5 Replies Latest reply on Oct 27, 2015 10:53 AM by joel_pau
    syncing animation to sound
    mikeh29565435
      I am trying to figure out how to synchronize an animation to play at a certain time code of an audio playing. Is there anything like that that has been done? I can manually scrub the timeline and place a trigger action so many seconds into the main timeline that has the audio in a layer, but I wanted to do it so that once a certain time code was reached, an animation would play. I"m working in EA 2015 CC.
      Mike
        • 1. Re: syncing animation to sound
          joel_pau Level 5
          Well, Edge API provides you .currentTime: Adobe Edge Animate CC JavaScript API
          var audio = sym.$("my_audio_element")[0];
          if (audio.currentTime = 5) { sym.play ("aLabel") }
          • 2. Re: syncing animation to sound
            mikeh29565435 Level 1
            Hi Joel,
            Thanks for your response. I haven't been able to figure it out just yet. Here's what I did so far.
            On my main timeline is where the audio layer (element) is located. It is set to autoplay and is called "about_us_audio." At the 5 second mark of the audio (.mp3) I want to play a symbol containing an animation called "about_me_animation." On the first frame of the main timeline I put the following trigger action.
            var audio = sym.$("about_us_audio")[0];
            if (audio.currentTime = 10) { sym.play ("about_me_animation") }
            No luck yet. Am I placing the action in the right place, in a trigger action?
            • 3. Re: syncing animation to sound
              joel_pau Level 5
              1) "At the 5 second mark of the audio (.mp3)" ==> it means: if (audio.currentTime = 5)
              2) "I want to play a symbol containing an animation called "about_me_animation."" ==> it means: { sym.getSymbol("about_me_animation").play() }
              So it should be: if (audio.currentTime = 5){ sym.getSymbol("about_me_animation").play() };
              • 4. Re: syncing animation to sound
                Thanks, I now understand what the code is doing. But where should I place the code? On the timeline as a trigger action? If so, does it matter which frame? Right now I have placed this code on the first frame of the timeline as a trigger action:
                The stage is set to autoplay. The audio element (layer) "Playback" is set to play from the first frame (0.00) of the main timeline.
                But the "about_me_animation" plays from the very beginning, not when the audio reaches the 5 second mark (of the .mp3). I'm wondering if I placed the code in the wrong place.
                • 5. Re: syncing animation to sound
                  joel_pau Level 5
                  Because the stage is set to autoplay, i will use the compositionReady panel.
                  I quote Edge API: compositionReady fires after the composition is ready to play, but before autoPlay occurs.
