3 Replies Latest reply on Oct 27, 2015 1:01 PM by rob day
    applescript export preset
    kezers
      Hello, on page 47 of pdf "Adobe Indesign CS5 Scripting Guide: Applescript" there is an example to call preset for exporting pdf, but it doesn't work for me (Indesign CC 2015, OSX 10.11.1)
      tell application "Adobe InDesign CC 2015"
        tell active document
        --You'll have to fill in a valid file path for your system and
        --a valid PDF export preset name.
        export format PDF type to "yukino:test.pdf" using PDF export preset "TEST" without showing options
        end tell
      end tell
      What is wrong?
      Thankyou in advance!
      Matteo
        • 1. Re: applescript export preset
          The tell is to InDesign not the document. Try this—make sure the path the PDF is complete:
              export active document format PDF type to "HD:Users:username:Desktop:Test.pdf" using PDF export preset "TEST" without showing options
          end tell
          • 2. Re: applescript export preset
            kezers Level 1
            Hello Rob,
            thank you! I'm confused about Applescript and Adobe Indesign support to Applescript because in the official manual "Adobe Indesign CS5 Scripting Guide: Applescript" the example use "tell" to activate document.
            Can you help me to understand:
            1) Applescript syntax is changed after "Adobe Indesign CS5 Scripting Guide: Applescript"
            2) Indesign syntax support to Applescript is changed after "Adobe Indesign CS5 Scripting Guide: Applescript"
            3) The manual "Adobe Indesign CS5 Scripting Guide: Applescript" in this case is wrong
            Thank you.
            • 3. Re: applescript export preset
              There are usually scripting changes with every release, although they were more extensive in earlier versions. There is a dictionary of the API for each version, which you can get from Script Editor via File>Open Dictionary and choosing the application. So export is in the basics suite:
