18 Replies Latest reply on Oct 25, 2015 8:28 AM by Just Shoot Me
    Lightroom CC crashes constantly
    Dan Power Photography
      I am experiencing crippling issues with LR CC crashing several times a day, sometimes up to several times an hour.  It's crashed twice in the last ten minutes.
      I have tried disabling graphics acceleration, doesn't seem to have helped although I have only done it recently.  It has crashed since then though.
      Searching these forums didn't turn up much, any Adobe staff care to help or has someone had a similar problem and resolved it?
      Thanks.
        • 1. Re: Lightroom CC crashes constantly
          Mrinmay Majhi Adobe Employee
          Hi Dan,
          I believe you have disabled the Display Processor use from Lightroom preferences. You should not be facing the crashing issue now.
          If in case Lightroom crahses again, please provide the below information.
          > Which version of Lightroom are you using?
          > Which operating system are you using?
          > Please post the error log.
          ~Mrinmay
          • 2. Re: Lightroom CC crashes constantly
            Just Shoot Me Adobe Community Professional
            There are many reports of LR crashing. To be able to help you we need the exact version of LR you are using, the exact version of the operating system your computer is running and the amount of RAM you have installed.
            99% of the time the crashes are caused by faulty hardware most likely a RAM issue. Although the most current version of LR, 2015.2.1/6.2.1, is loaded with BUGS. So it might help reverting to an earlier version like 2015.1.1/6.1.1.
            • 3. Re: Lightroom CC crashes constantly
              Dan Power Photography Level 1
              Hi Mrinmay,
              Sorry I should have included all that in the original post.  I'm using the current, up to date version of LR CC.  Here's a paste from the System Info box:
              Lightroom version: CC 2015.2.1 [ 1046594 ]
              License: Creative Cloud
              Operating system: Mac OS 10
              Version: 10.11 [0]
              Application architecture: x64
              Logical processor count: 8
              Processor speed: 2.8 GHz
              Built-in memory: 16,384.0 MB
              Real memory available to Lightroom: 16,384.0 MB
              Real memory used by Lightroom: 1,179.3 MB (7.1%)
              Virtual memory used by Lightroom: 2,239.6 MB
              Memory cache size: 953.0 MB
              Maximum thread count used by Camera Raw: 8
              Camera Raw SIMD optimization: SSE2,AVX,AVX2
              Displays: 1) 3360x2100
              Graphics Processor Info:
              NVIDIA GeForce GT 750M OpenGL Engine
              Check OpenGL support: Passed
              Vendor: NVIDIA Corporation
              Version: 4.1 NVIDIA-10.6.42 310.42.05f01
              Renderer: NVIDIA GeForce GT 750M OpenGL Engine
              LanguageVersion: 4.10
              Application folder: /Applications/Adobe Lightroom
              Library Path: /Users/dishwasher/Photography/Catalogues/Dan Power Photography/Dan Power Photography.lrcat
              Settings Folder: /Users/dishwasher/Library/Application Support/Adobe/Lightroom
              Installed Plugins:
              1) Aperture/iPhoto Importer Plug-in
              2) Canon Tether Plugin
              3) DxO OpticsPro 10
              4) DxO OpticsPro 10 Importer
              5) Facebook
              6) Flickr
              7) Leica Tether Plugin
              8) Nikon Tether Plugin
              Config.lua flags: None
              AudioDeviceIOBlockSize: 512
              AudioDeviceName: JBL Flip 2
              AudioDeviceNumberOfChannels: 2
              AudioDeviceSampleRate: 44100
              Build: Uninitialized
              CoreImage: true
              GL_ACCUM_ALPHA_BITS: 0
              GL_ACCUM_BLUE_BITS: 0
              GL_ACCUM_GREEN_BITS: 0
              GL_ACCUM_RED_BITS: 0
              GL_ALPHA_BITS: 8
              GL_BLUE_BITS: 8
              GL_DEPTH_BITS: 24
              GL_GREEN_BITS: 8
              GL_MAX_3D_TEXTURE_SIZE: 2048
              GL_MAX_TEXTURE_SIZE: 16384
              GL_MAX_TEXTURE_UNITS: 8
              GL_MAX_VIEWPORT_DIMS: 16384,16384
              GL_RED_BITS: 8
              GL_RENDERER: NVIDIA GeForce GT 750M OpenGL Engine
              GL_SHADING_LANGUAGE_VERSION: 1.20
              GL_STENCIL_BITS: 8
              GL_VENDOR: NVIDIA Corporation
              GL_VERSION: 2.1 NVIDIA-10.6.42 310.42.05f01
              GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
              Where do I find the error log?
              • 4. Re: Lightroom CC crashes constantly
                Also it's worth noting that this laptop has had a brand spanking new SSD installed under warranty, was having some issues with the old one which I thought were causing the crashing but it's persisted after the new drive was installed.
                Cheers.
                • 5. Re: Lightroom CC crashes constantly
                  Hi Dan,
                  Is your Lightroom application still crashing?
                  ~Mrinmay
                  • 6. Re: Lightroom CC crashes constantly
                    If these crashes started before you upgraded to OS X 10.11 and or you installed LR 2015.2.1 then it is a hardware problem. More than likely a RAM problem.
                    "IF" you never had LR installed before and this is a New Mac that came with OS X 10.11 there are some serious bugs in the most current release of LR that are causing all kinds of problems on OS X 10.x. So much so Adobe originally release 2015.2 then just 4 days later released 2015.2.1 to correct Some of the problems but not all.
                    • 7. Re: Lightroom CC crashes constantly
                      Thanks, they have been happening for a while now so definitely before I updated to OSX10.11 (did that last week) and probably since before I updated LR last.  But they haven't been happening since day 1 of having this machine... they started about three months after I bought it (which was about six months ago).
                      I don't have issues with ANY other software.  I had an issue with some bad sectors on the PCI-e SSD which was causing VLC to crash and then the thing wouldn't start and needed to be restored from a backup.  That happened twice in three months so I took it back to Apple and last week they put a new SSD in (the part alone was over a grand, lucky it was under warranty!) and it's been purring along nicely ever since.
                      Where does LR store it's error log file?  If there is something in there that can help me convince Apple that there's a RAM problem, I'll take it in there and get them to replace it.  They were AMAZING about the SSD... all the Apple diagnostic software said it was fine but I ran the S.M.A.R.T utility in front of the guy and it showed up a whole bunch of errors.. he ordered the part in front of me, three days later I took it back in they put a new drive in it in 20 minutes.  So it shouldn't be a problem doing the same with the RAM as long as I can show them some clear evidence...
                      • 8. Re: Lightroom CC crashes constantly
                        If this is on a Retina MBP the only way to change the RAM is to replace the whole, complete, logic board (Motherboard) as the RAM is soldered onto the board.
                        I suggest you download and run Memtest86 and let it run overnight to test out the RAM.
                        • 9. Re: Lightroom CC crashes constantly
                          Will do, thanks heaps for the ideas!
                          • 11. Re: Lightroom CC crashes constantly
                            Also if you haven't done this already I suggest you buy the AppleCare extended warranty. You have up to one year from date of purchase to buy the extended warranty. It will add 2 more years to the warranty and as you have found out to repair a Mac after the warranty runs out is VERY expensive. So much so it is cheaper to buy a new computer.
                            Best of luck to you.
                            • 12. Re: Lightroom CC crashes constantly
                              Thanks, already writing the image to the USB key
                              I tossed up getting AppleCare but in Aus consumer law requires them to warranty it against defects for "a reasonable period of time" which is the amount of time someone would expect the product to last.... Apple themselves consider this to be two years, so after 12 months but before 24 months you're pretty much guaranteed they won't argue about warranty... if you were good at arguing you could probably get most stuff repaired in the third year... my last laptop lasted five years and the one before lasted seven, so it's perfectly 'reasonable' to request warranty service within three years..
                              That being said they would probably make life a bit difficult in the second year and definitely in the third year and beyond...
                              Dunno.  I have a few more months to buy Applecare so will think about it a bit more.  As you say though parts are damn expensive so maybe it's worth just throwing $300 away to make life a bit easier
                              • 13. Re: Lightroom CC crashes constantly
                                Oh how long does memtest usually take to run on today's machines, is it definitely an overnight job?
                                Ta.
                                • 14. Re: Lightroom CC crashes constantly
                                  Yes it is an Overnight affair. For Memtest to really do its job it need to run many passes. For that to happen it needs to run for many hours. Although when I had some Really Bad RAM it only took a few minutes to turn up errors so there was no need to let it run longer. On questionable RAM the first pass might not find anything wrong but subsequent passes taxes the RAM more and will show errors if there are any.
                                  IMHO running it overnight is the only way to be sure the RAM is or isn't the problem.
                                  Sorry but Apple computers aren't any better built, don't use any better hardware, than what you find in any other brand computer. They just cost more, have sleek cases, run an alternative operating system and have the Apple Logo on them.
                                  I used Mac's for a while and switched back to Windows PCs. Personally I will never buy another Apple product.
                                  • 15. Re: Lightroom CC crashes constantly
                                    Sweet, will run it tonight.
                                    Agree with you about the comparison, although I do REALLY like how thin and light it is.  Screen is pretty amazing too (Retina MBP).  But it doesn't run *that* much quicker than my much lower specced PC and TBH Lightroom runs quite slowly comparatively, loading images (until the histogram pops up) can take several seconds and sometimes five to ten.  I only bought this cause my old one was stolen and the insurance company literally wrote me a blank cheque, said "go get whatever you want," I'd never have paid what I (they) did for this otherwise.  At least if I decide I want to palm this off in six months I can probably still get enough to cover a new PC laptop of the same spec
                                    Nice and shiny though!!  To be fair the warranty service when the SSD started to have trouble was REALLY good, I can kind of understand why people stay with Apple.  Oh and having a UNIX-feeling terminal to play with without having to shutdown and boot into something else is fun haha, I used to play with various *NIXs back in the day but they were always so clunky that I never really took my whole workload over to them, just played around when I was bored.
                                    Anyways TBH I'll most likely go back to a Windows PC when it's time to buy new again...
                                    • 16. Re: Lightroom CC crashes constantly
                                      BKKDon Level 4
                                      I'm not sure that this is a correct assumption.
                                      Even on Windows Lightroom 6.2.1 will not release RAM after it uses it. A point in case is say if you run HDR Merge or Panorama it just doesn't release the RAM after performing the operation.
                                      As well, going to develop module it just keeps taking up RAM and not releasing it. Especially if you are using it for larger RAW files such as the 5DS/5DSR at 60MB.
                                      Something has changed dramatically since v6.1 and not just the Import Screen.
                                      • 17. Re: Lightroom CC crashes constantly
                                        I see........... and how is this at all relevant to my Lightroom CC2015.2.1 install on Mac OS X 10.11?
                                        And through iStatMenus I can watch LR use RAM then release it.
                                        Pretty sure you've posted that reply on the wrong thread buddy.
                                        • 18. Re: Lightroom CC crashes constantly
                                          No he is posting to the correct thread. He is disputing my assumption it is a hardware problem because in all honesty the LR 2015.2 (.0 or .1)/6.2 (.0 or .1) release is BUGGY beyond belief. I would suggest you revert to the 1.1 release and see what happens.
                                          But if you were running the 1.1 release before and it was crashing all the time that to me suggests a hardware problem
