7 Replies Latest reply on Jun 20, 2016 10:59 PM by rtauler
    Setting rectangle shape corner rounding
    matias.kiviniemi Level 3
      Tried to use script listener to capture AM code for setting the corner radius of rectangle shapes. Below is what I got and it seems logical, but nothing happens when I run it independently. The right layer is selected but maybe I need to set a reference to the layer somehow? AM side is not my strong suit so hoping someone can pick up my mistake.. Example has 8px radius that was set with all corners locked, but I've also tried replacing 0's with the value.
      var idchangePathDetails = stringIDToTypeID( "changePathDetails" );
      var desc22 = new ActionDescriptor();
      var idkeyOriginType = stringIDToTypeID( "keyOriginType" );
      desc22.putInteger( idkeyOriginType, 1 );
      var idkeyOriginRRectRadii = stringIDToTypeID( "keyOriginRRectRadii" );
      var desc23 = new ActionDescriptor();
      var idunitValueQuadVersion = stringIDToTypeID( "unitValueQuadVersion" );
      desc23.putInteger( idunitValueQuadVersion, 1 );
      var idtopRight = stringIDToTypeID( "topRight" );
      var idPxl = charIDToTypeID( "#Pxl" );
      desc23.putUnitDouble( idtopRight, idPxl, 0 );
      var idtopLeft = stringIDToTypeID( "topLeft" );
      desc23.putUnitDouble( idtopLeft, idPxl, 8.0 );
      var idbottomLeft = stringIDToTypeID( "bottomLeft" );
      desc23.putUnitDouble( idbottomLeft, idPxl, 0 );
      var idbottomRight = stringIDToTypeID( "bottomRight" );
      desc23.putUnitDouble( idbottomRight, idPxl, 0 );
      var idradii = stringIDToTypeID( "radii" );
      desc22.putObject( idkeyOriginRRectRadii, idradii, desc23 );
      var idkeyActionRadiiSource = stringIDToTypeID( "keyActionRadiiSource" );
      desc22.putInteger( idkeyActionRadiiSource, 1 );
      var idkeyActionChangeAllCorners = stringIDToTypeID( "keyActionChangeAllCorners" );
      desc22.putBoolean( idkeyActionChangeAllCorners, true );
      executeAction( idchangePathDetails, desc22, DialogModes.NO );
        • 1. Re: Setting rectangle shape corner rounding
          pixxxel schubser MVP & Adobe Community Professional
          Hi Matias Kiviniemi
          which version of PS do you use?
          This is a possible AM-Code for creating a vector shape
          var idMk = charIDToTypeID( "Mk  " );
              var desc10 = new ActionDescriptor();
              var idnull = charIDToTypeID( "null" );
                  var ref2 = new ActionReference();
                  var idcontentLayer = stringIDToTypeID( "contentLayer" );
                  ref2.putClass( idcontentLayer );
              desc10.putReference( idnull, ref2 );
              var idUsng = charIDToTypeID( "Usng" );
                  var desc11 = new ActionDescriptor();
                  var idType = charIDToTypeID( "Type" );
                      var desc12 = new ActionDescriptor();
                      var idClr = charIDToTypeID( "Clr " );
                          var desc13 = new ActionDescriptor();
                          var idRd = charIDToTypeID( "Rd  " );
                          desc13.putDouble( idRd, 255.000000 );
                          var idGrn = charIDToTypeID( "Grn " );
                          desc13.putDouble( idGrn, 0.000000 );
                          var idBl = charIDToTypeID( "Bl  " );
                          desc13.putDouble( idBl, 0.000000 );
                      var idRGBC = charIDToTypeID( "RGBC" );
                      desc12.putObject( idClr, idRGBC, desc13 );
                  var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
                  desc11.putObject( idType, idsolidColorLayer, desc12 );
                  var idShp = charIDToTypeID( "Shp " );
                      var desc14 = new ActionDescriptor();
                      desc14.putInteger( idunitValueQuadVersion, 1 );
                      var idTop = charIDToTypeID( "Top " );
                      desc14.putUnitDouble( idTop, idPxl, 101.000000 );
                      var idLeft = charIDToTypeID( "Left" );
                      desc14.putUnitDouble( idLeft, idPxl, 54.000000 );
                      var idBtom = charIDToTypeID( "Btom" );
                      desc14.putUnitDouble( idBtom, idPxl, 353.000000 );
                      var idRght = charIDToTypeID( "Rght" );
                      desc14.putUnitDouble( idRght, idPxl, 439.000000 );
                      desc14.putUnitDouble( idtopRight, idPxl, 8.000000 );
                      desc14.putUnitDouble( idtopLeft, idPxl, 8.000000 );
                      desc14.putUnitDouble( idbottomLeft, idPxl, 8.000000 );
                      desc14.putUnitDouble( idbottomRight, idPxl, 8.000000 );
                  var idRctn = charIDToTypeID( "Rctn" );
                  desc11.putObject( idShp, idRctn, desc14 );
                  var idstrokeStyle = stringIDToTypeID( "strokeStyle" );
                      var desc15 = new ActionDescriptor();
                      var idstrokeStyleVersion = stringIDToTypeID( "strokeStyleVersion" );
                      desc15.putInteger( idstrokeStyleVersion, 2 );
                      var idstrokeEnabled = stringIDToTypeID( "strokeEnabled" );
                      desc15.putBoolean( idstrokeEnabled, false );
                      var idfillEnabled = stringIDToTypeID( "fillEnabled" );
                      desc15.putBoolean( idfillEnabled, true );
                      var idstrokeStyleLineWidth = stringIDToTypeID( "strokeStyleLineWidth" );
                      var idPnt = charIDToTypeID( "#Pnt" );
                      desc15.putUnitDouble( idstrokeStyleLineWidth, idPnt, 0.000000 );
                      var idstrokeStyleLineDashOffset = stringIDToTypeID( "strokeStyleLineDashOffset" );
                      desc15.putUnitDouble( idstrokeStyleLineDashOffset, idPnt, 0.000000 );
                      var idstrokeStyleMiterLimit = stringIDToTypeID( "strokeStyleMiterLimit" );
                      desc15.putDouble( idstrokeStyleMiterLimit, 100.000000 );
                      var idstrokeStyleLineCapType = stringIDToTypeID( "strokeStyleLineCapType" );
                      var idstrokeStyleButtCap = stringIDToTypeID( "strokeStyleButtCap" );
                      desc15.putEnumerated( idstrokeStyleLineCapType, idstrokeStyleLineCapType, idstrokeStyleButtCap );
                      var idstrokeStyleLineJoinType = stringIDToTypeID( "strokeStyleLineJoinType" );
                      var idstrokeStyleMiterJoin = stringIDToTypeID( "strokeStyleMiterJoin" );
                      desc15.putEnumerated( idstrokeStyleLineJoinType, idstrokeStyleLineJoinType, idstrokeStyleMiterJoin );
                      var idstrokeStyleLineAlignment = stringIDToTypeID( "strokeStyleLineAlignment" );
                      var idstrokeStyleAlignInside = stringIDToTypeID( "strokeStyleAlignInside" );
                      desc15.putEnumerated( idstrokeStyleLineAlignment, idstrokeStyleLineAlignment, idstrokeStyleAlignInside );
                      var idstrokeStyleScaleLock = stringIDToTypeID( "strokeStyleScaleLock" );
                      desc15.putBoolean( idstrokeStyleScaleLock, false );
                      var idstrokeStyleStrokeAdjust = stringIDToTypeID( "strokeStyleStrokeAdjust" );
                      desc15.putBoolean( idstrokeStyleStrokeAdjust, false );
                      var idstrokeStyleLineDashSet = stringIDToTypeID( "strokeStyleLineDashSet" );
                          var list1 = new ActionList();
                      desc15.putList( idstrokeStyleLineDashSet, list1 );
                      var idstrokeStyleBlendMode = stringIDToTypeID( "strokeStyleBlendMode" );
                      var idBlnM = charIDToTypeID( "BlnM" );
                      var idNrml = charIDToTypeID( "Nrml" );
                      desc15.putEnumerated( idstrokeStyleBlendMode, idBlnM, idNrml );
                      var idstrokeStyleOpacity = stringIDToTypeID( "strokeStyleOpacity" );
                      var idPrc = charIDToTypeID( "#Prc" );
                      desc15.putUnitDouble( idstrokeStyleOpacity, idPrc, 100.000000 );
                      var idstrokeStyleContent = stringIDToTypeID( "strokeStyleContent" );
                          var desc16 = new ActionDescriptor();
                              var desc17 = new ActionDescriptor();
                              desc17.putDouble( idRd, 0.000000 );
                              desc17.putDouble( idGrn, 0.000000 );
                              desc17.putDouble( idBl, 0.000000 );
                          desc16.putObject( idClr, idRGBC, desc17 );
                      desc15.putObject( idstrokeStyleContent, idsolidColorLayer, desc16 );
                      var idstrokeStyleResolution = stringIDToTypeID( "strokeStyleResolution" );
                      desc15.putDouble( idstrokeStyleResolution, 72.000000 );
                  desc11.putObject( idstrokeStyle, idstrokeStyle, desc15 );
              desc10.putObject( idUsng, idcontentLayer, desc11 );
              var idLyrI = charIDToTypeID( "LyrI" );
              desc10.putInteger( idLyrI, 2 );
          executeAction( idMk, desc10, DialogModes.NO );
          and this is only for creating a path
          var idsetd = charIDToTypeID( "setd" );
              var desc18 = new ActionDescriptor();
                  var ref3 = new ActionReference();
                  var idPath = charIDToTypeID( "Path" );
                  var idWrPt = charIDToTypeID( "WrPt" );
                  ref3.putProperty( idPath, idWrPt );
              desc18.putReference( idnull, ref3 );
              var idT = charIDToTypeID( "T   " );
                  var desc19 = new ActionDescriptor();
                  desc19.putInteger( idunitValueQuadVersion, 1 );
                  desc19.putUnitDouble( idTop, idPxl, 70.000000 );
                  desc19.putUnitDouble( idLeft, idPxl, 49.000000 );
                  desc19.putUnitDouble( idBtom, idPxl, 244.000000 );
                  desc19.putUnitDouble( idRght, idPxl, 445.000000 );
                  desc19.putUnitDouble( idtopRight, idPxl, 8.000000 );
                  desc19.putUnitDouble( idtopLeft, idPxl, 8.000000 );
                  desc19.putUnitDouble( idbottomLeft, idPxl, 8.000000 );
                  desc19.putUnitDouble( idbottomRight, idPxl, 8.000000 );
              desc18.putObject( idT, idRctn, desc19 );
          executeAction( idsetd, desc18, DialogModes.NO );
          and this should change the corner radius of the shape
              var desc26 = new ActionDescriptor();
              desc26.putInteger( idkeyOriginType, 1 );
                  var desc27 = new ActionDescriptor();
                  desc27.putInteger( idunitValueQuadVersion, 1 );
                  desc27.putUnitDouble( idtopRight, idPxl, 8.000000 );
                  desc27.putUnitDouble( idtopLeft, idPxl, 8.000000 );
                  desc27.putUnitDouble( idbottomLeft, idPxl, 8.000000 );
                  desc27.putUnitDouble( idbottomRight, idPxl, 8.000000 );
              desc26.putObject( idkeyOriginRRectRadii, idradii, desc27 );
              desc26.putInteger( idkeyActionRadiiSource, 1 );
              desc26.putBoolean( idkeyActionChangeAllCorners, true );
          executeAction( idchangePathDetails, desc26, DialogModes.NO );
          • 2. Re: Setting rectangle shape corner rounding
            It's latest CC 2015. The code for changing radius still does nothing, but your code to create rectangle with corner radius defined works! Thanks!
            • 3. Re: Setting rectangle shape corner rounding
              You're welcome.
              Matias Kiviniemi schrieb:
              It's latest CC 2015. The code for changing radius still does nothing …
              Hmmhh?
              I've tried it today at work with the latest PS CC 2015.
              Do you really have had a live vector shape with a corner radius different from 8 px?
              e.g. I've tried with 38px × 38px × 38px × 38px and run script snippet --> result: all corners of vector shape changed to 8px
              e.g. I've tried with 47px × 38px × 38px × 38px and run script snippet --> result: all corners of vector shape changed, but in relation to 8 px --> 17px × 8px × 8px × 8px
              The snippet gives funny results if one value is smaller than 8px before running the snippet.
              • 4. Re: Setting rectangle shape corner rounding
                I'm using the Win64 version and the rectangle had all corners with 0px, not sure why we're seeing different results (and why the creation works OK).
                • 5. Re: Setting rectangle shape corner rounding
                  rtauler
                  pixxxel schubser This corner edit script works flawlessly, can I've the edit storke width and color? I'm having a very hard time to get this.
                  • 6. Re: Setting rectangle shape corner rounding
                    rtauler
                    in the script snippets? Or after the snippet is running?
                    Try this after creating a vector shape:
                    // settings //
                    var strokeRed = 0;
                    var strokeGrn = 255;
                    var strokeBlue= 0;
                    var strokeWdt = 10;
                        var desc113 = new ActionDescriptor();
                            var ref84 = new ActionReference();
                            var idOrdn = charIDToTypeID( "Ordn" );
                            var idTrgt = charIDToTypeID( "Trgt" );
                            ref84.putEnumerated( idcontentLayer, idOrdn, idTrgt );
                        desc113.putReference( idnull, ref84 );
                            var desc114 = new ActionDescriptor();
                                var desc115 = new ActionDescriptor();
                                    var desc116 = new ActionDescriptor();
                                        var desc117 = new ActionDescriptor();
                                        desc117.putDouble( charIDToTypeID( "Rd  " ), strokeRed );
                                        desc117.putDouble( charIDToTypeID( "Grn " ), strokeGrn );
                                        desc117.putDouble( charIDToTypeID( "Bl  " ), strokeBlue );
                                    desc116.putObject( idClr, idRGBC, desc117 );
                                desc115.putObject( idstrokeStyleContent, idsolidColorLayer, desc116 );
                                desc115.putInteger( idstrokeStyleVersion, 2 );
                                desc115.putBoolean( idstrokeEnabled, true );
                            desc114.putObject( idstrokeStyle, idstrokeStyle, desc115 );
                        var idshapeStyle = stringIDToTypeID( "shapeStyle" );
                        desc113.putObject( idT, idshapeStyle, desc114 );
                    executeAction( idsetd, desc113, DialogModes.NO );
                        var desc151 = new ActionDescriptor();
                            var ref96 = new ActionReference();
                            ref96.putEnumerated( idcontentLayer, idOrdn, idTrgt );
                        desc151.putReference( idnull, ref96 );
                            var desc152 = new ActionDescriptor();
                                var desc153 = new ActionDescriptor();
                                desc153.putUnitDouble( stringIDToTypeID( "strokeStyleLineWidth" ), charIDToTypeID( "#Pnt" ), strokeWdt );
                                desc153.putInteger( idstrokeStyleVersion, 2 );
                                desc153.putBoolean( idstrokeEnabled, true );
                            desc152.putObject( idstrokeStyle, idstrokeStyle, desc153 );
                        desc151.putObject( idT, idshapeStyle, desc152 );
                    executeAction( idsetd, desc151, DialogModes.NO );
                    Have fun
