3 Replies Latest reply on Oct 26, 2015 2:53 PM by try67
    script to split pdf based on bookmarks in acrobat dc
    gert verrept Level 2
      I'm looking for a script (or action) to split a pdf in several pdfs, based on the bookmarks, and with the split name equal to the bookmark name.
      ex. Bookmark = nr am 43 (this is in fact the para style used in the indesign file), so the file should by named: nr am 43.pdf.
        • 1. Re: script to split pdf based on bookmarks in acrobat dc
          Some information missing here:
          - Do you want to do this to all bookmarks, or just some (say, only the top-level ones)?
          - Which page(s) should be included in the newly split file? The page the bookmark is pointing to? All of the pages until the next bookmark? Something else?
          - Which folder should be used for the new files? The same as the original one?
          - What should happen if the bookmark name can't be used as a file-name (if it contains illegal characters, for example, or is a duplicate of another file)?
          • 2. Re: script to split pdf based on bookmarks in acrobat dc
            @try67:
            Sorry about the lack of info, I was still looking for a solution on other sites, so:
            a. only top level one
            b. until next bookmark
            c. the same as the original one
            d. Not possible, the names are unique since they contain a sequence number and one or more names.
            To clarify point d: The doc name is 1234002. In this doc, a para style is used, called AM_NL which is used every time we encounter a sentence starting with "Nr. (followed by a sequence number) van de heer XXXX (or van de heren XXXX en YYYY...)". In doc 1234002 this number can appear only ones.
            • 3. Re: script to split pdf based on bookmarks in acrobat dc
              This kind of code was posted to these forums many times in the past.
              Basically you need to use a loop to iterate over the bookmarks, executing
              each one and then using the current page number information to determine
              the page range for each bookmark, and then extract it as a new file.
              In the past this process didn't work as a part of an Action, but I believe
              that was fixed recently.
              On Mon, Oct 26, 2015 at 2:15 PM, gert verrept <forums_noreply@adobe.com>
