1 Reply Latest reply on Oct 27, 2015 3:34 AM by Derek Cross
    Need Modification in existing Imagecatalog script
    sampathk37726153
      Hello,
      I have en-number of images in same size (Above 300 images), All image name is S1, S2, S3.......etc,
      My requirement is S1 image placed in first page, S2 is Second page, S3 is Third page......etc.
      When using this Imagecatalog script (which was already existing in Adobe Indesign),  Image are placed as per mentioned table.
      Image          Placed page
      S1               Page1
      S10             Page2
      S11             Page3
      S12             Page4
      S19            Page20
      S2              Page21........
      But  need as above mentioned sequence.
      Please do the needful modification for the same.
      Script
      main();
      function main(){
        var myFilteredFiles;
        //Make certain that user interaction (display of dialogs, etc.) is turned on.
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
        myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai"]
        //Display the folder browser.
        var myFolder = Folder.selectDialog("Select the folder containing the images", "");
        //Get the path to the folder containing the files you want to place.
        if(myFolder != null){
        if(File.fs == "Macintosh"){
        myFilteredFiles = myMacOSFileFilter(myFolder);
        else{
        myFilteredFiles = myWinOSFileFilter(myFolder);
        if(myFilteredFiles.length != 0){
        myDisplayDialog(myFilteredFiles, myFolder);
        alert("Done!");
      //Windows version of the file filter.
      function myWinOSFileFilter(myFolder){
        var myFiles = new Array;
        var myFilteredFiles = new Array;
        for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
        myExtension = myExtensions[myExtensionCounter];
              myFiles = myFolder.getFiles("*"+ myExtension);
        if(myFiles.length != 0){
        for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
        myFilteredFiles.push(myFiles[myFileCounter]);
        return myFilteredFiles;
      function myMacOSFileFilter(myFolder){
        var myFilteredFiles = myFolder.getFiles(myFileFilter);
      //Mac OS version of file filter
      //Have to provide a separate version because not all Mac OS users use file extensions
      //and/or file extensions are sometimes hidden by the Finder.
      function myFileFilter(myFile){
        var myFileType = myFile.type;
        switch (myFileType){
        case "JPEG":
        case "EPSF":
        case "PICT":
        case "TIFF":
        case "8BPS":
        case "GIFf":
        case "PDF ":
        return true;
        break;
        default:
        for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
        var myExtension = myExtensions[myCounter];
        if(myFile.name.indexOf(myExtension)>-1){
        return true;
        break;
        return false;
      function myDisplayDialog(myFiles, myFolder){
        var myLabelWidth = 112;
        var myStyleNames = myGetParagraphStyleNames(app);
        var myLayerNames = ["Layer 1", "Labels"];
        var myDialog = app.dialogs.add({name:"Image Catalog"});
        with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
        staticTexts.add({staticLabel:"Information:"});
        with(borderPanels.add()){
        with(dialogColumns.add()){
        staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
        staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
        staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
        staticTexts.add({staticLabel:myFiles.length + ""});
        staticTexts.add({staticLabel:"Options:"});
        staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
        var myNumberOfRowsField = integerEditboxes.add({editValue:3});
        staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
        var myNumberOfColumnsField = integerEditboxes.add({editValue:3});
        staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
        var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
        staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
        var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
        with (dialogRows.add()){
        staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
        var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
        var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
        var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
        var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
        staticTexts.add({staticLabel:""});
        var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
        with (myLabelsGroup){
        //Label type
        staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
        var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
        //Text frame height
        staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
        var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
        //Text frame offset
        staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
        var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
        //Style to apply
        staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
        var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
        //Layer
        staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
        var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
              var myResult = myDialog.show();
              if(myResult == true){
        var myNumberOfRows = myNumberOfRowsField.editValue;
        var myNumberOfColumns = myNumberOfColumnsField.editValue;
        var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
        var myFitProportional = myFitProportionalCheckbox.checkedState;
        var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
        var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
        var myHorizontalOffset = myHorizontalOffsetField.editValue;
        var myVerticalOffset = myVerticalOffsetField.editValue;
        var myMakeLabels = myLabelsGroup.checkedState;
        var myLabelType = myLabelTypeDropdown.selectedIndex;
        var myLabelHeight = myLabelHeightField.editValue;
        var myLabelOffset = myLabelOffsetField.editValue;
        var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
        var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
        myDialog.destroy();
        myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
        else{
        myDialog.destroy();
      function myGetParagraphStyleNames(myDocument){
        var myStyleNames = new Array;
        var myAddLabelStyle = true;
        for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
        myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
        if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
        myAddLabelStyle = false;
        if(myAddLabelStyle == true){
        myStyleNames.push("Labels");
        return myStyleNames;
      function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
        var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
        var myParagraphStyle, myError;
        var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
        var myDocument = app.documents.add();
        myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
        myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
        var myDocumentPreferences = myDocument.documentPreferences;
        var myNumberOfFrames = myFiles.length;
        var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
        if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
        myNumberOfPages++;
        //If myMakeLabels is true, then add the label style and layer if they do not already exist.
        if(myMakeLabels == true){
        try{
        myLabelLayer = myDocument.layers.item(myLayerName);
        //if the layer does not exist, trying to get the layer name will cause an error.
        myLabelLayer.name;
        catch (myError){
        myLabelLayer = myDocument.layers.add({name:myLayerName});
        //If the paragraph style does not exist, create it.
        try{
        myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
        myParagraphStyle.name;
        catch(myError){
        myDocument.paragraphStyles.add({name:myLabelStyle});
        myDocumentPreferences.pagesPerDocument = myNumberOfPages;
        myDocumentPreferences.facingPages = false;
        var myPage = myDocument.pages.item(0);
        var myMarginPreferences = myPage.marginPreferences;
        var myLeftMargin = myMarginPreferences.left;
        var myTopMargin = myMarginPreferences.top;
        var myRightMargin = myMarginPreferences.right;
        var myBottomMargin = myMarginPreferences.bottom;
        var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
        var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
        var myColumnWidth = myLiveWidth / myNumberOfColumns
        var myFrameWidth = myColumnWidth - myHorizontalOffset
        var myRowHeight = (myLiveHeight / myNumberOfRows)
        var myFrameHeight = myRowHeight - myVerticalOffset
        var myPages = myDocument.pages;
        // Construct the frames in reverse order. Don't laugh--this will
        // save us time later (when we place the graphics).
        for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
        myPage = myPages.item(myCounter);
        for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
        myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
        myY2 = myY1 + myFrameHeight;
        for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
        myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
        myX2 = myX1 + myFrameWidth;
        myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
        // Because we constructed the frames in reverse order, rectangle 1
        // is the first rectangle on page 1, so we can simply iterate through
        // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
        for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
        myFile = myFiles[myCounter];
        myRectangle = myDocument.rectangles.item(myCounter);
        myRectangle.place(File(myFile));
        myRectangle.label = myFile.fsName.toString();
        //Apply fitting options as specified.
        if(myFitProportional){
        myRectangle.fit(FitOptions.proportionally);
        if(myFitCenterContent){
        myRectangle.fit(FitOptions.centerContent);
        if(myFitFrameToContent){
        myRectangle.fit(FitOptions.frameToContent);
        //Add the label, if necessary.
        myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
        if (myRemoveEmptyFrames == 1){
        for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
        if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
        myDocument.rectangles.item(myCounter).remove();
        else{
        //As soon as you encounter a rectangle with content, exit the loop.
        break;
      //Function that adds the label.
      function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
        var myDocument = app.documents.item(0);
        var myLabel;
        var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
        var myLabelLayer = myDocument.layers.item(myLayerName);
        var myLink =myFrame.graphics.item(0).itemLink;
        //Label type defines the text that goes in the label.
        switch(myLabelType){
        //File name
        case 0:
        myLabel = myLink.name;
        break;
        //File path
        case 1:
        myLabel = myLink.filePath;
        break;
        //XMP description
        case 2:
        try{
        myLabel = myLink.linkXmp.description;
        if(myLabel.replace(/^\s*$/gi, "")==""){
        throw myError;
        catch(myError){
        myLabel = "No description available.";
        break;
        //XMP author
        case 3:
        try{
        myLabel = myLink.linkXmp.author
        throw myError;
        catch(myError){
        myLabel = "No author available.";
        break;
        var myX1 = myFrame.geometricBounds[1];
        var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
        var myX2 = myFrame.geometricBounds[3];
        var myY2 = myY1 + myLabelHeight;
        var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
        myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
        myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
      Regards,
      Sampath.S
