [0x7fff82cbfc65]
        12 -[NSView _setWindow:] + 2850 (AppKit) [0x7fff82ca015f]
        12 __21-[NSView _setWindow:]_block_invoke712 + 231 (AppKit) [0x7fff833e3c72]
        12 -[__NSArrayM enumerateObjectsWithOptions:usingBlock:] + 319 (CoreFoundation) [0x7fff88641a9f]
        12 __53-[__NSArrayM enumerateObjectsWithOptions:usingBlock:]_block_invoke + 137 (CoreFoundation) [0x7fff886422f9]
        12 -[NSScrollView _setWindow:] + 222 (AppKit) [0x7fff82ce4e9d]
        9  -[NSView _setWindow:] + 2850 (AppKit) [0x7fff82ca015f]
        9  __21-[NSView _setWindow:]_block_invoke712 + 231 (AppKit) [0x7fff833e3c72]
        9  -[__NSArrayM enumerateObjectsWithOptions:usingBlock:] + 319 (CoreFoundation) [0x7fff88641a9f]
        9  __53-[__NSArrayM enumerateObjectsWithOptions:usingBlock:]_block_invoke + 137 (CoreFoundation) [0x7fff886422f9]
        7  -[NSButton _setWindow:] + 48 (AppKit) [0x7fff82cb1c9e]
        7  -[NSControl _setWindow:] + 154 (AppKit) [0x7fff82cb1de5]
        7  -[NSView _setWindow:] + 2899 (AppKit) [0x7fff82ca0190]
        7  ??? (AgUI + 222007) [0x107022337]
        7  ??? (AgUI + 230541) [0x10702448d]
        7  +[NSObject(NSDelayedPerforming) cancelPreviousPerformRequestsWithTarget:selector:object:] + 598 (Foundation) [0x7fff8a3c35a0]
        7  CFRunLoopRemoveTimer + 343 (CoreFoundation) [0x7fff886707c7]
        7  CFSetApplyFunction + 173 (CoreFoundation) [0x7fff8861e33d]
        7  CFBasicHashApply + 124 (CoreFoundation) [0x7fff886028fc]
        7  __CFSetApplyFunction_block_invoke + 18 (CoreFoundation) [0x7fff8861e382]
        7  CFRunLoopRemoveTimer + 154 (CoreFoundation) [0x7fff8867070a]
        5  CFArrayGetFirstIndexOfValue + 211 (CoreFoundation) [0x7fff885d8de3]
        4  CFArrayGetValueAtIndex + 108 (CoreFoundation) [0x7fff885ec39c]
        *4  special_handler_continue + 0 (mach_kernel) [0xffffff80002489b0]
        *4  <suspended>
        1  CFArrayGetValueAtIndex + 122 (CoreFoundation) [0x7fff885ec3aa]
        1  <executing in user space>
        1  CFArrayGetFirstIndexOfValue + 244 (CoreFoundation) [0x7fff885d8e04]
        1  CFArrayGetValueAtIndex + 205 (CoreFoundation) [0x7fff885ec3fd]
        *1  special_handler_continue + 0 (mach_kernel) [0xffffff80002489b0]
        2  -[NSControl _setWindow:] + 154 (AppKit) [0x7fff82cb1de5]
        2  ??? (AgUI + 222007) [0x107022337]
        2  ??? (AgUI + 230541) [0x10702448d]
        2  +[NSObject(NSDelayedPerforming) cancelPreviousPerformRequestsWithTarget:selector:object:] + 598 (Foundation) [0x7fff8a3c35a0]
        2  CFRunLoopRemoveTimer + 343 (CoreFoundation) [0x7fff886707c7]
        2  CFSetApplyFunction + 173 (CoreFoundation) [0x7fff8861e33d]
        2  CFBasicHashApply + 124 (CoreFoundation) [0x7fff886028fc]
        2  __CFSetApplyFunction_block_invoke + 18 (CoreFoundation) [0x7fff8861e382]
        2  CFRunLoopRemoveTimer + 154 (CoreFoundation) [0x7fff8867070a]
        1  containsKey + 16 (CoreFoundation) [0x7fff885ec330]
        1  CFArrayGetFirstIndexOfValue + 211 (CoreFoundation) [0x7fff885d8de3]
        1  CFArrayGetValueAtIndex + 108 (CoreFoundation) [0x7fff885ec39c]
        3  -[NSView _setWindow:] + 2899 (AppKit) [0x7fff82ca0190]
        3  ??? (AgUI + 222007) [0x107022337]
        3  ??? (AgUI + 230541) [0x10702448d]
        3  +[NSObject(NSDelayedPerforming) cancelPreviousPerformRequestsWithTarget:selector:object:] + 598 (Foundation) [0x7fff8a3c35a0]
        3  CFRunLoopRemoveTimer + 343 (CoreFoundation) [0x7fff886707c7]
        3  CFSetApplyFunction + 173 (CoreFoundation) [0x7fff8861e33d]
        3  CFBasicHashApply + 124 (CoreFoundation) [0x7fff886028fc]
        3  __CFSetApplyFunction_block_invoke + 18 (CoreFoundation) [0x7fff8861e382]
        3  CFRunLoopRemoveTimer + 154 (CoreFoundation) [0x7fff8867070a]
        3  CFArrayGetFirstIndexOfValue + 211 (CoreFoundation) [0x7fff885d8de3]
        2  CFArrayGetValueAtIndex + 39 (CoreFoundation) [0x7fff885ec357]
        2  <executing in user space>
        1  CFArrayGetValueAtIndex + 24 (CoreFoundation) [0x7fff885ec348]
        Thread 0x8dc      DispatchQueue 2          priority 49
        12 _dispatch_mgr_thread + 52 (libdispatch.dylib) [0x7fff8f0a8136]
          12 kevent64 + 10 (libsystem_kernel.dylib) [0x7fff885b6662]
           *9  ??? (mach_kernel + 3963520) [0xffffff80005c7a80]
             *2  <suspended>
           *3  special_handler_continue + 0 (mach_kernel) [0xffffff80002489b0]
             *3  <suspended>
        Thread 0xb2d      priority 47
        12 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff885b5716]
         *12 psynch_cvcontinue + 0 (pthread) [0xffffff7f80bcf940]
           *5  <suspended>
        Thread 0xbb4      priority 47
        12 thread_start + 13 (libsystem_pthread.dylib) [0x7fff824aefc9]
          12 _pthread_start + 137 (libsystem_pthread.dylib) [0x7fff824aa72a]
            12 _pthread_body + 138 (libsystem_pthread.dylib) [0x7fff824aa899]
              12 __NSThread__main__ + 1318 (Foundation) [0x7fff8a3e5d8b]
                12 ??? (AgSubstrate + 80889) [0x10710bbf9]
                              12 AgLua_callWithAutoReleasePool + 85 (AgSubstrate) [0x10711810b]
                                        12 ??? (AgKernel + 136110) [0x106fb43ae]
                                          12 AgTransitQueue_dequeueToLuaState + 91 (AgKernel) [0x106fb3478]
                                            12 AgConditionLock_wait + 37 (AgKernel) [0x106fb99d5]
                                                 *5  <suspended>
        Thread 0xcbd      priority 47
                                      12 ??? (AgKernel + 16742) [0x106f97166]
        *5  <suspended>
        Thread 0x177e     priority 47         cpu time   0.001s
              12 _NSEventThread + 144 (AppKit) [0x7fff82e2905e]
                12 CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff8862fe75]
                  6  __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
                    6  __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
                      6  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
                       *6  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
                  6  __CFRunLoopRun + 1830 (CoreFoundation) [0x7fff886307d6]
                    6  __CFRunLoopDoSource1 + 478 (CoreFoundation) [0x7fff8863f79e]
                      6  __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff8863f829]
                        6  __CFMachPortPerform + 388 (CoreFoundation) [0x7fff8863f9c4]
                          6  MessageHandler(__CFMachPort*, void*, long, void*) + 51 (HIToolbox) [0x7fff8da566c6]
                            6  PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 518 (HIToolbox) [0x7fff8da568fe]
                              6  CFRunLoopPerformBlock + 108 (CoreFoundation) [0x7fff8861cf4c]
                                6  __psynch_mutexwait + 10 (libsystem_kernel.dylib) [0x7fff885b5746]
                                 *6  psynch_mtxcontinue + 0 (pthread) [0xffffff7f80bcea3b]
                                   *4  <suspended>
        Thread 0x1787     priority 44
           *5  <suspended>
        Thread 0x1788     priority 44
           *5  <suspended>
        Thread 0x178d     priority 47
              12 vcfoundation::thread::Thread::ThreadProc(void*) + 9 (VulcanMessage5.dylib) [0x1155a3e09]
                12 vcfoundation::thread::AbstractThread::Run() + 50 (VulcanMessage5.dylib) [0x1155a22e8]
                  12 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 995 (VulcanMessage5.dylib) [0x1155949c1]
                    12 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50 (VulcanMessage5.dylib) [0x115593f46]
                      12 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29 (VulcanMessage5.dylib) [0x1155a10bd]
                        12 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166 (VulcanMessage5.dylib) [0x1155a116a]
                          12 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37 (VulcanMessage5.dylib) [0x1155a14e9]
                            12 vcfoundation::ncomm::Connection::ReadIn() + 22 (VulcanMessage5.dylib) [0x1155a17c2]
                              12 vcfoundation::io::Serializer::Deserialize() + 9 (VulcanMessage5.dylib) [0x11559d93d]
                                12 vcfoundation::io::Serializer::InternalDeserialize() + 30 (VulcanMessage5.dylib) [0x11559d996]
                                  12 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46 (VulcanMessage5.dylib) [0x11559d4f8]
                                    12 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50 (VulcanMessage5.dylib) [0x1155a294e]
                                      12 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82 (VulcanMessage5.dylib) [0x1155a2a18]
                                        12 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21 (VulcanMessage5.dylib) [0x1155a365d]
                                          12 __recvfrom + 10 (libsystem_kernel.dylib) [0x7fff885b591a]
                                           *12 hndl_unix_scall64 + 22 (mach_kernel) [0xffffff80002f4c86]
                                             *12 unix_syscall64 + 499 (mach_kernel) [0xffffff8000641a23]
                                               *12 recvfrom_nocancel + 224 (mach_kernel) [0xffffff80006237f0]
                                                 *12 ??? (mach_kernel + 4340158) [0xffffff80006239be]
                                                   *12 soreceive + 2306 (mach_kernel) [0xffffff80006185e2]
                                                     *12 sbwait + 297 (mach_kernel) [0xffffff800061e4e9]
                                                       *12 msleep + 114 (mach_kernel) [0xffffff80005e4e32]
                                                         *12 ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
                                                           *12 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
                                                             *12 thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
                                                               *12 ??? (mach_kernel + 224459) [0xffffff8000236ccb]
        *12 machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
        *5  <suspended>
        Thread 0x17aa     priority 47
                                            12 AgConditionLock_wait + 182 (AgKernel) [0x106fb9a66]
                                                 *5  <suspended>
        Thread 0x1813     priority 47
        12 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
         *12 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
           *5  <suspended>
        Thread 0x19d6     priority 47
        12 __select + 10 (libsystem_kernel.dylib) [0x7fff885b59aa]
         *12 ??? (mach_kernel + 4083744) [0xffffff80005e5020]
           *5  <suspended>
        Thread 0x1a00     priority 38
                                                 *5  <suspended>
        Thread 0x1aad     priority 47
           *5  <suspended>
        Thread 0x1aaf     priority 47
           *5  <suspended>
        Thread 0x1ab0     priority 47
           *5  <suspended>
        Thread 0x1ab1     priority 47
           *5  <suspended>
        Thread 0x1ab2     priority 47
           *5  <suspended>
        Thread 0x1ab3     priority 47
           *5  <suspended>
        Thread 0x1ab4     priority 47
           *5  <suspended>
        Thread 0x1bda     priority 47
              12 boost::(anonymous namespace)::thread_proxy(void*) + 138 (LogSession) [0x1168f6bfa]
                12 RealTimeProcessor::WorkerThread() + 2157 (LogSession) [0x11689ed9d]
                  12 RealTimeProcessor::Sleep(int) + 243 (LogSession) [0x1168a0911]
                    12 boost::this_thread::hiden::sleep_until(timespec const&) + 78 (LogSession) [0x1168f7b9e]
                      12 boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76 (LogSession) [0x1168f92dc]
                           *5  <suspended>
        Thread 0x1fd7     priority 45
        *5  <suspended>
        Thread 0x1fe2     priority 44
           *5  <suspended>
        Thread 0x202d     priority 47
           *5  <suspended>
        Thread 0x202e     priority 47
              12 ??? (CameraRaw + 1758529) [0x10a838541]
                12 ??? (CameraRaw + 238226) [0x10a6c5292]
                  12 ??? (CameraRaw + 1981771) [0x10a86ed4b]
                       *5  <suspended>
        Thread 0xa057     priority 47
           *5  <suspended>
        Thread 0xa058     priority 47
           *5  <suspended>
        Thread 0xa059     priority 47
           *5  <suspended>
        Thread 0xa05a     priority 47
           *5  <suspended>
        Thread 0xa05b     priority 47
           *5  <suspended>
        Thread 0xa05c     priority 47
           *5  <suspended>
        Thread 0xdbbe     priority 47
        12 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          12 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *12 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
             *5  <suspended>
        Thread 0xdca4     priority 0
        3 __pthread_set_self + 16 (libsystem_pthread.dylib) [0x7fff824aefac]
         *3 wq_unsuspend_continue + 0 (pthread) [0xffffff7f80bcd7c4]
        3 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          3 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *3 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Binary Images:
               0x106f76000 -        0x106f84fff  com.adobe.Lightroom6 Adobe Lightroom [1046594] (6.2.1) <C6DBCD5E-A85F-3ABF-8A73-72BBCAC34F68> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
               0x106f93000 -        0x106fd4fff  com.adobe.ag.kernel AgKernel Version 1.0 (1.0) <D04B5F34-3399-3B56-A293-4DCFE509A4EC> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgKernel.framework/Versions/A/AgKernel
               0x106fec000 -        0x1070affff  com.adobe.ag.ui views version 0.0.1d1 <E62658C1-629F-328E-8D83-658BBB1B11B4> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgUI.framework/Versions/A/AgUI
               0x1070f8000 -        0x107140ff7  com.adobe.ag.substrate com.adobe.ag.substrate 6.2.1 (1.0) <8F46D612-9B18-3030-A2F4-C2B0B9CBF054> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AgSubstrate.framework/Versions/A/AgSubstrate
               0x10a68b000 -        0x10cdb1fff  com.adobe.ag.AgImageIO com.adobe.ag.AgImageIO 6.2.1 (1.0.0d1) <596CEB21-63B8-3949-8D3C-F9D02592E255> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/CameraRaw.lrtoolkit/CameraRaw
               0x115586000 -        0x1155befff  VulcanMessage5.dylib (1) <490958A0-D98D-34D8-872D-01B21AC279D8> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/VulcanMessaging.framework/Versions/A/VulcanMessage5.dyl ib
               0x116815000 -        0x116951fff  com.adobe.headlights.LogSessionFramework (7.3.1.61) <D633CDB7-C235-328A-98E5-11FE46B3D179> /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/LogSession.framework/LogSession
            0x7fff824a9000 -     0x7fff824b0ff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
            0x7fff82c65000 -     0x7fff837dbff7  com.apple.AppKit 6.9 (1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0x7fff885a0000 -     0x7fff885bcff7  libsystem_kernel.dylib (2422.115.14) <8116098D-B3F1-3E50-A934-576DD6369234> /usr/lib/system/libsystem_kernel.dylib
            0x7fff885c0000 -     0x7fff887a5fff  com.apple.CoreFoundation 6.9 (855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x7fff8a37f000 -     0x7fff8a67fff7  com.apple.Foundation 6.9 (1056.17) <E0B0FAF6-5CA8-3EEB-8BF2-104C0AEEF925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0x7fff8b8f3000 -     0x7fff8b8f6ff7  libdyld.dylib (239.4) <7C9EC3B7-DDE3-33FF-953F-4067C743951D> /usr/lib/system/libdyld.dylib
            0x7fff8da20000 -     0x7fff8dccaff5  com.apple.HIToolbox 2.1.1 <A388E773-AE7B-3FD1-8662-A98E6E24EA16> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x7fff8f0a5000 -     0x7fff8f0bffff  libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib
      *0xffffff7f80bca000 - 0xffffff7f80bd1fff  com.apple.kec.pthread 1.0 (1) <882075E6-12C4-3225-8750-928715183739> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
      *0xffffff8000200000 - 0xffffff80007aa29a  mach_kernel (2422.115.14) <8B1A8FD1-2344-36C0-A7F5-D9D485A995FA> /mach_kernel
      Process:         accountsd [212]
      Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
      UID:             501
      Sudden Term:     Clean (allows idle exit)
      Task size:       324 pages (+2)
      Importance:      Adaptive, Background Priority
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x6d5      DispatchQueue 1          priority 4
        Thread 0x6d7      DispatchQueue 2          priority 4
           *12 ??? (mach_kernel + 3963520) [0xffffff80005c7a80]
        Thread 0x5afd     priority 4
        Thread 0xdc9c     priority 4
        9 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          9 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *9 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Binary Images:
               0x10877e000 -        0x10877ffff  accountsd (336.9) <806AD9DD-23C7-3DB5-BE2F-C3E4D3E27EA9> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
      Process:         Adobe CEF Helper [518]
      Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
      Architecture:    i386
      Parent:          Creative Cloud [359]
      Responsible:     Creative Cloud [359]
      UID:             501
      Task size:       3611 pages
      CPU Time:        0.003s
      Importance:      Donating
      IO Policy:       Standard
      Process:         Adobe CEF Helper [523]
      Architecture:    i386
      UID:             501
      Task size:       979 pages (+2)
      IO Policy:       Standard
      Process:         Adobe CEF Helper [529]
      Architecture:    i386
      UID:             501
      Task size:       1568 pages (+2)
      CPU Time:        0.010s
      IO Policy:       Standard
      Process:         Adobe Desktop Service [520]
      Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
      Architecture:    i386
      UID:             501
      Task size:       984 pages
      Process:         AdobeCrashDaemon [287]
      Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemo n.app/Contents/MacOS/AdobeCrashDaemon
      Architecture:    unknown
      Parent:          Adobe Lightroom [253]
      Responsible:     Adobe Lightroom [253]
      UID:             501
      Task size:       253 pages
      CPU Time:        0.003s
      Process:         AdobeCrashDaemon [530]
      Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemon.app /Contents/MacOS/AdobeCrashDaemon
      Parent:          Core Sync [527]
      Responsible:     Core Sync [527]
      UID:             501
      Task size:       254 pages
      CPU Time:        0.003s
      Process:         AdobeIPCBroker [501]
      Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
      Architecture:    i386
      Parent:          launchd [1]
      UID:             501
      Task size:       422 pages
      Process:         AdobeUpdateDaemon [68]
      Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
      Architecture:    i386
      Parent:          launchd [1]
      UID:             0
      Task size:       65 pages (+2)
      CPU Time:        0.001s
      IO Policy:       Standard
      Timers:          Coalesced
      Process:         airportd [62]
      Path:            /usr/libexec/airportd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       485 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x14f      DispatchQueue 1          priority 4
          12 ??? (airportd + 85556) [0x105054e34]
            12 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff8a4d0aca]
              12 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 253 (Foundation) [0x7fff8a3e80fc]
                  12 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
                    12 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
        Thread 0x3ce      DispatchQueue 2          priority 4
          12 _dispatch_mgr_invoke + 177 (libdispatch.dylib) [0x7fff8f0a83e3]
            12 __select_nocancel + 10 (libsystem_kernel.dylib) [0x7fff885b59c2]
        Thread 0x3d2      priority 4
        Thread 0xdca0     priority 4
        Binary Images:
               0x105040000 -        0x1050afff7  airportd (940.60) <0329604B-D65F-3571-BBC5-7ABF6CC80101> /usr/libexec/airportd
      Process:         aksusbd [66]
      Path:            /usr/libexec/aksusbd
      Architecture:    i386
      Parent:          launchd [1]
      UID:             0
      Task size:       64 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x153      priority 31
        12 __select + 10 (libsystem_kernel.dylib) [0x9a117ace]
        Thread 0x1cf      DispatchQueue 2696358572 priority 33
        12 _dispatch_mgr_thread + 52 (libdispatch.dylib) [0x9756f532]
          12 kevent64 + 10 (libsystem_kernel.dylib) [0x9a118992]
        Thread 0x1cc      priority 31
        12 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x9a112fb6]
         *12 semaphore_wait_continue + 0 (mach_kernel) [0xffffff800023b8e0]
        Thread 0x1cd      priority 31
        12 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x9a112f7a]
        Thread 0xdc97     priority 31
        9 start_wqthread + 30 (libsystem_pthread.dylib) [0x90c3ecce]
          9 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x9a118046]
        Binary Images:
                    0x1000 -            0x14ff7  aksusbd <15FF8D9D-257A-5B4A-F219-64E82453DFC5> /usr/libexec/aksusbd
                0x90c38000 -         0x90c3fffb  libsystem_pthread.dylib (53.1.4) <8B1B7B84-1B5D-32A8-AC0D-1E689E5C8A4C> /usr/lib/system/libsystem_pthread.dylib
                0x9756c000 -         0x97584ffd  libdispatch.dylib (339.92.1) <7E7A88BF-74B3-363B-B534-6F757DF2DDE3> /usr/lib/system/libdispatch.dylib
                0x9a100000 -         0x9a11dff4  libsystem_kernel.dylib (2422.115.14) <E6E6967B-23CB-3FED-982E-3C63338C9278> /usr/lib/system/libsystem_kernel.dylib
      Process:         Amazon Music Helper [361]
      Path:            /Applications/Amazon Music.app/Contents/MacOS/Amazon Music Helper
      Architecture:    i386
      UID:             501
      Task size:       59 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
      Process:         Android File Transfer Agent [371]
      Path:            /Users/USER/Library/Application Support/Google/*/Android File Transfer Agent.app/Contents/MacOS/Android File Transfer Agent
      Architecture:    i386
      UID:             501
      Task size:       59 pages (+3)
      Timers:          Coalesced
      Process:         aosnotifyd [61]
      Path:            /usr/libexec/aosnotifyd
      Parent:          launchd [1]
      UID:             0
      Task size:       139 pages (+2)
      Importance:      Adaptive, Boosted
      Timers:          Coalesced
        Thread 0x14e      DispatchQueue 1          priority 31
          12 ??? (aosnotifyd + 61205) [0x103fcaf15]
            12 ??? (aosnotifyd + 173664) [0x103fe6660]
        Thread 0x3b1      DispatchQueue 2          priority 33
        Thread 0xdc8f     priority 31
        Binary Images:
               0x103fbc000 -        0x10401afff  aosnotifyd (760.4) <CA430D31-B9A3-3262-9A74-D517E193B2B2> /usr/libexec/aosnotifyd
      Process:         appleeventsd [52]
      Path:            /System/Library/CoreServices/appleeventsd
      Parent:          launchd [1]
      UID:             55
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x228      DispatchQueue 2          priority 4
        Thread 0x229      DispatchQueue 7          priority 4
        12 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff885b5caa]
        Binary Images:
               0x100e22000 -        0x100e22ffe  appleeventsd (665.6) <FA960DFA-28C1-3A24-8FB2-7DC3B8E2738D> /System/Library/CoreServices/appleeventsd
      Process:         apsd [60]
      Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
      Parent:          launchd [1]
      UID:             0
      Task size:       614 pages (+2)
      Importance:      Adaptive, Donating
      Timers:          Coalesced
        Thread 0x14d      DispatchQueue 1          priority 31
          12 ??? (apsd + 211338) [0x10637098a]
        Thread 0x355      DispatchQueue 2          priority 33
        Thread 0x3f5      priority 63
        Thread 0x4b7      priority 31
        Thread 0xdc80     priority 31
        Binary Images:
               0x10633d000 -        0x1063d1fff  apsd (206.2) <6F36B882-4D77-34A8-8BB4-1300962DE3F4> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
      Process:         auditd [1787]
      Path:            /usr/sbin/auditd
      Parent:          launchd [1]
      UID:             0
      Task size:       240 pages
      IO Policy:       Standard
      Timers:          Coalesced
      Note:            Exited before symbolication
        Thread 0xd94c     DispatchQueue 1          priority 31
        12 ??? [0x7fff8b8f65fd]
          12 ??? [0x10dbc0ccd]
            12 ??? [0x7fff885b1576]
              12 ??? [0x7fff885b1a1a]
        Thread 0xd953     DispatchQueue 2          priority 33
        12 ??? [0x7fff8f0a8136]
          12 ??? [0x7fff885b6662]
        Binary Images:
      Process:         authd [107]
      Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty (allows idle exit)
      Task size:       654 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x301      priority 4
        Thread 0x302      DispatchQueue 2          priority 4
        Thread 0x303      DispatchQueue 6          priority 4
          12 _pthread_wqthread + 314 (libsystem_pthread.dylib) [0x7fff824abef8]
            12 _dispatch_worker_thread2 + 40 (libdispatch.dylib) [0x7fff8f0a9177]
              12 _dispatch_root_queue_drain + 326 (libdispatch.dylib) [0x7fff8f0a8082]
                12 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8f0a628d]
                  12 _dispatch_call_block_and_release + 12 (libdispatch.dylib) [0x7fff8f0a91bb]
                    12 ??? (authd + 73564) [0x10e507f5c]
                      12 au_sdev_read_aia + 570 (libbsm.0.dylib) [0x7fff8a68eac5]
                        12 fgetc + 44 (libsystem_c.dylib) [0x7fff8bda468e]
                          12 __srget + 14 (libsystem_c.dylib) [0x7fff8bdaaff5]
                            12 __srefill1 + 24 (libsystem_c.dylib) [0x7fff8bdaaedb]
                              12 __read_nocancel + 10 (libsystem_kernel.dylib) [0x7fff885b58ea]
                                   *12 read_nocancel + 127 (mach_kernel) [0xffffff80005f2ebf]
                                     *12 ??? (mach_kernel + 4141230) [0xffffff80005f30ae]
                                       *12 ??? (mach_kernel + 2050245) [0xffffff80003f48c5]
                                         *12 VNOP_READ + 225 (mach_kernel) [0xffffff80003fed11]
                                           *12 spec_read + 253 (mach_kernel) [0xffffff800040e0dd]
                                             *12 ??? (mach_kernel + 3850633) [0xffffff80005ac189]
        Thread 0xdb85     priority 4
        Thread 0xdb86     priority 4
        Thread 0xdb87     priority 4
      *12 wq_unsuspend_continue + 0 (pthread) [0xffffff7f80bcd7c4]
        Binary Images:
               0x10e4f6000 -        0x10e50dff3  com.apple.authd 1.0 (55471.14.38) <1104E819-88C4-3415-A468-202702E4E307> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
            0x7fff8a680000 -     0x7fff8a690fff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
            0x7fff8bd68000 -     0x7fff8bdf1ff7  libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
      Process:         autofsd [59]
      Path:            /usr/libexec/autofsd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       58 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x19b      DispatchQueue 2          priority 33
        Thread 0x45a      DispatchQueue 7          priority 31
        Thread 0xdc92     priority 31
        Binary Images:
               0x106683000 -        0x106684fff  autofsd (234) <6536BE49-F3B9-3603-B2C5-1EB34103CF10> /usr/libexec/autofsd
      Process:         backupd [1629]
      Path:            /System/Library/CoreServices/backupd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       6339 pages (+419)
      Pageins:         2 pages
      CPU Time:        0.014s
      Importance:      Background Priority
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xc7fc     DispatchQueue 1          priority 4
          12 ??? [0x1088e194a]
            12 ??? [0x7fff886e5811]
              12 ??? [0x7fff8862fe75]
                12 ??? [0x7fff88630539]
                  12 ??? [0x7fff88630f15]
        Thread 0xc7ff     DispatchQueue 2          priority 4
        Thread 0xc817     DispatchQueue 10         priority    0-46   cpu time   0.014s
        12 ??? [0x7fff824aefb9]
          12 ??? [0x7fff824abef8]
            12 ??? [0x7fff8f0a9177]
              12 ??? [0x7fff8f0a8082]
                12 ??? [0x7fff8f0a628d]
                  12 ??? [0x7fff8f0a91bb]
                    12 ??? [0x1088d7219]
                      12 ??? [0x1088d75c8]
                        12 ??? [0x1088db692]
                         *9  hndl_alltraps + 219 (mach_kernel) [0xffffff80002f438b]
                           *9  user_trap + 748 (mach_kernel) [0xffffff80002dd05c]
                             *8  vm_fault + 6545 (mach_kernel) [0xffffff8000279e41]
                               *8  throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
                                 *8  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
                                   *8  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
                                     *8  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
                                       *8  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
                                         *8  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
                                           *8  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
                             *1  vm_fault + 2660 (mach_kernel) [0xffffff8000278f14]
                               *1  vm_fault_page + 3762 (mach_kernel) [0xffffff8000275652]
                                 *1  apple_protect_pager_data_request + 778 (mach_kernel) [0xffffff80002bd87a]
                                     *1  vnode_pager_data_request + 99 (mach_kernel) [0xffffff800026cd13]
                                       *1  vnode_pager_cluster_read + 68 (mach_kernel) [0xffffff800026d8b4]
                                         *1  vnode_pagein + 380 (mach_kernel) [0xffffff800063b7dc]
                                           *1  VNOP_PAGEIN + 87 (mach_kernel) [0xffffff8000400e17]
                                             *1  hfs_vnop_pagein + 1059 (mach_kernel) [0xffffff8000571c03]
                                               *1  decmpfs_pagein_compressed + 583 (mach_kernel) [0xffffff8000416127]
                                                 *1  ??? (mach_kernel + 2188497) [0xffffff80004164d1]
                                                   *1  vnode_fetch_uncompressed_data_Type4 + 108 (AppleFSCompressionTypeZlib) [0xffffff7f81ff75b4]
                                                     *1  doUncompressType4 + 198 (AppleFSCompressionTypeZlib) [0xffffff7f81ff73f4]
                                                       *1  chunkingDecompressor + 748 (AppleFSCompressionTypeZlib) [0xffffff7f81ff5e9d]
                                                         *1  supplyChunkType4 + 233 (AppleFSCompressionTypeZlib) [0xffffff7f81ff72f2]
                                                           *1  _getxattr + 221 (AppleFSCompressionTypeZlib) [0xffffff7f81ff6a27]
                                                             *1  VNOP_GETXATTR + 80 (mach_kernel) [0xffffff80004010b0]
                                                               *1  hfs_vnop_getxattr + 778 (mach_kernel) [0xffffff800058de0a]
        *1  VNOP_READ + 225 (mach_kernel) [0xffffff80003fed11]
        *1  hfs_vnop_read + 566 (mach_kernel) [0xffffff800056cbb6]
        *1  cluster_read_ext + 5045 (mach_kernel) [0xffffff80003d1ab5]
        *1  ??? (mach_kernel + 1910925) [0xffffff80003d288d]
        *1  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
        *1  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
        *1  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
        *1  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
        *1  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
        *1  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
                          3  ??? [0x1088e2827]
                            3  ??? [0x7fff8a39e4dc]
                              3  ??? [0x7fff885f8932]
                                3  ??? [0x10891f149]
                                 *3  hndl_alltraps + 219 (mach_kernel) [0xffffff80002f438b]
                                   *3  user_trap + 748 (mach_kernel) [0xffffff80002dd05c]
                                     *3  vm_fault + 6545 (mach_kernel) [0xffffff8000279e41]
                                       *3  throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
                                         *3  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
                                           *3  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
                                             *3  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
                                               *3  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
                                                 *3  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
                                                   *3  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
        Thread 0xc805     priority 4
        12 ??? [0x7fff885b1a56]
        Thread 0xdbb6     priority 4
          12 ??? [0x7fff885b5e6a]
        Thread 0xdbb7     priority 4
        Binary Images:
      *0xffffff7f81ff5000 - 0xffffff7f81ff7fff  com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 56.92.2 (1.0.0d1) <C8ECCA9F-9122-33CF-B11C-AD407FBA6D8B> /System/Library/Extensions/AppleFSCompressionTypeZlib.kext/Contents/MacOS/AppleFSCompress ionTypeZlib
      Process:         backupd-helper [1614]
      Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
      Parent:          launchd [1]
      UID:             0
      Task size:       349 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xc579     DispatchQueue 1          priority 4
        Thread 0xc5ba     DispatchQueue 2          priority 4
        Thread 0xc784     DispatchQueue 47         priority 0
        12 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a56]
        Thread 0xdca3     priority 4
        Binary Images:
               0x106f2a000 -        0x106f3cff3  backupd-helper (185) <FFB954F2-4D5B-320C-981D-33CA3E197A64> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
      Process:         BambooCore [363]
      Path:            /Library/Application Support/Wacom/BambooCore.app/Contents/MacOS/BambooCore
      Architecture:    i386
      UID:             501
      Task size:       412 pages
      Process:         blued [56]
      Path:            /usr/sbin/blued
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       317 pages (+2)
      Timers:          Coalesced
        Thread 0x149      DispatchQueue 1          priority 31
          12 ??? (blued + 81560) [0x1048c3e98]
        Thread 0x1ac      DispatchQueue 2          priority 33
        Thread 0x332      priority 31
        Thread 0xdc7c     priority 31
        Binary Images:
               0x1048b0000 -        0x104925fff  blued (4270.4.5) <70D33413-EB5B-3290-983D-D7F01A918E9E> /usr/sbin/blued
      Process:         CalendarAgent [201]
      Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
      UID:             501
      Task size:       2045 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x65f      DispatchQueue 1          priority 4
        Thread 0x664      DispatchQueue 2          priority 4
        Thread 0x6b6      priority 4
        Thread 0x6bd      priority 4
        Thread 0xdc9d     priority 4
        Binary Images:
               0x10dd97000 -        0x10dd97fff  CalendarAgent (176.2) <2FD3C03A-82F7-365A-8D0E-F5FE944D4016> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
      Process:         CCC User Agent [344]
      Path:            /Applications/Carbon Copy Cloner.app/Contents/Library/LoginItems/CCC User Agent.app/Contents/MacOS/CCC User Agent
      UID:             501
      Sudden Term:     Clean
      Task size:       569 pages (+2)
      IO Policy:       Standard
      Process:         cfprefsd [77]
      Path:            /usr/sbin/cfprefsd
      Parent:          launchd [1]
      UID:             0
      Task size:       333 pages (+7)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x1f0      DispatchQueue 2          priority 4
        Thread 0x1f7      DispatchQueue 7          priority 4
        Thread 0xdc70     priority 4
        11 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          11 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *11 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Thread 0xdc71     priority 4
        Thread 0xdc72     priority 4
      *11 wq_unsuspend_continue + 0 (pthread) [0xffffff7f80bcd7c4]
        Binary Images:
               0x10dfb4000 -        0x10dfb4fff  cfprefsd (855.17) <CB068287-D94D-359D-B7C3-068612256CEB> /usr/sbin/cfprefsd
      Process:         cfprefsd [189]
      UID:             501
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x5d5      DispatchQueue 2          priority    4-33
        Thread 0x5d6      DispatchQueue 7          priority    4-31
        Thread 0xdbce     priority    4-31
        Thread 0xdbcf     priority 4
        Thread 0xdc6f     priority    4-31
        Thread 0xdbcf     DispatchQueue 6          priority 46
          1 _pthread_wqthread + 314 (libsystem_pthread.dylib) [0x7fff824abef8]
            1 _dispatch_worker_thread2 + 40 (libdispatch.dylib) [0x7fff8f0a9177]
              1 _dispatch_root_queue_drain + 326 (libdispatch.dylib) [0x7fff8f0a8082]
                1 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8f0a628d]
                  1 _dispatch_call_block_and_release + 12 (libdispatch.dylib) [0x7fff8f0a91bb]
                    1 __90+[CFPDSource withSourceForDomain:forRemoteClient:inContainer:user:byHost:managed:perform:]_block_invok e_2 + 42 (CoreFoundation) [0x7fff8874fc1a]
                      1 __handle_synchronize_message_block_invoke + 215 (CoreFoundation) [0x7fff88758d67]
                        1 -[CFPDSource acceptMessage:] + 673 (CoreFoundation) [0x7fff88751301]
                          1 -[CFPDSource validateMessage:withPlistData:containerPath:diagnosticMessage:] + 180 (CoreFoundation) [0x7fff88750ed4]
                            1 -[CFPDSource propertyList] + 150 (CoreFoundation) [0x7fff88750546]
                              1 __open + 10 (libsystem_kernel.dylib) [0x7fff885b55da]
                               *1 hndl_unix_scall64 + 22 (mach_kernel) [0xffffff80002f4c86]
                                 *1 unix_syscall64 + 499 (mach_kernel) [0xffffff8000641a23]
                                   *1 open + 274 (mach_kernel) [0xffffff80003e8032]
                                     *1 open1 + 309 (mach_kernel) [0xffffff80003e7775]
                                       *1 vn_open_auth + 214 (mach_kernel) [0xffffff80003f5616]
                                         *1 namei + 1460 (mach_kernel) [0xffffff80003d6584]
                                           *1 lookup + 603 (mach_kernel) [0xffffff80003d6c2b]
                                             *1 VNOP_LOOKUP + 75 (mach_kernel) [0xffffff80003fe22b]
                                               *1 hfs_vnop_lookup + 1174 (mach_kernel) [0xffffff800056b466]
                                                 *1 cat_lookup + 164 (mach_kernel) [0xffffff800055b174]
                                                   *1 ??? (mach_kernel + 3519665) [0xffffff800055b4b1]
                                                     *1 BTSearchRecord + 325 (mach_kernel) [0xffffff80005921c5]
                                                       *1 SearchTree + 115 (mach_kernel) [0xffffff8000596073]
                                                         *1 GetNode + 44 (mach_kernel) [0xffffff800059504c]
                                                           *1 GetBTreeBlock + 178 (mach_kernel) [0xffffff8000559222]
                                                             *1 buf_biowait + 122 (mach_kernel) [0xffffff80003c86aa]
        Binary Images:
               0x10d536000 -        0x10d536fff  cfprefsd (855.17) <CB068287-D94D-359D-B7C3-068612256CEB> /usr/sbin/cfprefsd
      Process:         com.apple.audio.SandboxHelper [1774]
      Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
      Parent:          launchd [1]
      Responsible:     coreaudiod [259]
      UID:             202
      Task size:       1101 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xd8fc     DispatchQueue 7          priority 4
        12 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff8f0b07c5]
        Thread 0xd91f     DispatchQueue 2          priority 4
        Binary Images:
               0x108e71000 -        0x108e78ff7  com.apple.audio.SandboxHelper 1.0.1 (1) <FB9D7F77-E66F-39A1-8C9C-6382C6E3D9A8> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
      Process:         com.apple.CodeSigningHelper [1769]
      Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
      Parent:          launchd [1]
      UID:             0
      Task size:       1095 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xd711     DispatchQueue 7          priority 4
        Thread 0xd713     DispatchQueue 2          priority 4
        Binary Images:
               0x10642d000 -        0x10642dff7  com.apple.CodeSigningHelper 1.0 (1) <CCFDAE52-F756-3DB7-BA6D-3353F3115496> /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
      Process:         com.apple.dock.extra [314]
      Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
      Parent:          launchd [1]
      Responsible:     Dock [256]
      UID:             501
      Task size:       637 pages
        Thread 0xa06      DispatchQueue 1          priority 46
        12 ??? (com.apple.dock.extra + 5620) [0x1055155f4]
          12 ??? (com.apple.dock.extra + 5644) [0x10551560c]
            12 xpc_main + 399 (libxpc.dylib) [0x7fff84372bde]
              12 _xpc_main + 385 (XPCService) [0x7fff84385c0f]
                  12 -[NSApplication run] + 553 (AppKit) [0x7fff82c7c99c]
                    12 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122 (AppKit) [0x7fff82c8889b]
                      12 _DPSNextEvent + 1434 (AppKit) [0x7fff82c8924e]
                        12 _BlockUntilNextEventMatchingListInModeWithFilter + 65 (HIToolbox) [0x7fff8da4e5bc]
                          12 ReceiveNextEventCommon + 479 (HIToolbox) [0x7fff8da4e7b7]
                            12 RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff8da4ea0d]
        Thread 0xa0b      DispatchQueue 2          priority 48
        Thread 0xa13      priority 46
        Thread 0xdb8f     priority    0-46
        Binary Images:
               0x105514000 -        0x105519ff7  com.apple.dock.extra 1.0 (1) <BC607092-FA14-3E48-981B-C1A8C90A4ED3> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
            0x7fff8435f000 -     0x7fff84383fff  libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
            0x7fff84384000 -     0x7fff8438aff7  com.apple.XPCService 2.0 (1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
      Process:         com.apple.iCloudHelper [1794]
      Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
      Parent:          launchd [1]
      UID:             501
      Task size:       2038 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xd9ad     DispatchQueue 1          priority 4
          12 main + 176 (com.apple.iCloudHelper) [0x10ef99c20]
              12 _xpc_main + 417 (XPCService) [0x7fff84385c2f]
        Thread 0xd9d1     DispatchQueue 2          priority 4
        Thread 0xda48     priority 4
                12 -[AOSConfig listenForSystemEvents:] + 335 (AOSKit) [0x7fff8480f50d]
                  12 CFRunLoopRun + 97 (CoreFoundation) [0x7fff886e5811]
        Thread 0xda54     priority 4
                12 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348 (Foundation) [0x7fff8a3e5f87]
        Thread 0xda5e     priority 4
        Thread 0xdb9c     priority 4
        Thread 0xdb9d     priority 4
        Thread 0xdba0     priority 4
        Binary Images:
               0x10ef98000 -        0x10ef9eff7  com.apple.iCloudHelper 1.06 (176.2) <54240DA7-C010-3A4C-9090-B119FD88A655> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
            0x7fff847f3000 -     0x7fff84a84ff7  com.apple.AOSKit 1.06 (176.2) <9D851C25-F98E-317B-A9E1-2774942BBAC3> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
      Process:         com.apple.IconServicesAgent [1786]
      Path:            /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/XPCServices/com.apple .IconServicesAgent.xpc/Contents/MacOS/com.apple.IconServicesAgent
      Parent:          launchd [1]
      UID:             501
      Task size:       1277 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xd95f     DispatchQueue 7          priority 4
        Thread 0xd961     DispatchQueue 2          priority 4
        Binary Images:
               0x105ccc000 -        0x105cccfff  com.apple.IconServicesAgent 25 (25.17) <FEB468E2-2BDE-329E-8D4A-B56E133A445F> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/XPCServices/com.apple .IconServicesAgent.xpc/Contents/MacOS/com.apple.IconServicesAgent
      Process:         com.apple.internetaccounts [207]
      Path:            /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
      Parent:          launchd [1]
      UID:             501
      Task size:       865 pages
        Thread 0x69f      DispatchQueue 1          priority 46
          12 main + 157 (com.apple.internetaccounts) [0x10f59e39f]
            12 -[NSXPCListener resume] + 108 (Foundation) [0x7fff8a5d8cdb]
        Thread 0x6a1      DispatchQueue 2          priority 48
        Thread 0x6b1      priority 46
        Thread 0xdb93     priority    0-46
        Binary Images:
               0x10f59d000 -        0x10f5b0fff  com.apple.internetaccounts 1.0 (1) <7F86FA21-339A-312E-85EE-9ED0C5F55812> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
      Process:         com.bombich.ccchelper [64]
      Path:            /Library/PrivilegedHelperTools/com.bombich.ccchelper
      Parent:          launchd [1]
      UID:             0
      Task size:       252 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
      Process:         configd [54]
      Path:            /usr/libexec/configd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       544 pages
      Importance:      Adaptive, Boosted, Donating
      Timers:          Coalesced
        Thread 0x147      DispatchQueue 1          priority 31
          12 ??? (configd + 7579) [0x107a6ed9b]
            12 ??? (configd + 10766) [0x107a6fa0e]
        Thread 0x196      DispatchQueue 2          priority 33
        Thread 0x197      priority 31
        Thread 0x1e8      priority 31
              12 ??? (configd + 61557) [0x107a7c075]
        Thread 0x204      priority 31
        Thread 0x20e      priority 31
              12 pppcntl_run_thread + 1224 (PPPController) [0x10800c7f4]
        Thread 0xdb9e     priority    0-31
        Thread 0xdb9f     priority 31
        Binary Images:
               0x107a6d000 -        0x107aa0ff7  configd (596.15) <A0BA7068-DE27-3A09-8BF3-609D840BA6B8> /usr/libexec/configd
               0x108000000 -        0x10804dff7  com.apple.SystemConfiguration.PPPController 1.9 (1.9) <C3A61D36-AA67-326F-A9B1-F462AC5D1D4B> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
      Process:         ConsumerTouchDriver [381]
      Path:            /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app/Contents/Ma cOS/ConsumerTouchDriver
      UID:             501
      Task size:       437 pages
      Process:         cookied [1780]
      Path:            /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
      UID:             501
      Sudden Term:     Clean
      Task size:       696 pages
      Timers:          Coalesced
        Thread 0xd881     DispatchQueue 1          priority 31
          12 _cookied_main + 1291 (CFNetwork) [0x7fff8b1b122e]
        Thread 0xd882     DispatchQueue 2          priority 33
        Binary Images:
               0x1004c4000 -        0x1004c4fff  cookied (673.6) <EBC13F23-B5C7-3734-B938-8AFD9CB1C2D9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
            0x7fff8b0c9000 -     0x7fff8b264ff8  com.apple.CFNetwork 673.6 (673.6) <CAA196FE-BF5A-384F-975E-E0F81359805B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
      Process:         Core Sync [527]
      Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
      UID:             501
      Task size:       950 pages
      Process:         coreaudiod [259]
      Path:            /usr/sbin/coreaudiod
      Parent:          launchd [1]
      UID:             202
      Sudden Term:     Dirty
      Task size:       810 pages (+2)
      Timers:          Coalesced
        Thread 0x873      DispatchQueue 1          priority 63
          12 ??? (coreaudiod + 434846) [0x102d0029e]
        Thread 0x89c      DispatchQueue 2          priority 33
        Thread 0x9bb      priority 56
        Thread 0x9ea      priority 61
              12 ??? (coreaudiod + 481733) [0x102d0b9c5]
                12 ??? (coreaudiod + 447284) [0x102d03334]
        Thread 0xdc88     priority 31
        Binary Images:
               0x102c96000 -        0x102d57ff8  coreaudiod (309.13) <9831A5D9-505B-335C-844A-F43ABA1954EE> /usr/sbin/coreaudiod
      Process:         coreservicesd [72]
      Path:            /System/Library/CoreServices/coreservicesd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       2395 pages (+4)
      Timers:          Coalesced
        Thread 0x160      DispatchQueue 1          priority 31
          12 _CoreServicesServerMain + 692 (CarbonCore) [0x7fff8f3e5550]
        Thread 0x18f      DispatchQueue 2          priority 33
        Thread 0x242      priority 31
        Thread 0x243      priority 31
        12 read + 10 (libsystem_kernel.dylib) [0x7fff885b69f2]
                 *12 ??? (mach_kernel + 2143165) [0xffffff800040b3bd]
                   *12 tsleep + 92 (mach_kernel) [0xffffff80005e4ecc]
                     *12 ??? (mach_kernel + 4082602) [0xffffff80005e4baa]
        Thread 0xdc8d     priority 31
        Binary Images:
               0x10c16e000 -        0x10c16effe  coreservicesd (1077.17) <F0219AE2-7764-336B-9876-4F1FC676560C> /System/Library/CoreServices/coreservicesd
            0x7fff8f354000 -     0x7fff8f63efff  com.apple.CoreServices.CarbonCore 1077.17 (1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      Process:         Creative Cloud [359]
      Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
      Architecture:    i386
      UID:             501
      Task size:       1995 pages (+1)
      CPU Time:        0.023s
      IO Policy:       Standard
      Process:         CVMCompiler [1762]
      Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
      UID:             501
      Sudden Term:     Dirty
      Task size:       5579 pages
      Timers:          Coalesced
        Thread 0xd61c     DispatchQueue 7          priority 31
        Thread 0xd61e     DispatchQueue 2          priority 33
        Binary Images:
               0x109d30000 -        0x109d34fff  CVMCompiler (58.1) <3C615DB7-7821-3079-8E0E-59B1A5DB906A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
      Process:         CVMServer [151]
      Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       132 pages
      Timers:          Coalesced
        Thread 0x49b      priority 31
        Thread 0x49d      DispatchQueue 2          priority 33
        Binary Images:
               0x10183c000 -        0x101844fff  CVMServer (58.1) <E83687C2-F456-3754-9563-120B4E3300F1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
      Process:         dbfseventsd [1204]
      Path:            /Library/DropboxHelperTools/*/dbfseventsd
      Architecture:    i386
      Parent:          Dropbox [365]
      Responsible:     Dropbox [365]
      UID:             0
      Task size:       24 pages
      Process:         dbfseventsd [1205]
      Architecture:    i386
      Parent:          dbfseventsd [1204]
      UID:             0
      Task size:       452 pages
      Process:         dbfseventsd [1206]
      Architecture:    i386
      Parent:          dbfseventsd [1205]
      UID:             501
      Task size:       13 pages
      Process:         diskarbitrationd [50]
      Path:            /usr/libexec/diskarbitrationd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       200 pages
      Timers:          Coalesced
        Thread 0x143      DispatchQueue 1          priority 31
        Thread 0x19c      DispatchQueue 2          priority 33
        Thread 0xdb82     priority   29-31
        Binary Images:
               0x106bce000 -        0x106be3fff  diskarbitrationd (266) <94F10D52-A866-34ED-B278-873B4B2E0C7E> /usr/libexec/diskarbitrationd
      Process:         distnoted [71]
      Path:            /usr/sbin/distnoted
      Parent:          launchd [1]
      UID:             0
      Task size:       273 pages
      Timers:          Coalesced
        Thread 0x15e      DispatchQueue 1          priority 31
        Thread 0x17a      DispatchQueue 2          priority 33
        Thread 0xdb81     priority 31
        Thread 0xdb83     priority 31
        Thread 0xdb84     priority 31
        Binary Images:
               0x10c278000 -        0x10c280ff7  distnoted (855.17) <01E569A0-1603-3456-A5CC-21C706B5AA18> /usr/sbin/distnoted
      Process:         distnoted [187]
      UID:             501
      Task size:       741 pages
      CPU Time:        0.002s
      Timers:          Coalesced
        Thread 0x5cf      DispatchQueue 1          priority 31
        Thread 0x5d7      DispatchQueue 2          priority 33
        Thread 0xdbaa     priority 31
        Thread 0xdbae     priority 31         cpu time   0.002s
        Thread 0xdbaf     priority 31
        Thread 0xdbbf     priority 31
        Binary Images:
               0x100fa9000 -        0x100fb1ff7  distnoted (855.17) <01E569A0-1603-3456-A5CC-21C706B5AA18> /usr/sbin/distnoted
      Process:         distnoted [246]
      Parent:          launchd [240]
      UID:             89
      Task size:       154 pages
      Timers:          Coalesced
        Thread 0x80f      DispatchQueue 1          priority 31
        Thread 0x819      DispatchQueue 2          priority 33
        Thread 0xdbab     priority 31
        Thread 0xdbb0     priority 31
        Thread 0xdbb1     priority 31
        Binary Images:
               0x1057d6000 -        0x1057deff7  distnoted (855.17) <01E569A0-1603-3456-A5CC-21C706B5AA18> /usr/sbin/distnoted
      Process:         distnoted [329]
      Parent:          launchd [326]
      UID:             99
      Task size:       127 pages
      Timers:          Coalesced
        Thread 0xb41      DispatchQueue 1          priority 31
        Thread 0xb42      DispatchQueue 2          priority 33
        Thread 0xdbac     priority 31
        Thread 0xdbb2     priority 31
        Thread 0xdbb3     priority 31
        Binary Images:
               0x10e5bd000 -        0x10e5c5ff7  distnoted (855.17) <01E569A0-1603-3456-A5CC-21C706B5AA18> /usr/sbin/distnoted
      Process:         distnoted [564]
      Parent:          launchd [562]
      UID:             92
      Task size:       126 pages
      Timers:          Coalesced
        Thread 0x213f     DispatchQueue 1          priority 31
        Thread 0x214b     DispatchQueue 2          priority 33
        Thread 0xdbad     priority 31
        Thread 0xdbb4     priority 31
        Thread 0xdbb5     priority 31
        Binary Images:
               0x10a42a000 -        0x10a432ff7  distnoted (855.17) <01E569A0-1603-3456-A5CC-21C706B5AA18> /usr/sbin/distnoted
      Process:         Dock [256]
      Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
      UID:             501
      Task size:       2832 pages (+2)
      Pageins:         1 pages
      CPU Time:        0.011s
        Thread 0x86c      DispatchQueue 1          priority 46         cpu time   0.010s
          12 ??? (Dock + 20579) [0x1055df063]
              12 __CFRunLoopRun + 1830 (CoreFoundation) [0x7fff886307d6]
                12 __CFRunLoopDoSource1 + 478 (CoreFoundation) [0x7fff8863f79e]
                  12 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff8863f829]
                    12 mshPerform + 11 (HIServices) [0x7fff8ce7df5c]
                      12 ??? (Dock + 200963) [0x10560b103]
                        12 ??? (Dock + 391161) [0x1056397f9]
                          12 ??? (Dock + 730615) [0x10568c5f7]
                            12 ??? (Dock + 732241) [0x10568cc51]
                              12 ??? (Dock + 842023) [0x1056a7927]
                                12 _HandlePopUpMenuSelection7 + 596 (HIToolbox) [0x7fff8da812f6]
                                  11 PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1526 (HIToolbox) [0x7fff8da820d6]
                                    9  TrackMenuCommon(MenuSelectData&, unsigned char*) + 1545 (HIToolbox) [0x7fff8da99c61]
                                      9  IsUserStillTracking(MenuSelectData*, unsigned char*) + 186 (HIToolbox) [0x7fff8da9a05a]
                                        9  AcquireNextEventInMode + 51 (HIToolbox) [0x7fff8da9c5cd]
                                          9  ReceiveNextEventCommon + 479 (HIToolbox) [0x7fff8da4e7b7]
                                            9  RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff8da4ea0d]
                                              9  CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff8862fe75]
                                                9  __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
                                                  9  __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
                                                    9  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
                                                     *9  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
                                    2  TrackMenuCommon(MenuSelectData&, unsigned char*) + 1664 (HIToolbox) [0x7fff8da99cd8]
                                      1  SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 461 (HIToolbox) [0x7fff8daa21e1]
                                        1  FlashFeedback(MenuSelectData*) + 127 (HIToolbox) [0x7fff8daa2405]
                                          1  HIView::SimulateClick(unsigned int, short, unsigned int, short*) + 167 (HIToolbox) [0x7fff8daa24ff]
                                            1  SendEventToEventTargetWithOptions + 43 (HIToolbox) [0x7fff8da275f7]
                                              1  SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 385 (HIToolbox) [0x7fff8da27787]
                                                1  DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 892 (HIToolbox) [0x7fff8da281d4]
                                                  1  HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 6770 (HIToolbox) [0x7fff8da33b82]
                                                    1  HIView::SimulateClickSelf(short, unsigned int, short*) + 72 (HIToolbox) [0x7fff8daa25de]
                                                      1  SendControlSimulateHit(HIView*, short, unsigned int, short*) + 152 (HIToolbox) [0x7fff8daa2715]
                                                              1  HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2212 (HIToolbox) [0x7fff8da329b4]
        1  HIStandardMenuView::SimulateHitSelf(short, unsigned int, short*) + 185 (HIToolbox) [0x7fff8daa280f]
        1  HIMenuView::SimulateHitSelf(short, unsigned int, short*) + 141 (HIToolbox) [0x7fff8daa28e5]
        1  RunCurrentEventLoopInMode + 259 (HIToolbox) [0x7fff8da4ea2e]
        1  CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff8862fe75]
        1  __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
        1  __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
        1  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
        *1  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
                                      1  SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 814 (HIToolbox) [0x7fff8daa2342]
                                        1  RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff8da4ea0d]
                                  1  PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1726 (HIToolbox) [0x7fff8da8219e]
                                    1  FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 94 (HIToolbox) [0x7fff8daa40af]
                                      1  SendMenuItemSelectedEvent + 178 (HIToolbox) [0x7fff8daa41d0]
                                        1  SendMenuCommandWithContextAndModifiers + 59 (HIToolbox) [0x7fff8daa4228]
                                          1  SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 420 (HIToolbox) [0x7fff8da71640]
                                            1  SendEventToEventTarget + 40 (HIToolbox) [0x7fff8da3b880]
                                                  1  ??? (Dock + 731147) [0x10568c80b]
                                                    1  ??? (Dock + 783376) [0x105699410]
                                                      1  ??? (Dock + 727085) [0x10568b82d]
                                                        1  LQForceQuit + 97 (libquit.dylib) [0x7fff827bfa85]
                                                          1  _CRProcessWillBeForceQuit + 90 (CrashReporterSupport) [0x7fff8e5c76fe]
                                                            1  _CRCopyCrashHistoryForProcess + 20 (CrashReporterSupport) [0x7fff8e5c74cb]
                                                              1  _CRCopyExecutablePathAndNameForPIDDetectingInconsistencies + 371 (CrashReporterSupport) [0x7fff8e5c404b]
                                                               *1  hndl_alltraps + 219 (mach_kernel) [0xffffff80002f438b]
        *1  user_trap + 748 (mach_kernel) [0xffffff80002dd05c]
        *1  vm_fault_page + 994 (mach_kernel) [0xffffff8000274b82]
        *1  lck_rw_sleep + 81 (mach_kernel) [0xffffff800022dab1]
        Thread 0x8a8      DispatchQueue 2          priority 48         cpu time   0.001s
        Thread 0x9f1      priority 46
              12 ??? (Dock + 195915) [0x105609d4b]
        Thread 0xdb73     priority   46-48
        Thread 0xdbbc     priority 46
        Binary Images:
               0x1055da000 -        0x10584fff7  com.apple.dock 1.8 (1314.12) <5757C45F-68A0-310E-BA58-85D4337FAC27> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
            0x7fff827be000 -     0x7fff827bffff  libquit.dylib (161.2) <7B9C07B6-8993-32C8-89C2-23D2E7FA85BA> /usr/lib/libquit.dylib
            0x7fff8ce74000 -     0x7fff8ceb9ff6  com.apple.HIServices 1.23 <5970AF5C-F5BD-3B6A-97C9-95B2CA98D71D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0x7fff8e5c2000 -     0x7fff8e5ccff7  com.apple.CrashReporterSupport 10.9 (539) <B25A09EC-A021-32EC-86F8-05B4837E0EDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
      Process:         Dropbox [365]
      Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
      Architecture:    i386
      UID:             501
      Task size:       4906 pages
      CPU Time:        0.001s
      Process:         dynamic_pager [46]
      Path:            /sbin/dynamic_pager
      Parent:          launchd [1]
      UID:             0
      Task size:       6 pages
      Timers:          Coalesced
        Thread 0x13f      priority 63
        Binary Images:
      Process:         filecoordinationd [301]
      Path:            /usr/sbin/filecoordinationd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       280 pages
      Timers:          Coalesced
        Thread 0x98a      priority 31
        Thread 0x98b      DispatchQueue 2          priority 33
        Binary Images:
               0x1068d9000 -        0x1068ddff7  filecoordinationd (1056.17) <2A5373E1-91E8-35EB-AEE3-EAD0E752A3B5> /usr/sbin/filecoordinationd
      Process:         Finder [258]
      Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
      UID:             501
      Sudden Term:     Clean
      Task size:       2274 pages (+2)
      Suppression:     IO Throttling, Low CPU Priority, Timer Limits
      IO Policy:       Standard
      Timers:          Limited
        Thread 0x86f      DispatchQueue 1          priority    4-46
          12 ??? (Finder + 26416) [0x107533730]
        Thread 0x8df      DispatchQueue 2          priority    4-48
        Thread 0x980      priority    4-46
        Thread 0x13b3     priority    4-46
        Thread 0x13b8     priority    4-46
        Thread 0x1ed5     priority    4-46
         *12 special_handler_continue + 0 (mach_kernel) [0xffffff80002489b0]
        Thread 0x1edf     priority    4-46
                12 -[NSConnection run] + 127 (Foundation) [0x7fff8a45ef89]
        Thread 0x1ef4     priority    4-46
        Thread 0xdb7d     priority    0-46
        Thread 0xdbb9     priority    4-46
        Binary Images:
               0x10752d000 -        0x1079fbff9  com.apple.finder 10.9.5 (10.9.5) <96C91804-B75F-3E8F-B157-C82C032C6353> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
      Process:         fontd [192]
      Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
      UID:             501
      Sudden Term:     Clean
      Task size:       410 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x5f2      DispatchQueue 1          priority 4
          12 main_handler + 4271 (libATSServer.dylib) [0x7fff8ae8ebd3]
        Thread 0x5f3      DispatchQueue 2          priority 4
        Thread 0xdca2     priority 4
        Binary Images:
               0x10ae47000 -        0x10ae4afff  fontd (363.6) <B9E7463D-29A5-3438-9C15-A1A864EE6C6E> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
            0x7fff8ae13000 -     0x7fff8aea4ff7  libATSServer.dylib (363.6) <47375061-C00F-377F-906B-1BBEE7E320BD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
      Process:         fseventsd [44]
      Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
      Parent:          launchd [1]
      UID:             0
      Task size:       809 pages (+2)
      Timers:          Coalesced
        Thread 0x13d      DispatchQueue 1          priority 31
          12 ??? (fseventsd + 7725) [0x105b5ce2d]
            12 mach_msg_server + 603 (libsystem_kernel.dylib) [0x7fff885b164e]
              12 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a26]
        Thread 0x2c7      DispatchQueue 2          priority 33
        Thread 0x18c      priority 49
              12 ??? (fseventsd + 47597) [0x105b669ed]
                12 ??? (fseventsd + 46380) [0x105b6652c]
        Thread 0x2c4      priority 31
        Thread 0x2c5      priority 50
        Thread 0x2c6      priority 31
              12 ??? (fseventsd + 32476) [0x105b62edc]
        Thread 0xdb1c     priority 31
              12 ??? (fseventsd + 32434) [0x105b62eb2]
        Thread 0xdb28     priority 31
        Thread 0xdc98     priority 31
        Binary Images:
               0x105b5b000 -        0x105b73ff7  fseventsd (1077.17) <AE4BB363-CC47-3401-8D66-9390C165A349> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
      Process:         Google Drive [367]
      Path:            /Applications/Google Drive.app/Contents/MacOS/Google Drive
      UID:             501
      Task size:       3986 pages
      CPU Time:        0.001s
      Process:         hasplmd [65]
      Path:            /usr/libexec/hasplmd
      Architecture:    i386
      Parent:          launchd [1]
      UID:             0
      Task size:       619 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x152      priority 31
        Thread 0x2c9      priority 31
        Thread 0x616      priority 31
        12 thread_start + 34 (libsystem_pthread.dylib) [0x90c3ecf2]
          12 _pthread_start + 130 (libsystem_pthread.dylib) [0x90c39485]
            12 ??? (hasplmd + 1510639) [0x171cef]
              12 pthread_cond_wait$UNIX2003 + 71 (libsystem_pthread.dylib) [0x90c3dbd9]
                12 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x9a1177ca]
        Thread 0x617      priority 31
            12 ??? (hasplmd + 95363) [0x18483]
              12 __semwait_signal + 10 (libsystem_kernel.dylib) [0x9a117b76]
        Thread 0x618      priority 31
        Thread 0x619      priority 31
        Thread 0x61a      priority 31
        Binary Images:
                    0x1000 -           0x282101  hasplmd <A6A6BA66-0B72-543B-1B4B-DF99160A9487> /usr/libexec/hasplmd
      Process:         helpd [1342]
      Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
      UID:             501
      Sudden Term:     Clean
      Task size:       911 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xa705     DispatchQueue 1          priority 31
        Thread 0xa708     DispatchQueue 2          priority 33
        Thread 0xdc8e     priority 31
        Binary Images:
               0x10ef69000 -        0x10ef77fff  helpd (97) <8F9366B0-42AA-3DF3-8D30-A4681369D612> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
      Process:         hidd [43]
      Path:            /usr/libexec/hidd
      Parent:          launchd [1]
      UID:             0
      Task size:       55 pages (+2)
        Thread 0x13c      DispatchQueue 1          priority 31
        Thread 0x1d0      DispatchQueue 2          priority 33
        Thread 0x1d2      priority 63
        Thread 0xdc96     priority 31
        Binary Images:
               0x10ffdb000 -        0x10ffdbfff  hidd (503.215.7) <E4A26D48-03F7-3AAA-ABD8-15157D0AF8D1> /usr/libexec/hidd
      Process:         i1ProfilerTray [372]
      Path:            /Applications/i1Profiler/i1ProfilerTray.app/Contents/MacOS/i1ProfilerTray
      Architecture:    i386
      UID:             501
      Sudden Term:     Clean
      Task size:       1304 pages
      Process:         identityservicesd [224]
      Path:            /System/Library/PrivateFrameworks/IDSCore.framework/identityservicesd.app/Contents/MacOS/ identityservicesd
      UID:             501
      Task size:       684 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x717      DispatchQueue 1          priority 4
          12 ??? (identityservicesd + 6605) [0x10b2b09cd]
        Thread 0x718      DispatchQueue 2          priority 4
        Thread 0x71e      priority 4
        Thread 0x71f      priority 4
        Thread 0xdc9f     priority 4
        Binary Images:
               0x10b2af000 -        0x10b2feff7  com.apple.identityservicesd 10.0 (1000) <9D6070CC-7083-35BA-B681-AE5C282E52E3> /System/Library/PrivateFrameworks/IDSCore.framework/identityservicesd.app/Contents/MacOS/ identityservicesd
      Process:         Image Capture Extension [309]
      Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
      UID:             501
      Sudden Term:     Clean
      Task size:       699 pages
        Thread 0x9cc      DispatchQueue 1          priority 46
        Thread 0x9dd      DispatchQueue 2          priority 48
        Thread 0xa10      priority 46
        Thread 0xdb90     priority    0-46
        Binary Images:
               0x100913000 -        0x100958fff  com.apple.ImageCaptureExtension2 9.2 (9.2) <DE33F91B-4309-3FEF-AC37-2C6F90A8C474> /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
      Process:         imagent [215]
      Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
      UID:             501
      Task size:       538 pages (+2)
      Timers:          Coalesced
        Thread 0x701      DispatchQueue 1          priority 31
          12 ??? (imagent + 33449) [0x10894e2a9]
        Thread 0x702      DispatchQueue 2          priority 33
        Thread 0xdc81     priority 31
        Binary Images:
               0x108946000 -        0x108969ff7  com.apple.imagent 10.0 (1000) <A1D59944-801E-326F-854B-BF0C174958CB> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
      Process:         installd [1171]
      Path:            /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
      Architecture:    x86_64
      Parent:          launchd [1]
      UID:             0
      Task size:       3941 pages (+455)
      Pageins:         42 pages
      CPU Time:        0.684s
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xa083     DispatchQueue 1          priority    4-31
        Thread 0xa084     DispatchQueue 2          priority    4-33
        Thread 0xdba2     priority    4-31   cpu time   0.003s
        Thread 0xdba3     priority    4-31
        Thread 0xdba6     priority    4-31
        Thread 0xdba7     priority    0-30   cpu time   0.680s
        10 thread_start + 13 (libsystem_pthread.dylib) [0x7fff824aefc9]
          10 _pthread_start + 137 (libsystem_pthread.dylib) [0x7fff824aa72a]
            10 _pthread_body + 138 (libsystem_pthread.dylib) [0x7fff824aa899]
              10 __NSThread__main__ + 1318 (Foundation) [0x7fff8a3e5d8b]
                9 -[PKInstall _installMain:] + 855 (PackageKit) [0x7fff8be305ad]
                  9 -[PKInstallAnalyzer initWithInstallRequest:includeObsoletion:] + 582 (PackageKit) [0x7fff8be5eead]
                    8 -[PKInstallAnalyzer _analyzeIncludingObsoletion:] + 412 (PackageKit) [0x7fff8be5f172]
                      6 -[PKInstallAnalyzer _findObsoleteOnDiskFilesForPackageSpecifier:coreLanguages:] + 4039 (PackageKit) [0x7fff8be60a08]
                        5 -[PKInstallAnalyzer _coreLocsToInstallAtResourcesPath:withCoreLocs:ofComponent:] + 153 (PackageKit) [0x7fff8be61d76]
                          5 -[PKPackage subpathsForComponent:] + 29 (PackageKit) [0x7fff8be3f61a]
                            2 -[PKPackage _populateComponentSubpaths] + 701 (PackageKit) [0x7fff8be3f90c]
                              2 -[PKPackage directoryEnumerator] + 73 (PackageKit) [0x7fff8be3f503]
                                1 _ReadFreeList + 154 (Bom) [0x7fff86d5d6b4]
                                1 BOMBomFree + 185 (Bom) [0x7fff86d43e5f]
                            1 -[PKPackage _populateComponentSubpaths] + 808 (PackageKit) [0x7fff8be3f977]
                              1 -[__NSCFString substringWithRange:] + 231 (CoreFoundation) [0x7fff8862dbb7]
                                1 CFStringCreateWithSubstring + 462 (CoreFoundation) [0x7fff885de0ee]
                                  1 __CFStringCreateImmutableFunnel3 + 2368 (CoreFoundation) [0x7fff885c5560]
                                    1 _platform_memset$VARIANT$Merom + 48 (libsystem_platform.dylib) [0x7fff8e1baf10]
                                     *1 return_from_trap + 178 (mach_kernel) [0xffffff80002f4452]
                                       *1 i386_astintr + 35 (mach_kernel) [0xffffff80002dd253]
                                         *1 ast_taken + 136 (mach_kernel) [0xffffff8000220cc8]
                            1 -[PKPackage _populateComponentSubpaths] + 1283 (PackageKit) [0x7fff8be3fb52]
                              1 -[__NSCFString hasPrefix:] + 101 (CoreFoundation) [0x7fff88627335]
                                1 CFStringHasPrefix + 55 (CoreFoundation) [0x7fff885d5047]
                                  1 CFStringFindWithOptionsAndLocale + 6934 (CoreFoundation) [0x7fff885d6b76]
                            1 -[PKPackage _populateComponentSubpaths] + 1824 (PackageKit) [0x7fff8be3fd6f]
                              1 -[NSAutoreleasePool drain] + 147 (Foundation) [0x7fff8a39a437]
                                1 _CFAutoreleasePoolPop + 50 (CoreFoundation) [0x7fff885f8932]
                                  1 (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 502 (libobjc.A.dylib) [0x7fff8d80565a]
                                    1 OSAtomicCompareAndSwapLong$VARIANT$mp + 8 (libsystem_platform.dylib) [0x7fff8e1b8bd4]
                        1 -[PKInstallAnalyzer _coreLocsToInstallAtResourcesPath:withCoreLocs:ofComponent:] + 304 (PackageKit) [0x7fff8be61e0d]
                          1 -[NSString hasPrefix:] + 56 (Foundation) [0x7fff8a3a2b96]
                            1 -[NSString rangeOfString:options:range:] + 29 (Foundation) [0x7fff8a3a2bd4]
                              1 -[NSString rangeOfString:options:range:locale:] + 475 (Foundation) [0x7fff8a3830c6]
                                1 CFStringFindWithOptionsAndLocale + 1238 (CoreFoundation) [0x7fff885d5536]
                                  1 -[NSPathStore2 getCharacters:range:] + 162 (Foundation) [0x7fff8a38bc72]
                                    1 _platform_memmove$VARIANT$Merom + 96 (libsystem_platform.dylib) [0x7fff8e1ba2c0]
                      2 -[PKInstallAnalyzer _findObsoleteOnDiskFilesForPackageSpecifier:coreLanguages:] + 4010 (PackageKit) [0x7fff8be609eb]
                        2 -[PKInstallAnalyzer _coreLocsInstalledAtPath:withCoreLocs:returningOtherInstalledLocs:] + 139 (PackageKit) [0x7fff8be61acc]
                          2 -[NSFileManager contentsOfDirectoryAtPath:error:] + 36 (Foundation) [0x7fff8a3a28df]
                            2 -[NSFileManager directoryContentsAtPath:matchingExtension:options:keepExtension:error:] + 318 (Foundation) [0x7fff8a3a2a23]
                              1 _NSDirectoryContentsFromCarbonError + 591 (Foundation) [0x7fff8a3a307c]
                                1 CFStringCreateWithCharacters + 70 (CoreFoundation) [0x7fff885da7c6]
                                  1 __CFStringCreateImmutableFunnel3 + 2016 (CoreFoundation) [0x7fff885c5400]
                                    1 <executing in user space>
                              1 _NSDirectoryContentsFromCarbonError + 130 (Foundation) [0x7fff8a3a2eaf]
                                1 FSOpenIterator + 28 (CarbonCore) [0x7fff8f36268d]
                                  1 PBOpenIteratorSync + 201 (CarbonCore) [0x7fff8f36276e]
                                    1 GetFSRefAttributes(FSMount*, FSRef const*, unsigned int, FSAttributeInfo*, unsigned int, char*) + 127 (CarbonCore) [0x7fff8f35d931]
                                      1 FSMount::getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 228 (CarbonCore) [0x7fff8f35da86]
                                        1 FSMount::_getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 129 (CarbonCore) [0x7fff8f35db55]
                                          1 GetVolFSAttributes(FSMount*, unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned int, FSVolAttributeInfo*, unsigned char*) + 824 (CarbonCore) [0x7fff8f35dfb2]
                                            1 __getattrlist + 10 (libsystem_kernel.dylib) [0x7fff885b50aa]
                                                 *1 getattrlist + 191 (mach_kernel) [0xffffff80003c46bf]
                                                   *1 return_to_iret + 288 (mach_kernel) [0xffffff80002f476d]
                    1 -[PKInstallAnalyzer _analyzeIncludingObsoletion:] + 428 (PackageKit) [0x7fff8be5f182]
                      1 -[PKInstallAnalyzer _findRegistrationPathsForPackageSpecifier:] + 1012 (PackageKit) [0x7fff8be63734]
                              1 CFStringFindWithOptionsAndLocale + 1070 (CoreFoundation) [0x7fff885d548e]
                1 -[PKInstall _installMain:] + 2306 (PackageKit) [0x7fff8be30b58]
                        1 -[__NSArrayM dealloc] + 185 (CoreFoundation) [0x7fff885ec699]
                          1 CFRelease + 591 (CoreFoundation) [0x7fff885d943f]
                            1 -[PKPackage dealloc] + 81 (PackageKit) [0x7fff8be3f306]
                              1 -[__NSDictionaryM dealloc] + 249 (CoreFoundation) [0x7fff8860b4a9]
                                  1 -[PKBundleComponent dealloc] + 41 (PackageKit) [0x7fff8be3be34]
                                    1 CFRelease + 1097 (CoreFoundation) [0x7fff885d9639]
                                      1 szone_free + 1132 (libsystem_malloc.dylib) [0x7fff86c347ba]
                                        1 get_tiny_previous_free_msize + 48 (libsystem_malloc.dylib) [0x7fff86c3c20c]
        Binary Images:
               0x1055b6000 -        0x1055b6fff  installd (332) <F48CFE75-4DAE-3A5C-B820-CF14FAA31839> /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
            0x7fff86c31000 -     0x7fff86c4cff7  libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
            0x7fff86d3f000 -     0x7fff86d7afff  com.apple.bom 14.0 (193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
            0x7fff8be22000 -     0x7fff8beb8ff7  com.apple.PackageKit 3.0 (332) <70BE1C7F-0609-32D3-9FA3-3C2CCF7FE999> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/PackageKit
            0x7fff8d7fe000 -     0x7fff8d9abf27  libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
            0x7fff8e1b6000 -     0x7fff8e1bcff7  libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
      Process:         iTunesHelper [1442]
      Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
      Parent:          launchd [181]
      UID:             501
      Task size:       613 pages (+3)
      IO Policy:       Standard
        Thread 0xaaa4     DispatchQueue 1          priority 46
        12 start + 1 (libdyld.dylib) [0x7fff8b8f65fd]
          12 ??? (iTunesHelper + 50516) [0x101fcf554]
              12 CFRunLoopRunSpecific + 309 (CoreFoundation) [0x7fff8862fe75]
        Thread 0xaaa5     DispatchQueue 2          priority 48
        12 _dispatch_mgr_thread + 52 (libdispatch.dylib) [0x7fff8f0a8136]
          12 kevent64 + 10 (libsystem_kernel.dylib) [0x7fff885b6662]
        Thread 0xab53     priority 46
        Thread 0xdc7b     priority 46
        Binary Images:
               0x101fc3000 -        0x101fdefff  com.apple.iTunesHelper 12.3.1 (12.3.1.23) <373AD60B-CF80-3E21-AD1E-0D37E176BD9D> /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
      Process:         KernelEventAgent [41]
      Path:            /usr/sbin/KernelEventAgent
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       35 pages
      Timers:          Coalesced
        Thread 0x13a      priority 31
        Thread 0x178      priority 33
        Thread 0x179      priority 31
        Binary Images:
               0x100c86000 -        0x100c8cfff  KernelEventAgent (81) <DF479FD9-A3F2-3B68-A7DC-BAF1376C2466> /usr/sbin/KernelEventAgent
      Process:         kextd [12]
      Path:            /usr/libexec/kextd
      Parent:          launchd [1]
      UID:             0
      Task size:       179 pages (+2)
      Timers:          Coalesced
        Thread 0x11c      DispatchQueue 1          priority 31
        Thread 0x1b1      DispatchQueue 2          priority 33
        Thread 0xdc8b     priority 31
        Binary Images:
               0x101fe4000 -        0x102000ff7  kextd (326.95.1) <FD6C9124-FF5E-3ABB-B85D-C6B79CDE7573> /usr/libexec/kextd
      Process:         LaterAgent [1496]
      Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
      UID:             501
      Sudden Term:     Clean
      Task size:       1498 pages (+3)
      IO Policy:       Standard
        Thread 0xab9f     DispatchQueue 1          priority 46
          12 NSApplicationMain + 940 (AppKit) [0x7fff82c67783]
        Thread 0xaba3     DispatchQueue 2          priority 48
        Thread 0xabbb     priority 46
        12 thread_start + 13 (libsystem_pthread.dylib) [0x7fff824aefc9]
          12 _pthread_start + 137 (libsystem_pthread.dylib) [0x7fff824aa72a]
            12 _pthread_body + 138 (libsystem_pthread.dylib) [0x7fff824aa899]
              12 _NSEventThread + 144 (AppKit) [0x7fff82e2905e]
        Thread 0xdc79     priority 46
        Binary Images:
               0x10369a000 -        0x1036a5fff  com.apple.lateragent 1.0 (1) <86B9C0DB-8764-3F44-8DF5-690A71F7CAD3> /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
      Process:         launchd [1]
      Path:            /sbin/launchd
      Parent:          kernel_task [0]
      UID:             0
      Task size:       620 pages
      CPU Time:        0.008s
        Thread 0x103      DispatchQueue 1          priority 31         cpu time   0.008s
          12 ??? (launchd + 18649) [0x1010598d9]
            12 ??? (launchd + 27018) [0x10105b98a]
              12 xpc_pipe_try_receive + 87 (libxpc.dylib) [0x7fff84377000]
                12 _xpc_pipe_receive + 92 (libxpc.dylib) [0x7fff84376e6b]
        Thread 0x10b      priority 31
        Thread 0x10c      priority 31
              12 ??? (launchd + 18941) [0x1010599fd]
                12 sleep + 42 (libsystem_c.dylib) [0x7fff8bde3c1f]
                  12 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff885b5a3a]
        Binary Images:
               0x101055000 -        0x10107bff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchd [181]
      Path:            /sbin/launchd
      Parent:          launchd [1]
      UID:             501
      Sudden Term:     Dirty
      Task size:       218 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x5b7      DispatchQueue 1          priority 31
          12 ??? (launchd + 18649) [0x106ab88d9]
            12 ??? (launchd + 27018) [0x106aba98a]
        Thread 0x5b8      priority 31
        Binary Images:
               0x106ab4000 -        0x106adaff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchd [240]
      Path:            /sbin/launchd
      Parent:          launchd [1]
      UID:             89
      Sudden Term:     Dirty
      Task size:       104 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x7ff      DispatchQueue 1          priority 31
          12 ??? (launchd + 18649) [0x10e0ef8d9]
            12 ??? (launchd + 27018) [0x10e0f198a]
        Thread 0x802      priority 31
        Binary Images:
               0x10e0eb000 -        0x10e111ff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchd [326]
      Path:            /sbin/launchd
      Parent:          launchd [1]
      UID:             99
      Sudden Term:     Dirty
      Task size:       94 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xb37      DispatchQueue 1          priority 31
          12 ??? (launchd + 18649) [0x103c798d9]
            12 ??? (launchd + 27018) [0x103c7b98a]
                  12 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
                   *12 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
        Thread 0xb39      priority 31
              12 __select + 10 (libsystem_kernel.dylib) [0x7fff885b59aa]
               *12 ??? (mach_kernel + 4083744) [0xffffff80005e5020]
        Binary Images:
               0x103c75000 -        0x103c9bff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchd [562]
      Path:            /sbin/launchd
      Parent:          launchd [1]
      UID:             92
      Sudden Term:     Dirty
      Task size:       69 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x2133     DispatchQueue 1          priority 31
          12 ??? (launchd + 18649) [0x10d3e78d9]
            12 ??? (launchd + 27018) [0x10d3e998a]
        Thread 0x2134     priority 31
        Binary Images:
               0x10d3e3000 -        0x10d409ff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchd [1491]
      Path:            /sbin/launchd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       133 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xab75     DispatchQueue 1          priority 31
          12 ??? (launchd + 18649) [0x1026e38d9]
            12 ??? (launchd + 27018) [0x1026e598a]
        Thread 0xab76     priority 31
        Binary Images:
               0x1026df000 -        0x102705ff7  launchd (842.92.1) <364E35A7-9FA7-3950-8494-40B49A2E7250> /sbin/launchd
      Process:         launchdadd [1811]
      Path:            /usr/libexec/launchdadd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       421 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xdbdf     DispatchQueue 1          priority 31
        11 ??? [0x7fff8b8f65fd]
          11 ??? [0x1047a84f5]
            11 ??? [0x7fff886e5811]
              11 ??? [0x7fff8862fe75]
                11 ??? [0x7fff88630539]
                  11 ??? [0x7fff88630f15]
                    11 ??? [0x7fff885b1a1a]
                     *11 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000216900]
        Thread 0xdc6c     DispatchQueue 2          priority 33
        11 ??? [0x7fff8f0a8136]
          11 ??? [0x7fff885b6662]
           *11 ??? (mach_kernel + 3963520) [0xffffff80005c7a80]
        Thread 0xdc94     priority 31
        9 ??? [0x7fff824aefb9]
          9 ??? [0x7fff885b5e6a]
        Binary Images:
      Process:         launchservicesd [51]
      Path:            /System/Library/CoreServices/launchservicesd
      Parent:          launchd [1]
      UID:             0
      Task size:       794 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x18e      DispatchQueue 2          priority 4
        Thread 0x190      DispatchQueue 7          priority 4
        Thread 0xdbbd     priority 4
        12 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          12 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *12 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Binary Images:
               0x10cecb000 -        0x10ced5ff7  launchservicesd (572.32) <3210474A-775D-3F6F-853B-4E28CB094957> /System/Library/CoreServices/launchservicesd
      Process:         librariand [293]
      Path:            /usr/libexec/librariand
      UID:             501
      Task size:       14 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x8f3      priority 4
        Thread 0x8ff      priority 4
        Binary Images:
               0x105d97000 -        0x105da7ffe  librariand (1210.1.10) <4454A8A4-8B01-3300-9A34-D7EB48731635> /usr/libexec/librariand
      Process:         locationd [40]
      Path:            /usr/libexec/locationd
      Parent:          launchd [1]
      UID:             205
      Task size:       741 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x139      DispatchQueue 1          priority 4
          12 ??? (locationd + 120852) [0x10a43e814]
            12 ??? (locationd + 16946) [0x10a425232]
              12 ??? (locationd + 16168) [0x10a424f28]
        Thread 0x3b4      DispatchQueue 2          priority 4
        Thread 0x505      priority 4
        Thread 0x515      priority 4
        Thread 0x516      priority 4
        12 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff885b5716]
         *12 psynch_cvcontinue + 0 (pthread) [0xffffff7f80bcf940]
        Thread 0x517      priority 4
        12 kevent + 10 (libsystem_kernel.dylib) [0x7fff885b664a]
        Thread 0xdc9b     priority 4
        Binary Images:
               0x10a421000 -        0x10a72cfff  locationd (1486.24.1) <EF6B268F-E057-3BFD-A589-61C1B281F2DB> /usr/libexec/locationd
            0x7fff824a9000 -     0x7fff824b0ff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
      Process:         logind [39]
      Path:            /System/Library/CoreServices/logind
      Parent:          launchd [1]
      UID:             0
      Task size:       99 pages
      Timers:          Coalesced
        Thread 0x138      DispatchQueue 1          priority 31
        Thread 0x15c      DispatchQueue 2          priority 33
        Binary Images:
               0x102461000 -        0x102466ff7  logind (21) <2A1555A3-E186-3508-B9DF-486455F97B1C> /System/Library/CoreServices/logind
            0x7fff885a0000 -     0x7fff885bcff7  libsystem_kernel.dylib (2422.115.14) <8116098D-B3F1-3E50-A934-576DD6369234> /usr/lib/system/libsystem_kernel.dylib
      Process:         loginwindow [38]
      Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
      Parent:          launchd [1]
      UID:             501
      Task size:       1058 pages
      CPU Time:        0.004s
        Thread 0x137      DispatchQueue 1          priority 48         cpu time   0.004s
          12 ??? (loginwindow + 23346) [0x108046b32]
        Thread 0x391      DispatchQueue 2          priority 50
        Thread 0xdb89     priority    0-48
        Binary Images:
               0x108041000 -        0x1080daff7  com.apple.loginwindow 9.0 (9.0) <BCEE9FC2-DB71-396D-B666-25C691A23B84> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
            0x7fff82c65000 -     0x7fff837dbff7  com.apple.AppKit 6.9 (1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0x7fff885c0000 -     0x7fff887a5fff  com.apple.CoreFoundation 6.9 (855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x7fff8b8f3000 -     0x7fff8b8f6ff7  libdyld.dylib (239.4) <7C9EC3B7-DDE3-33FF-953F-4067C743951D> /usr/lib/system/libdyld.dylib
            0x7fff8da20000 -     0x7fff8dccaff5  com.apple.HIToolbox 2.1.1 <A388E773-AE7B-3FD1-8662-A98E6E24EA16> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0x7fff8f0a5000 -     0x7fff8f0bffff  libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib
      *0xffffff7f80bca000 - 0xffffff7f80bd1fff  com.apple.kec.pthread 1.0 (1) <882075E6-12C4-3225-8750-928715183739> /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
      *0xffffff8000200000 - 0xffffff80007aa29a  mach_kernel (2422.115.14) <8B1A8FD1-2344-36C0-A7F5-D9D485A995FA> /mach_kernel
      Process:         lsboxd [209]
      Path:            /usr/libexec/lsboxd
      UID:             501
      Task size:       178 pages
      Importance:      Adaptive, Background Priority
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x6ac      DispatchQueue 2          priority 4
           *12 ??? (mach_kernel + 3963520) [0xffffff80005c7a80]
        Thread 0x6ae      DispatchQueue 7          priority 4
        Binary Images:
               0x1052d9000 -        0x1052dcff7  lsboxd (572.32) <887F8AE7-8BC4-3D40-B0D6-718B48EE720B> /usr/libexec/lsboxd
      Process:         MassStorageCamera [300]
      Path:            /System/Library/Image Capture/Devices/MassStorageCamera.app/Contents/MacOS/MassStorageCamera
      UID:             501
      Sudden Term:     Clean
      Task size:       531 pages
        Thread 0x984      DispatchQueue 1          priority 46
          12 ICD_main + 24 (ICADevices) [0x10c3d64bf]
            12 ICAApplicationMain + 395 (ICADevices) [0x10c3cb1c3]
        Thread 0x98d      DispatchQueue 2          priority 48
        Thread 0x9a6      priority 46
        Thread 0x9c8      priority 46
        Thread 0xdb91     priority    0-46
        Binary Images:
               0x10c3a6000 -        0x10c3b4fff  com.apple.MassStorageCamera 9.2 (9.2) <416EDB3C-95A6-3717-810F-5D4BB7C8D68F> /System/Library/Image Capture/Devices/MassStorageCamera.app/Contents/MacOS/MassStorageCamera
               0x10c3c9000 -        0x10c3f0ff7  com.apple.ICADevices 9.2 (9.2) <F160147D-44D6-326E-8423-07E7033922F8> /System/Library/Frameworks/ICADevices.framework/Versions/A/ICADevices
      Process:         mdflagwriter [690]
      Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
      UID:             501
      Sudden Term:     Clean
      Task size:       76 pages
      Timers:          Coalesced
        Thread 0x31ce     DispatchQueue 2          priority 33
        Thread 0x31d2     DispatchQueue 7          priority 31
        Binary Images:
               0x10b7b4000 -        0x10b7b4fff  mdflagwriter (800.30) <D04E739F-2AF3-3B39-83DE-A9B0ADCD9503> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
      Process:         mdflagwriter [1493]
      Parent:          launchd [1491]
      UID:             0
      Sudden Term:     Clean
      Task size:       110 pages
      Timers:          Coalesced
        Thread 0xab7a     DispatchQueue 2          priority 33
        Thread 0xab7c     DispatchQueue 7          priority 31
        Binary Images:
               0x10d02d000 -        0x10d02dfff  mdflagwriter (800.30) <D04E739F-2AF3-3B39-83DE-A9B0ADCD9503> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
      Process:         mDNSResponder [35]
      Path:            /usr/sbin/mDNSResponder
      Parent:          launchd [1]
      UID:             65
      Sudden Term:     Clean
      Task size:       361 pages (+2)
      Timers:          Coalesced
        Thread 0x134      DispatchQueue 1          priority 31
        12 start + 52 (mDNSResponder) [0x1065a5370]
          12 main + 2193 (mDNSResponder) [0x106573c11]
                12 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
                  12 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
        Thread 0x35a      DispatchQueue 2          priority 33
        Thread 0x394      priority 31
        Thread 0xdc83     priority 31
        9 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          9 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *9 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Binary Images:
               0x106572000 -        0x10661cff7  mDNSResponder <7B7C82B2-983E-3193-A824-F76CB814A192> /usr/sbin/mDNSResponder
      Process:         mds [34]
      Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
      Parent:          launchd [1]
      UID:             0
      Task size:       4108 pages
      Timers:          Coalesced
        Thread 0x133      DispatchQueue 1          priority 31
        Thread 0x2bf      DispatchQueue 2          priority 33
        Thread 0x317      priority 50
               *12 hndl_unix_scall64 + 22 (mach_kernel) [0xffffff80002f4c86]
                 *12 unix_syscall64 + 499 (mach_kernel) [0xffffff8000641a23]
                             *12 thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
                               *12 ??? (mach_kernel + 224459) [0xffffff8000236ccb]
                                 *12 machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
        Thread 0xd7d0     priority    0-31
        Thread 0xd9ac     priority 31
        Thread 0xdb4b     priority 0
        Thread 0xdbba     priority 0
              12 _dispatch_worker_thread + 145 (libdispatch.dylib) [0x7fff8f0a7eec]
                12 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a6e]
                 *12 semaphore_wait_continue + 0 (mach_kernel) [0xffffff800023b8e0]
        Binary Images:
               0x102cac000 -        0x102e09ff7  mds (800.30) <94155319-41BF-3E2B-AE1A-3C2C72FDA6C5> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
      Process:         mds_stores [149]
      Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       14919 pages
      Timers:          Coalesced
        Thread 0x433      DispatchQueue 1          priority 31
          12 ??? (mds_stores + 16522) [0x1057c808a]
        Thread 0x435      DispatchQueue 2          priority 33
        Thread 0xdb38     priority 31
        Thread 0xdb39     priority 31
        Thread 0xdb6b     priority 0
        Thread 0xdb6f     priority 0
        Binary Images:
               0x1057c4000 -        0x105801fff  mds_stores (800.30) <4BEDB4DF-3BA9-3846-BAD8-99C11A2F646A> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
      Process:         mdworker [328]
      Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      UID:             99
      Sudden Term:     Clean
      Task size:       49 pages
      IO Policy:       Throttle
      Timers:          Coalesced
      Note:            Background Priority
        Thread 0xb3d      priority 0
        Thread 0xb3e      priority 4
        Binary Images:
               0x10e142000 -        0x10e19dff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      Process:         mdworker [652]
      UID:             89
      Sudden Term:     Dirty
      Task size:       259 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0x2b76     DispatchQueue 1          priority 0
        Thread 0x2b77     DispatchQueue 2          priority 4
        Binary Images:
               0x106402000 -        0x10645dff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      Process:         mdworker [983]
      UID:             501
      Sudden Term:     Dirty
      Task size:       877 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0x752b     priority 0
        Thread 0x752d     priority 4
        Binary Images:
               0x10b3c4000 -        0x10b41fff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      Process:         mdworker [1722]
      Architecture:    unknown
      UID:             501
      Sudden Term:     Clean
      Task size:       2382 pages
      CPU Time:        0.001s
      IO Policy:       Throttle
      Timers:          Coalesced
      Note:            Exited before symbolication
        Thread 0xd172     DispatchQueue 1          priority 0
        12 ??? [0x7fff8b8f65fd]
          12 ??? [0x103d1b440]
                    12 ??? [0x7fff885b1a1a]
        Thread 0xd173     DispatchQueue 2          priority 4
        12 ??? [0x7fff8f0a8136]
          12 ??? [0x7fff885b6662]
        Thread 0xd178     priority    4-46   cpu time   0.001s
        12 ??? [0x7fff824aefc9]
          12 ??? [0x7fff824aa72a]
            12 ??? [0x7fff824aa899]
              12 ??? [0x103d1d437]
                12 ??? [0x103d18930]
                  12 ??? [0x103d165e3]
                    12 ??? [0x103d156e3]
                      12 ??? [0x103d2fba0]
                        12 ??? [0x7fff88640b02]
                          12 ??? [0x7fff8a9ec11d]
                            12 ??? [0x7fff8a9edfbb]
                              12 ??? [0x7fff89dcac58]
                                12 ??? [0x7fff89e51e49]
                                  12 ??? [0x7fff89dd1619]
                                    12 ??? [0x7fff89dd1811]
                                      12 ??? [0x7fff89dd1b28]
                                        12 ??? [0x7fff89e3034d]
                                          12 ??? [0x7fff89e2d3b5]
                                            12 ??? [0x7fff89e53656]
                                              11 ??? [0x7fff89dd6513]
                                                11 ??? [0x7fff88636bcf]
                                                  11 ??? [0x7fff88610905]
                                                    11 ??? [0x7fff88611221]
                                                      11 ??? [0x7fff88611617]
                                                        11 ??? [0x7fff8861186b]
                                                          11 ??? [0x7fff8861206d]
                                                            11 ??? [0x7fff885e190a]
                                                              11 ??? [0x7fff885b5622]
                                                               *11 hndl_unix_scall64 + 22 (mach_kernel) [0xffffff80002f4c86]
        *11 unix_syscall64 + 499 (mach_kernel) [0xffffff8000641a23]
        *11 open_nocancel + 258 (mach_kernel) [0xffffff80003e8162]
        *11 open1 + 309 (mach_kernel) [0xffffff80003e7775]
        *11 vn_open_auth + 214 (mach_kernel) [0xffffff80003f5616]
        *11 namei + 1460 (mach_kernel) [0xffffff80003d6584]
        *11 lookup + 603 (mach_kernel) [0xffffff80003d6c2b]
        *11 VNOP_LOOKUP + 75 (mach_kernel) [0xffffff80003fe22b]
        *9  hfs_vnop_lookup + 2270 (mach_kernel) [0xffffff800056b8ae]
        *9  throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
        *9  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
        *9  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
        *9  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
        *9  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
        *9  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
        *9  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
        *2  hfs_vnop_lookup + 1174 (mach_kernel) [0xffffff800056b466]
        *2  cat_lookup + 164 (mach_kernel) [0xffffff800055b174]
        *2  ??? (mach_kernel + 3519665) [0xffffff800055b4b1]
        *2  BTSearchRecord + 325 (mach_kernel) [0xffffff80005921c5]
        *2  SearchTree + 115 (mach_kernel) [0xffffff8000596073]
        *2  GetNode + 44 (mach_kernel) [0xffffff800059504c]
        *2  GetBTreeBlock + 178 (mach_kernel) [0xffffff8000559222]
        *2  buf_biowait + 122 (mach_kernel) [0xffffff80003c86aa]
        *2  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
        *2  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
        *2  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
        *2  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
        *2  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
        *2  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
                                              1  ??? [0x7fff89dd653e]
                                                1  ??? [0x7fff885e483e]
                                                  1  ??? [0x7fff885e5cc9]
                                                    1  ??? [0x7fff885b69f2]
                                                       *1  unix_syscall64 + 755 (mach_kernel) [0xffffff8000641b23]
                                                         *1  throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
        Binary Images:
      Process:         mdworker [1766]
      UID:             89
      Sudden Term:     Dirty
      Task size:       1635 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd67b     DispatchQueue 1          priority 4
          12 ??? (mdworker + 37952) [0x105ab9440]
        Thread 0xd683     DispatchQueue 2          priority 4
        Thread 0xd685     DispatchQueue 27         priority    4-46
          12 _pthread_wqthread + 314 (libsystem_pthread.dylib) [0x7fff824abef8]
            12 _dispatch_worker_thread2 + 40 (libdispatch.dylib) [0x7fff8f0a9177]
              12 _dispatch_root_queue_drain + 75 (libdispatch.dylib) [0x7fff8f0a7f87]
                12 _dispatch_queue_invoke + 110 (libdispatch.dylib) [0x7fff8f0a99c1]
                  12 _dispatch_queue_drain + 451 (libdispatch.dylib) [0x7fff8f0a8673]
                    12 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8f0a628d]
                      12 _dispatch_call_block_and_release + 12 (libdispatch.dylib) [0x7fff8f0a91bb]
                        12 ??? (mdworker + 221885) [0x105ae62bd]
                          12 ??? (mdworker + 221191) [0x105ae6007]
                            12 ??? (mdworker + 218015) [0x105ae539f]
                              12 ??? (mdworker + 219953) [0x105ae5b31]
                                12 SecStaticCodeCheckValidityWithErrors + 445 (Security) [0x7fff86403ae7]
                                  12 Security::CodeSigning::SecStaticCode::staticValidate(unsigned int, Security::CodeSigning::SecRequirement const*) + 138 (Security) [0x7fff8640cc90]
                                    12 Security::CodeSigning::SecStaticCode::validateResources(unsigned int) + 708 (Security) [0x7fff8640b6c4]
                                      12 Security::CodeSigning::ResourceBuilder::scan(void (_ftsent*, unsigned int, char const*, Security::CodeSigning::ResourceBuilder::Rule*) block_pointer) + 764 (Security) [0x7fff8641d576]
                                        12 fts_read$INODE64 + 291 (libsystem_c.dylib) [0x7fff8bd6cb3b]
                                          12 fts_build + 805 (libsystem_c.dylib) [0x7fff8bd6d387]
                                            12 lstat$INODE64 + 10 (libsystem_kernel.dylib) [0x7fff885b670a]
                                               *11 unix_syscall64 + 755 (mach_kernel) [0xffffff8000641b23]
                                                 *11 throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
                                                   *11 msleep + 114 (mach_kernel) [0xffffff80005e4e32]
                                                     *11 ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
                                                       *11 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
                                                         *11 thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
                                                           *11 ??? (mach_kernel + 224459) [0xffffff8000236ccb]
                                                             *11 machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
                                                 *1  lstat64 + 156 (mach_kernel) [0xffffff80003ea70c]
                                                   *1  ??? (mach_kernel + 2040970) [0xffffff80003f248a]
                                                     *1  vn_stat_noauth + 165 (mach_kernel) [0xffffff80003f6265]
                                                       *1  vnode_getattr + 119 (mach_kernel) [0xffffff80003fd1c7]
                                                         *1  hfs_vnop_getattr + 93 (mach_kernel) [0xffffff80005861bd]
                                                           *1  hfs_file_is_compressed + 152 (mach_kernel) [0xffffff8000585778]
                                                             *1  decmpfs_file_is_compressed + 469 (mach_kernel) [0xffffff80004157c5]
                                                               *1  ??? (mach_kernel + 2183342) [0xffffff80004150ae]
        *1  vn_getxattr + 405 (mach_kernel) [0xffffff80003f6a45]
        *1  VNOP_GETXATTR + 80 (mach_kernel) [0xffffff80004010b0]
        *1  hfs_vnop_getxattr + 268 (mach_kernel) [0xffffff800058dc0c]
        *1  hfs_getxattr_internal + 420 (mach_kernel) [0xffffff800058e084]
        *1  msleep + 114 (mach_kernel) [0xffffff80005e4e32]
        *1  ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
        *1  lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
        *1  thread_block_reason + 204 (mach_kernel) [0xffffff800023608c]
        *1  ??? (mach_kernel + 224459) [0xffffff8000236ccb]
        *1  machine_switch_context + 354 (mach_kernel) [0xffffff80002d8ab2]
        Thread 0xdb96     priority 4
        Binary Images:
               0x105ab0000 -        0x105b0bff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            0x7fff86332000 -     0x7fff865a2ff5  com.apple.security 7.0 (55471.14.38) <2A78FED8-45F0-32F1-9871-F28E76724D05> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x7fff8bd68000 -     0x7fff8bdf1ff7  libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
      Process:         mdworker [1767]
      UID:             501
      Sudden Term:     Dirty
      Task size:       1603 pages
      CPU Time:        0.001s
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd67c     DispatchQueue 1          priority 4
          12 ??? (mdworker + 37952) [0x101b94440]
        Thread 0xd67f     DispatchQueue 2          priority 4
        Thread 0xd680     DispatchQueue 27         priority 4          cpu time   0.001s
                        12 ??? (mdworker + 221885) [0x101bc12bd]
                          12 ??? (mdworker + 221191) [0x101bc1007]
                            12 ??? (mdworker + 218015) [0x101bc039f]
                              12 ??? (mdworker + 219953) [0x101bc0b31]
                                               *12 unix_syscall64 + 755 (mach_kernel) [0xffffff8000641b23]
                                                 *12 throttle_lowpri_io + 491 (mach_kernel) [0xffffff800040feeb]
                                                   *12 msleep + 114 (mach_kernel) [0xffffff80005e4e32]
                                                     *12 ??? (mach_kernel + 4082693) [0xffffff80005e4c05]
                                                       *12 lck_mtx_sleep + 78 (mach_kernel) [0xffffff800022d34e]
        Thread 0xdb7f     priority 4
        Binary Images:
               0x101b8b000 -        0x101be6ff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      Process:         mdworker [1768]
      UID:             99
      Sudden Term:     Dirty
      Task size:       1637 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd67d     DispatchQueue 1          priority 4
          12 ??? (mdworker + 37952) [0x10799d440]
        Thread 0xd687     DispatchQueue 2          priority 4
        Thread 0xd689     DispatchQueue 27         priority 4
                        12 ??? (mdworker + 221885) [0x1079ca2bd]
                          12 ??? (mdworker + 221191) [0x1079ca007]
                            12 ??? (mdworker + 218015) [0x1079c939f]
                              12 ??? (mdworker + 219953) [0x1079c9b31]
        Thread 0xdb88     priority 4
        Binary Images:
               0x107994000 -        0x1079efff7  mdworker (800.30) <271F3F93-1EC8-33A6-95A7-4E12B382844C> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
      Process:         mdworker [1772]
      UID:             501
      Sudden Term:     Clean
      Task size:       3284 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd750     DispatchQueue 1          priority 0
          12 ??? [0x10a913440]
            12 ??? [0x7fff886e5811]
              12 ??? [0x7fff8862fe75]
                12 ??? [0x7fff88630539]
                  12 ??? [0x7fff88630f15]
        Thread 0xd751     DispatchQueue 2          priority 4
        Thread 0xd786     priority 4
              12 ??? [0x10a914a6e]
                12 ??? [0x10a9173b1]
        Thread 0xd9ae     priority 4
              12 ??? [0x10a92a3a2]
        Binary Images:
      Process:         mdworker [1773]
      UID:             501
      Sudden Term:     Clean
      Task size:       3262 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd7f9     DispatchQueue 1          priority 0
          12 ??? [0x10c6ff440]
        Thread 0xd7fa     DispatchQueue 2          priority 4
        Thread 0xd892     priority 4
              12 ??? [0x10c700a6e]
                12 ??? [0x10c7033b1]
        Thread 0xd9a0     priority 4
              12 ??? [0x10c7163a2]
        Binary Images:
      Process:         mdworker [1778]
      UID:             501
      Sudden Term:     Clean
      Task size:       3007 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd82b     DispatchQueue 1          priority 0
          12 ??? [0x10c9e4440]
        Thread 0xd82c     DispatchQueue 2          priority 4
        Thread 0xd8ab     priority    4-46
              12 ??? [0x10c9e6437]
                12 ??? [0x10c9e1930]
                  12 ??? [0x10c9df5e3]
                    12 ??? [0x10c9de6e3]
                      12 ??? [0x10c9f8ba0]
                                        12 ??? [0x7fff89e302b6]
                                              11 ??? [0x7fff89dd653e]
                                                11 ??? [0x7fff885e483e]
                                                  11 ??? [0x7fff885e5cc9]
                                                    11 ??? [0x7fff885b55da]
                                                            1  ??? [0x7fff885e191e]
                                                              1  ??? [0x7fff8bd95619]
        1  ??? [0x7fff885b50c2]
        *1  getdirentries64 + 58 (mach_kernel) [0xffffff80003ee19a]
        *1  ??? (mach_kernel + 2022767) [0xffffff80003edd6f]
        *1  VNOP_READDIR + 134 (mach_kernel) [0xffffff80004008e6]
        *1  hfs_vnop_readdir + 1264 (mach_kernel) [0xffffff800058cd20]
        *1  cat_getdirentries + 652 (mach_kernel) [0xffffff800055f5ec]
        Thread 0xd9a1     priority 4
              12 ??? [0x10c9fb3a2]
        Binary Images:
      Process:         mdworker [1779]
      UID:             501
      Sudden Term:     Clean
      Task size:       2967 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd838     DispatchQueue 1          priority 0
          12 ??? [0x1003d0440]
        Thread 0xd83a     DispatchQueue 2          priority 4
        Thread 0xd8ff     priority 4
              12 ??? [0x1003d1a6e]
                12 ??? [0x1003d43b1]
        Thread 0xd99d     priority 4
              12 ??? [0x1003e73a2]
        Binary Images:
      Process:         mdworker [1782]
      UID:             89
      Sudden Term:     Clean
      Task size:       1827 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd8d1     DispatchQueue 1          priority 0
          12 ??? [0x10fca1440]
        Thread 0xd8f0     DispatchQueue 2          priority 4
        Thread 0xd96f     priority 4
              12 ??? [0x10fca2a6e]
                12 ??? [0x10fca53b1]
        Binary Images:
      Process:         mdworker [1783]
      UID:             89
      Sudden Term:     Clean
      Task size:       1905 pages
      CPU Time:        0.001s
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xd8d2     DispatchQueue 1          priority 0
          12 ??? [0x103cce440]
        Thread 0xd8f1     DispatchQueue 2          priority 4
        Thread 0xd97a     priority 4          cpu time   0.001s
              12 ??? [0x103cd0437]
                12 ??? [0x103ccb930]
                  12 ??? [0x103cc95e3]
                    12 ??? [0x103cc86e3]
                      12 ??? [0x103ce2ba0]
                                              12 ??? [0x7fff89dd653e]
                                                12 ??? [0x7fff885e483e]
                                                  12 ??? [0x7fff885e5cc9]
                                                    12 ??? [0x7fff885b55da]
        Binary Images:
      Process:         mdworker [1806]
      UID:             89
      Sudden Term:     Clean
      Task size:       1378 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xdae9     DispatchQueue 1          priority 0
          12 ??? [0x10a066440]
        Thread 0xdaec     DispatchQueue 2          priority 4
        Thread 0xdb30     priority 4
              12 ??? [0x10a068437]
                12 ??? [0x10a063930]
                  12 ??? [0x10a0615e3]
                    12 ??? [0x10a0606e3]
                      12 ??? [0x10a07aba0]
                                              12 ??? [0x7fff89dd6513]
                                                12 ??? [0x7fff88636bcf]
                                                  12 ??? [0x7fff88610905]
                                                    12 ??? [0x7fff88611221]
                                                      12 ??? [0x7fff88611617]
                                                        12 ??? [0x7fff8861186b]
                                                          12 ??? [0x7fff8861206d]
                                                            12 ??? [0x7fff885e191e]
                                                              12 ??? [0x7fff8bd95619]
        12 ??? [0x7fff885b50c2]
        Binary Images:
      Process:         mdworker [1807]
      UID:             89
      Sudden Term:     Clean
      Task size:       1367 pages
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0xdaf5     DispatchQueue 1          priority 0
          12 ??? [0x10476c440]
        Thread 0xdaf7     DispatchQueue 2          priority 4
        Thread 0xdb2e     priority 4
              12 ??? [0x10476da6e]
                12 ??? [0x1047703b1]
        Binary Images:
      Process:         netbiosd [155]
      Path:            /usr/sbin/netbiosd
      Parent:          launchd [1]
      UID:             222
      Sudden Term:     Clean
      Task size:       78 pages
      Importance:      Donating
      IO Policy:       Throttle
      Timers:          Coalesced
        Thread 0x4b0      DispatchQueue 2          priority 4
        Thread 0x4b2      DispatchQueue 7          priority 4
        12 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff885b5caa]
        Binary Images:
               0x106827000 -        0x106871fff  netbiosd (276.92.2) <ABAF29F3-2B81-3D82-A136-8F7B8AEE5BCB> /usr/sbin/netbiosd
      Process:         networkd [131]
      Path:            /usr/libexec/networkd
      Parent:          launchd [1]
      UID:             24
      Sudden Term:     Dirty (allows idle exit)
      Task size:       217 pages (+2)
      Importance:      Adaptive, Donating
      Timers:          Coalesced
        Thread 0x397      DispatchQueue 1          priority 31
        Thread 0x3a1      DispatchQueue 2          priority 33
        Thread 0xdc93     priority 31
        Binary Images:
               0x10f42d000 -        0x10f443ffb  networkd (241.4) <9C3ADF21-D905-35F0-A115-0FA625878705> /usr/libexec/networkd
      Process:         networkd_privileged [132]
      Path:            /usr/libexec/networkd_privileged
      Parent:          launchd [1]
      UID:             0
      Task size:       75 pages
      Timers:          Coalesced
        Thread 0x3a7      priority 31
        Thread 0x3a8      DispatchQueue 2          priority 33
        Binary Images:
               0x101ed6000 -        0x101ed7fff  networkd_privileged (241.4) <A27C872C-8CDC-32FE-BEBA-28E99A8AD463> /usr/libexec/networkd_privileged
      Process:         NotificationCenter [297]
      Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
      UID:             501
      Task size:       3855 pages
        Thread 0x96e      DispatchQueue 1          priority 46
          12 ??? (NotificationCenter + 8574) [0x10049417e]
              12 -[NSApplication run] + 553 (AppKit) [0x7fff82c7c99c]
                12 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122 (AppKit) [0x7fff82c8889b]
                  12 _DPSNextEvent + 1434 (AppKit) [0x7fff82c8924e]
                    12 _BlockUntilNextEventMatchingListInModeWithFilter + 65 (HIToolbox) [0x7fff8da4e5bc]
                      12 ReceiveNextEventCommon + 479 (HIToolbox) [0x7fff8da4e7b7]
                        12 RunCurrentEventLoopInMode + 226 (HIToolbox) [0x7fff8da4ea0d]
        Thread 0x977      DispatchQueue 2          priority 48
        Thread 0x9b6      priority 46
        Thread 0xdb7c     priority    0-46
        Binary Images:
               0x100492000 -        0x1004fbff7  com.apple.notificationcenterui 1.0 (222.6) <FBCB0F74-B206-3EEC-A154-D298710521E7> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
      Process:         notifyd [69]
      Path:            /usr/sbin/notifyd
      Parent:          launchd [1]
      UID:             0
      Task size:       236 pages
      CPU Time:        0.001s
      Timers:          Coalesced
        Thread 0x173      DispatchQueue 2          priority 33
        Thread 0x174      DispatchQueue 7          priority 31
        12 ??? [0x7fff885b5caa]
        Thread 0xdb80     priority 31         cpu time   0.001s
        12 ??? [0x7fff824aefb9]
          12 ??? [0x7fff885b5e6a]
        Binary Images:
      Process:         ntpd [145]
      Path:            /usr/sbin/ntpd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       74 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x407      priority 31
          12 ??? (ntpd + 139329) [0x1037ff041]
            12 ??? (ntpd + 140489) [0x1037ff4c9]
              12 __sigsuspend + 10 (libsystem_kernel.dylib) [0x7fff885b5c92]
        Thread 0x58d      priority 33
        Binary Images:
               0x1037dd000 -        0x10382bffb  ntpd (88.1.3) <B89294DA-B32B-36A6-97BB-6550E91ADDD6> /usr/sbin/ntpd
      Process:         ocspd [1704]
      Path:            /usr/sbin/ocspd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       482 pages
      Timers:          Coalesced
        Thread 0xd006     DispatchQueue 1          priority 31
          12 ??? (ocspd + 14343) [0x10eb02807]
            12 ??? (ocspd + 49207) [0x10eb0b037]
              12 ??? (ocspd + 49812) [0x10eb0b294]
        Thread 0xd95d     priority 31
              12 ??? (ocspd + 54856) [0x10eb0c648]
                12 ??? (ocspd + 51295) [0x10eb0b85f]
        Binary Images:
               0x10eaff000 -        0x10eb14ff7  ocspd (55118.2) <3A50C0BE-819D-3CAD-B5B0-AC38F73DCA73> /usr/sbin/ocspd
      Process:         opendirectoryd [31]
      Path:            /usr/libexec/opendirectoryd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       972 pages
      Timers:          Coalesced
        Thread 0x17f      DispatchQueue 2          priority 33
        Thread 0x1c6      DispatchQueue 6          priority 31
              12 _dispatch_root_queue_drain + 326 (libdispatch.dylib) [0x7fff8f0a8082]
                    12 ??? (opendirectoryd + 141915) [0x103541a5b]
        Thread 0x1d3      DispatchQueue 6          priority 31
        Thread 0x1bb      DispatchQueue 697        priority 31
                  12 _dispatch_async_redirect_invoke + 154 (libdispatch.dylib) [0x7fff8f0aa7e3]
                        12 __identitysvc + 10 (libsystem_kernel.dylib) [0x7fff885b521a]
        Thread 0x182      priority 31
        Thread 0x1bc      priority 31
        Thread 0xdbc6     priority 31
        Thread 0xdbc7     priority 31
        Thread 0xdbc8     priority 31
        Binary Images:
               0x10351f000 -        0x10357cff5  opendirectoryd (339.102.1) <53D60D86-6994-34BA-B5BE-DF052B38E1FA> /usr/libexec/opendirectoryd
      Process:         pacemaker [147]
      Path:            /usr/libexec/pacemaker
      Parent:          launchd [1]
      UID:             0
      Task size:       36 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x41c      DispatchQueue 2          priority 33
        Thread 0x41f      priority 31
        Thread 0x431      priority 0
        Binary Images:
               0x10c94c000 -        0x10c94eff2  pacemaker (3) <FFFA27F0-4343-3A48-9D66-7F12DC2DCB33> /usr/libexec/pacemaker
      Process:         pboard [196]
      Path:            /usr/sbin/pboard
      UID:             501
      Sudden Term:     Clean
      Task size:       9 pages
      Timers:          Coalesced
        Thread 0x615      priority 31
          12 ??? (pboard + 2536) [0x10b2029e8]
            12 mach_msg_server + 544 (libsystem_kernel.dylib) [0x7fff885b1613]
        Binary Images:
               0x10b202000 -        0x10b202fff  pboard (855.17) <796C413E-3229-3795-92F8-61CD3D7B1BE5> /usr/sbin/pboard
      Process:         pbs [1680]
      Path:            /System/Library/CoreServices/pbs
      UID:             501
      Sudden Term:     Clean (allows idle exit)
      Task size:       326 pages
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0xcd7f     DispatchQueue 2          priority 4
        Thread 0xcd80     DispatchQueue 7          priority 4
        Binary Images:
               0x10be60000 -        0x10be72ff7  pbs (278) <73E78ED2-9F6A-3EC5-8365-89EDD69C7A96> /System/Library/CoreServices/pbs
      Process:         PenTabletDriver [356]
      Path:            /Library/Application Support/Tablet/PenTabletDriver.app/Contents/MacOS/PenTabletDriver
      UID:             501
      Task size:       870 pages (+2)
      IO Policy:       Standard
      Process:         powerd [28]
      Path:            /System/Library/CoreServices/powerd.bundle/powerd
      Parent:          launchd [1]
      UID:             0
      Task size:       208 pages
      Timers:          Coalesced
        Thread 0x12d      DispatchQueue 1          priority 31
          12 main + 1870 (powerd) [0x1098d5307]
            12 CFRunLoopRun + 97 (CoreFoundation) [0x7fff886e5811]
        Thread 0x189      DispatchQueue 2          priority 33
        Thread 0xdb9b     priority    0-31
        Binary Images:
               0x1098d3000 -        0x1098f1ff7  powerd (420.90.1) <83C854AA-0FB9-30C2-8443-D10D781E0E25> /System/Library/CoreServices/powerd.bundle/powerd
      Process:         revisiond [27]
      Path:            /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisi ond
      Parent:          launchd [1]
      UID:             0
      Task size:       279 pages
      Timers:          Coalesced
        Thread 0x1b3      DispatchQueue 2          priority 33
        Thread 0x237      DispatchQueue 7          priority 31
        Thread 0x233      priority 31
             *12 read_nocancel + 127 (mach_kernel) [0xffffff80005f2ebf]
               *12 ??? (mach_kernel + 4141230) [0xffffff80005f30ae]
                 *12 ??? (mach_kernel + 2050245) [0xffffff80003f48c5]
                   *12 VNOP_READ + 225 (mach_kernel) [0xffffff80003fed11]
                     *12 spec_read + 253 (mach_kernel) [0xffffff800040e0dd]
                       *12 cdev_read + 99 (AppleFSCompressionTypeDataless) [0xffffff7f820039ab]
        Thread 0x234      priority 47
        12 fsctl + 10 (libsystem_kernel.dylib) [0x7fff885b62ea]
             *12 fsctl + 282 (mach_kernel) [0xffffff80003efb6a]
               *12 ??? (mach_kernel + 2031348) [0xffffff80003efef4]
                 *12 ??? (mach_kernel + 2039227) [0xffffff80003f1dbb]
        Binary Images:
               0x1073ca000 -        0x10741cff7  revisiond (160.3) <D47873DF-3407-3625-982D-4E80B7D4B8DC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisi ond
      *0xffffff7f82002000 - 0xffffff7f82003ff7  com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 56.92.2 (1.0.0d1) <04E5B099-150C-3EDC-A3E9-3375A74F9A35> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSComp ressionTypeDataless
      Process:         secd [206]
      Path:            /usr/libexec/secd
      UID:             501
      Task size:       278 pages (+2)
      Timers:          Coalesced
        Thread 0x69a      priority 31
        Thread 0x69b      DispatchQueue 2          priority 33
        Thread 0xdc8a     priority 31
        Binary Images:
               0x1097d9000 -        0x10984cff1  secd (55471.14.38) <0617D110-6751-370C-BAFE-B74DF7A7B5C8> /usr/libexec/secd
      Process:         securityd [25]
      Path:            /usr/sbin/securityd
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       597 pages (+2)
      Importance:      Adaptive, Boosted, Donating
      Timers:          Coalesced
        Thread 0x12a      DispatchQueue 1          priority 31
          12 ??? (securityd + 238216) [0x10d7db288]
            12 ??? (securityd + 487785) [0x10d818169]
              12 ??? (securityd + 47080) [0x10d7ac7e8]
        Thread 0x2cc      DispatchQueue 2          priority 33
        Thread 0x1cb      priority 31
              12 ??? (securityd + 46190) [0x10d7ac46e]
                12 ??? (securityd + 375618) [0x10d7fcb42]
                  12 au_sdev_read_aia + 570 (libbsm.0.dylib) [0x7fff8a68eac5]
                    12 fgetc + 44 (libsystem_c.dylib) [0x7fff8bda468e]
                      12 __srget + 14 (libsystem_c.dylib) [0x7fff8bdaaff5]
                        12 __srefill1 + 24 (libsystem_c.dylib) [0x7fff8bdaaedb]
                          12 __read_nocancel + 10 (libsystem_kernel.dylib) [0x7fff885b58ea]
                                         *12 ??? (mach_kernel + 3850633) [0xffffff80005ac189]
        Thread 0xd703     priority 31
                12 ??? (securityd + 46301) [0x10d7ac4dd]
        Thread 0xd704     priority 31
        Thread 0xdc82     priority 31
        Binary Images:
               0x10d7a1000 -        0x10d85bff7  securityd (55199.3) <EC50266C-46EF-327F-A9A8-E7CAE8FA9903> /usr/sbin/securityd
            0x7fff8a680000 -     0x7fff8a690fff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
      Process:         securityd_service [183]
      Path:            /usr/libexec/securityd_service
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       89 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x5c0      priority 31
        Thread 0x5c2      DispatchQueue 2          priority 33
        Binary Images:
               0x10447e000 -        0x104483ff7  securityd_service (55199.3) <DDEC98C2-B102-3868-9A54-B969B7325BE2> /usr/libexec/securityd_service
      Process:         sharingd [291]
      Path:            /usr/libexec/sharingd
      UID:             501
      Task size:       6 pages
      Timers:          Coalesced
        Thread 0x8ef      priority 31
        Thread 0x8f2      priority 33
        Binary Images:
               0x10abf3000 -        0x10ac3ffff  sharingd (132.2) <C4FA4877-6F18-3715-A5C8-DEDF9026BDF9> /usr/libexec/sharingd
      Process:         Silver Efex Pro 2 [251]
      Path:            /Applications/Nik Collection/Silver Efex Pro 2.app/Contents/MacOS/Silver Efex Pro 2
      UID:             501
      Task size:       3102 pages
      IO Policy:       Standard
      Timers:          Limited
      Process:         SleepServicesD [24]
      Path:            /System/Library/CoreServices/SleepServicesD
      Parent:          launchd [1]
      UID:             0
      Task size:       6 pages
      Importance:      Background Priority
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x129      priority 4
        Thread 0x159      priority 4
        Binary Images:
               0x105b8e000 -        0x105b94ff7  SleepServicesD (1.51) <18F75DE2-A8E5-333A-8ABA-B408CF80DB88> /System/Library/CoreServices/SleepServicesD
      Process:         soagent [305]
      Path:            /System/Library/PrivateFrameworks/MessagesKit.framework/Resources/soagent.app/Contents/Ma cOS/soagent
      UID:             501
      Task size:       805 pages (+2)
      IO Policy:       Utility
      Timers:          Coalesced
        Thread 0x9b3      DispatchQueue 1          priority 4
          12 ??? (soagent + 7131) [0x10bc4bbdb]
            12 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff8a4d0aca]
              12 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 253 (Foundation) [0x7fff8a3e80fc]
        Thread 0x9b7      DispatchQueue 2          priority 4
        Thread 0xdca1     priority 4
        Binary Images:
               0x10bc4a000 -        0x10bc4bfff  com.apple.soagent 7.0 (4048) <223E40C2-A372-3C73-BC37-737AAE083362> /System/Library/PrivateFrameworks/MessagesKit.framework/Resources/soagent.app/Contents/Ma cOS/soagent
            0x7fff8a37f000 -     0x7fff8a67fff7  com.apple.Foundation 6.9 (1056.17) <E0B0FAF6-5CA8-3EEB-8BF2-104C0AEEF925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      Process:         SocialPushAgent [331]
      Path:            /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
      UID:             501
      Task size:       6 pages
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0xb51      priority 31
        Thread 0xb6f      priority 33
        Binary Images:
               0x10fd0e000 -        0x10fd22ff7  com.apple.SocialPushAgent 25 (25) <3F601C45-6373-3800-ABFC-6FC580D5A5F0> /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
      Process:         socketfilterfw [148]
      Path:            /usr/libexec/ApplicationFirewall/socketfilterfw
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Clean
      Task size:       812 pages (+2)
      IO Policy:       Standard
      Timers:          Coalesced
        Thread 0x428      DispatchQueue 1          priority 31
          12 ??? (socketfilterfw + 27400) [0x10187eb08]
            12 ??? (socketfilterfw + 18979) [0x10187ca23]
        Thread 0x42c      DispatchQueue 2          priority 33
        Thread 0x42e      priority 31
        Thread 0xdc8c     priority 31
        Binary Images:
               0x101878000 -        0x101888fff  socketfilterfw (153) <0DCA246B-9528-3599-8D87-DECC235AA25A> /usr/libexec/ApplicationFirewall/socketfilterfw
      Process:         softwareupdated [1795]
      Path:            /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
      Parent:          launchd [1]
      UID:             200
      Task size:       7765 pages
      Pageins:         1 pages
      Timers:          Coalesced
        Thread 0xd9bf     DispatchQueue 1          priority 31
          12 ??? (softwareupdated + 3552) [0x105c1bde0]
                11 __CFRunLoopRun + 1161 (CoreFoundation) [0x7fff88630539]
                  11 __CFRunLoopServiceMachPort + 181 (CoreFoundation) [0x7fff88630f15]
                    11 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff885b1a1a]
                1  __CFRunLoopRun + 1636 (CoreFoundation) [0x7fff88630714]
                  1  __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9 (CoreFoundation) [0x7fff886754f9]
                    1  _dispatch_main_queue_callback_4CF + 333 (libdispatch.dylib) [0x7fff8f0adef0]
                      1  _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff8f0a628d]
                        1  _dispatch_call_block_and_release + 12 (libdispatch.dylib) [0x7fff8f0a91bb]
                          1  -[PKInstallClient _finishInstallClientOnMainThreadWithError:] + 180 (PackageKit) [0x7fff8be25751]
                            1  __destroy_helper_block_341 + 32 (SoftwareUpdate) [0x7fff8b8bb320]
                                 *1  vm_fault + 2660 (mach_kernel) [0xffffff8000278f14]
        Thread 0xda07     DispatchQueue 2          priority 33
        Thread 0xda0c     DispatchQueue 10         priority 0
                    12 __215-[SUUpdateSession startUpdateForProducts:usingClientAuthorization:inForeground:holdingBoostDuringInstall:st ageInstall:clientBlocksRestart:allowOnlyAppleSigned:packageScriptUserID:sendingStatusUpdat es:replyWhenDone:]_block_invoke + 1943 (SoftwareUpdate) [0x7fff8b8a704f]
                      12 -[SUUpdateSession _installProducts:authorization:holdingBoostDuringInstall:stageInstall:clientBlocksRestart :allowOnlyAppleSigned:packageScriptUserID:] + 1738 (SoftwareUpdate) [0x7fff8b8a53e3]
                        12 -[SUInstallOperation main] + 1166 (SoftwareUpdate) [0x7fff8b873531]
                          12 -[NSRunLoop(SUAdditions) _runUntilCondition:periodicAction:] + 163 (SoftwareUpdate) [0x7fff8b892125]
                            12 -[NSRunLoop(NSRunLoop) runUntilDate:] + 78 (Foundation) [0x7fff8a43072b]
        Thread 0xda04     priority   31-33
        Thread 0xda80     priority 63
              12 __NSThread__main__ + 1318 (Foundation) [0x7fff8a3e5d8b]
                12 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348 (Foundation) [0x7fff8a3e5f87]
        Thread 0xda9b     priority 31
        Thread 0xdb6c     priority 31
              12 WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore) [0x7fff8aa0ff4f]
                7  JSC::BlockAllocator::blockFreeingThreadMain() + 117 (JavaScriptCore) [0x7fff8aa1ac25]
                  7  WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 118 (JavaScriptCore) [0x7fff8aa1b106]
                    7  __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff885b5716]
                     *7  psynch_cvcontinue + 0 (pthread) [0xffffff7f80bcf940]
                5  JSC::BlockAllocator::blockFreeingThreadMain() + 261 (JavaScriptCore) [0x7fff8aa1acb5]
                  5  __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff885b5716]
                   *5  psynch_cvcontinue + 0 (pthread) [0xffffff7f80bcf940]
        Thread 0xdb6d     priority 31
                12 JSC::GCThread::gcThreadMain() + 88 (JavaScriptCore) [0x7fff8aa1b5b8]
                  12 JSC::GCThread::waitForNextPhase() + 119 (JavaScriptCore) [0x7fff8aa1b727]
        Thread 0xdba1     priority 31
        Binary Images:
               0x105c1b000 -        0x105c1bfff  softwareupdated (574.6) <188D485A-1DB2-325C-A2CD-CE6AC0C1486D> /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
            0x7fff8aa07000 -     0x7fff8ad7eff6  com.apple.JavaScriptCore 9537 (9537.78.1) <8623A109-9E9D-3E3B-A8E1-6EE447C0110C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x7fff8b85b000 -     0x7fff8b8e6ff7  com.apple.SoftwareUpdate.framework 6 (574.6) <A83587ED-67AE-3FB0-9494-6EAEFEF4B17D> /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Versions/A/SoftwareUpdate
      Process:         spindump [1809]
      Path:            /usr/sbin/spindump
      Parent:          launchd [1]
      UID:             0
      Sudden Term:     Dirty
      Task size:       1112 pages (+932)
      Pageins:         1 pages
      CPU Time:        0.058s
      IO Policy:       Throttle
        Thread 0xdbbb     DispatchQueue 1          priority 29
          12 ??? (spindump + 6258) [0x10f92a872]
        Thread 0xdbc1     DispatchQueue 2          priority 33         cpu time   0.004s
        Thread <multiple> DispatchQueue 15         priority 31         cpu time   0.037s
                  12 _dispatch_queue_drain + 359 (libdispatch.dylib) [0x7fff8f0a8617]
                    12 _dispatch_source_invoke + 413 (libdispatch.dylib) [0x7fff8f0a8885]
                        12 __syscall + 10 (libsystem_kernel.dylib) [0x7fff885b5d3a]
                             *12 stack_snapshot2 + 376 (mach_kernel) [0xffffff80005b38b8]
        Thread 0xdbc2     priority 31
        11 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          11 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *11 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        1  __pthread_set_self + 16 (libsystem_pthread.dylib) [0x7fff824aefac]
         *1  wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Thread 0xdc0f     priority 31
        Thread 0xdc11     priority 31
        10 start_wqthread + 13 (libsystem_pthread.dylib) [0x7fff824aefb9]
          10 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff885b5e6a]
           *10 wq_unpark_continue + 0 (pthread) [0xffffff7f80bcd6ae]
        Thread 0xdc13     priority 31
        Thread 0xdc14     priority 31
        Thread 0xdc15     priority 31
        Thread 0xdc16     priority 31
        Thread 0xdc17     priority 31
        Thread 0xdc18     priority 31
        Thread 0xdc19     priority 31
        Thread 0xdc1a     priority 31
        Thread 0xdc1b     priority 31
        Thread 0xdc1c     priority 31
        Thread 0xdc1d     priority 31
        Thread 0xdc1e     priority 31
        Thread 0xdc1f     priority 31
        Thread 0xdc20     priority 31
        Thread 0xdc21     priority 31
        Thread 0xdc22     priority 31
        Thread 0xdc23     priority 31
        Thread 0xdc24     priority 31
        Thread 0xdc25     priority 31
        Thread 0xdc26     priority 31
        Thread 0xdc27     priority 31
        Thread 0xdc28     priority 31
        Thread 0xdc29     priority 31
        Thread 0xdc2a     priority 31
        Thread 0xdc2b     priority 31
        Thread 0xdc2c     priority 31
        Thread 0xdc2d     priority 31
        Thread 0xdc2e     priority 31
        Thread 0xdc2f     priority 31
        Thread 0xdc30     priority 31
        Thread 0xdc31     priority 31
        Thread 0xdc32     priority 31
        Thread 0xdc33     priority 31
        Thread 0xdc34     priority 31
        Thread 0xdc35     priority 31
        Thread 0xdc36     priority 31
        Thread 0xdc37     priority 31
        Thread 0xdc38     priority 31
        Thread 0xdc39     priority 31
        Thread 0xdc3a     priority 31
        Thread 0xdc3b     priority 31
        Thread 0xdc3c     priority 31
        Thread 0xdc3d     priority 31
        Thread 0xdc3e     priority 31
        Thread 0xdc3f     priority 31
        Thread 0xdc40     priority 31
        Thread 0xdc41     priority 31
        Thread 0xdc42     priority 31
        Thread 0xdc43     priority 31
        Thread 0xdc44     priority 31
        Thread 0xdc45     priority 31
        Thread 0xdc46     priority 31
        Thread 0xdc47     priority 31
        Thread 0xdc48     priority 31
        Thread 0xdc49     priority 31
        Thread 0xdc4a     priority 31
        Thread 0xdc4b     priority 31
        Thread 0xdc4c     priority 31
        Thread 0xdc4d     priority 31
        Thread 0xdc4e     priority 31
        Thread 0xdc4f     priority 31
        Thread 0xdc50     priority 31
        Thread 0xdc51     priority 31
        Thread 0xdc52     priority 31
        Thread 0xdc53     priority 31
        Thread 0xdc54     priority 31
        Thread 0xdc55     priority 31
        Thread 0xdc56     priority 31
        Thread 0xdc57     priority 31
        Thread 0xdc58     priority 31
        Thread 0xdc59     priority 31
        Thread 0xdc5a     priority 31
        Thread 0xdc5b     priority 31
        Thread 0xdc5c     priority 31
        Thread 0xdc5d     priority 31
        Thread 0xdc5e     priority 31
        Thread 0xdc5f     priority 31
        Thread 0xdc60     priority 31
        Thread 0xdc61     priority 31
        Thread 0xdc62     priority 31
        Thread 0xdc63     priority 31
        Thread 0xdc64     priority 31
        Thread 0xdc65     priority 31
        Thread 0xdc66     priority 31
        Thread 0xdc67     priority 31
        Thread 0xdc68     priority 31
        Thread 0xdc69     priority 31
        Thread 0xdc6a     priority 31
        Thread 0xdc6b     priority 31
        Thread 0xdc6d     priority 31
      *11 wq_unsuspend_continue + 0 (pthread) [0xffffff7f80bcd7c4]
        Thread 0xdbc3     priority 31
        Thread 0xdbd0     priority 31
        Thread 0xdbd1     priority 31
        Thread 0xdbd2     priority 31
        Thread 0xdbd3     priority 31
        Thread 0xdbd4     priority 31
        Thread 0xdbd6     priority 31
        Thread 0xdbd7     priority 31
        Thread 0xdbd8     priority 31
        Thread 0xdbd9     priority 31
        Thread 0xdbda     priority 31
        Thread 0xdbdb     priority 31
        Thread 0xdbdc     priority 31
        Thread 0xdbdd     priority 31
        Thread 0xdbde     priority 31
        Thread 0xdbe0     priority 31
        Thread 0xdbe1     priority 31
        Thread 0xdbe2     priority 31
        Thread 0xdbe3     priority 31
        Thread 0xdbe4     priority 31
        Thread 0xdbe5     priority 31
        Thread 0xdbe6     priority 31
        Thread 0xdbe7     priority 31
        Thread 0xdbe8     priority 31
        Thread 0xdbe9     priority 31
        Thread 0xdbea     priority 31
        Thread 0xdbeb     priority 31
        Thread 0xdbec     priority 31
        Thread 0xdbed     priority 31
        Thread 0xdbee     priority 31
        Thread 0xdbef     priority 31
        Thread 0xdbf0     priority 31
        Thread 0xdbf1     priority 31
        Thread 0xdbf2     priority 31
        Thread 0xdbf3     priority 31
        Thread 0xdbf4     priority 31
        Thread 0xdbf5     priority 31
        Thread 0xdbf6     priority 31
        Thread 0xdbf7     priority 31
        Thread 0xdbf8     priority 31
        Thread 0xdbf9     priority 31
        Thread 0xdbfa     priority 31
        Thread 0xdbfb     priority 31
        Thread 0xdbfc     priority 31
        Thread 0xdbfd     priority 31
        Thread 0xdbfe     priority 31
        Thread 0xdbff     priority 31
        Thread 0xdc00     priority 31
        Thread 0xdc01     priority 31
