1 Reply Latest reply on Oct 27, 2015 7:00 AM by Vamitul
    Deleting part of image name and changing file extension
    beto correa Level 1
      I work with linked images in low resolution and .jpg extension that has the following pattern – f000_1ab_cde_fgh_ (description image with Bank).jpg
      I need to delimit and delete the text of the description and replace the extension .psd. The description can be a variable length.
      It is possible via script to delete the image description space and then add the extension?
      The final name should look like – f000_1ab_cde_fgh.psd
      That way I can automatically exchange images by lower for high resolution.
      Even if the extension becomes the same can also relink from file extension.
