25 Replies Latest reply on Nov 8, 2015 9:33 PM by JaysonM-Y
    Computer/Workstation for multicamera editing (2 cameras) (4k - 60fps - h264)
    stefang58883272 Level 1
      Hello,
      I would like to ask what kind of CPU I should get for this.
      Currently we are using i7 - 3770 with 32gb of ram - WD Black in raid (300 MB/s)
      The issue is that when I import footage from camera ( Panasonic X1000) the playback with just 1 camera is fine CPU at 95 percent
      When I add second camera (GoPro, or Another X1000) and enable multicam the playback is laggy. Basically it will play like 4 seconds and then it starts to lag like hell.
      I would like to avoid the solution to encode everything to lower resolution first and then do the edit.
      I do not use any effects.
      What workstation should I buy ? Or better yet which components should I buy ?
      Thank you very much.
