2 Replies Latest reply on Oct 26, 2015 6:45 PM by jiml88834626
    java.lang.NullPointerException while packaging
    jiml88834626 Level 1
      There was an error occurred while I had been packaging my APK.
      My project is included an ANE. I rebuilt the ANE and the error occurred.
      The error I got as below:
      !ENTRY com.adobe.flexbuilder.project 4 43 2015-10-26 17:10:52.114
      !MESSAGE Error
      !STACK 0
      at java.util.zip.ZipFile.getInputStream(Unknown Source)
      at com.adobe.air.apk.APKPackager.processExtensions(APKPackager.java:276)
      at com.adobe.air.ApplicationPackager.createPackage(ApplicationPackager.java:65)
      at com.adobe.flexbuilder.multisdk.apollo.export.AIRAPKPackager.createUsingPackager(AIRAPKPac kager.java:245)
      at com.adobe.flexbuilder.multisdk.apollo.export.AIRAPKPackager.create(AIRAPKPackager.java:57 5)
      at com.adobe.flexbuilder.multisdk.apollo.export.AIRAPKPackager.create(AIRAPKPackager.java:13 8)
      at com.adobe.flexide.multiplatform.android.exportrelease.AndroidExportReleaseHandler.createP ackage(AndroidExportReleaseHandler.java:354)
      at com.adobe.flexide.multiplatform.android.exportrelease.AndroidExportReleaseHandler.doPacka ge(AndroidExportReleaseHandler.java:258)
      at com.adobe.flashbuilder.project.multiplatform.ui.exportrelease.MultiPlatformExportReleaseV ersionManager.doExport(MultiPlatformExportReleaseVersionManager.java:317)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard$1.run(Exp ortReleaseVersionWizard.java:221)
      The ADT cmd as below:
      "C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\sdks\17.0\bin\adt" -package -target ane speech.ane extension.xml -swc speech.swc -platform iPhone-ARM -C ios . -platform Android-ARM -C android . -platform default -C default .
      By the way, I use above command built the ANE and packaged my APK correctly before.
      Even I rebuilt the ANE use same command and  files before I had used, the error was still occurred.
      Could anybody give me suggestions how could I debug the issue?
      I used flash build 4.7 and SDK 17.0!
      Jim
