14 Replies Latest reply on Oct 28, 2015 6:58 PM by Johnwhite
    Convert registration color to black
    LeoMari Level 2
      Hello everyone,
      I am looking for a script that converts Registration colors to CMYK Black ..
      It's possible?
      I appreciate the help!
      Hug..
        • 1. Re: Convert registration color to black
          Jump_Over Level 5
          You could use InDesign Find...Change utility to replace each "registration color" occurrence with "black color"
          So probably no need to use a script...
          Jarek
          • 2. Re: Convert registration color to black
            LeoMari Level 2
            Jarek Hello!
            Already do this but the idea is to incorporate this action to several other I'm writing. I want to reduce the number of clicks.
            I hope you understood my English is very bad ..
            Thank you!
            Leonardo
            • 3. Re: Convert registration color to black
              LeoMari Level 2
              I could !!
              You just need to do for the text ..
              Thank's!
              var doc = app.activeDocument;
              app.findObjectPreferences = app.changeObjectPreferences = null;
              app.findObjectPreferences.fillColor = "Registration";
              app.changeObjectPreferences.fillColor ="Black";
              app.changeObject();
              • 4. Re: Convert registration color to black
                beto correa Level 1
                You can try this
                app.changeObjectPreferences.fillColor = "Black";
                app.changeObject();
                app.findObjectPreferences = NothingEnum.nothing;
                app.changeObjectPreferences = NothingEnum.nothing;
                app.findObjectPreferences.strokeColor = "Registration";
                app.changeObjectPreferences.strokeColor = "Black";
                app.changeObject();
                app.findTextPreferences = app.changeTextPreferences = null;
                app.findTextPreferences.fillColor = "Registration";
                app.changeTextPreferences.fillColor = "Black";
                app.changeText();
                app.findTextPreferences = NothingEnum.nothing;
                app.changeTextPreferences = NothingEnum.nothing;
                app.findTextPreferences.strokeColor = "Registration";
                app.changeTextPreferences.strokeColor = "Black";
                app.changeText();
                • 5. Re: Convert registration color to black
                  Johnwhite Level 1
                  Hi Beto
                  Find and Change Object Fill color and Stroke Color not really work.
                  Why?
                  Is that correct syntax?
                  Regard
                  John
                  • 6. Re: Convert registration color to black
                    LeoMari Level 2
                    Hi John White!
                    Add #target indesign earlier in the code.
                    Work on the CS6 version of Mac and perfect works.
                    If not, error print post ..
                    hug!
                    • 7. Re: Convert registration color to black
                      Johnwhite Level 1
                      Hi LeoMari
                      Thank you for you help.
                      But, not work.
                      thaks
                      Regard
                      John
                      • 8. Re: Convert registration color to black
                        Johnwhite Level 1
                        Sorry all,
                        Before run this script,
                        User have change the find-change object's options to all object,
                        then it will work.
                        But how can I tell the script I want to find and change in all objects?
                        Regard
                        John
                        • 9. Re: Convert registration color to black
                          LeoMari Level 2
                          Important to all objects and layers unlocked. Also look for how to include the find/change options.
                          I have these lines on unlocking:
                          var myDocuments = app.documents.everyItem();
                          var myLayers = myDocuments.layers.everyItem();
                          myDocuments.pageItems.everyItem().locked = false;
                          myLayers.locked = false;
                          • 10. Re: Convert registration color to black
                            Johnwhite Level 1
                            Thank you LeoMari
                            thank you so much.
                            John
                            • 11. Re: Convert registration color to black
                              Johnwhite Level 1
                              Sorry LeoMari
                              It seems like I have to tell the script I want to change all kind of objects' fill color and stroke color. not all objects.
                              it seems these two tems have some different conditions.
                              I use you are script as above, but unfortunately not work.
                              Regard
                              John
                              • 12. Re: Convert registration color to black
                                Johnwhite Level 1
                                Hi all,
                                Is I have to give a constructor.name, like
                                object.constructor.name = "GraphicLine";
                                object.constructor.name = "Rectangle";
                                object.constructor.name = "Oval";
                                object.constructor.name = "TextFrame"
                                What's the syntax for all kine of constructor.name?
                                Regard
                                John
                                • 13. Re: Convert registration color to black
                                  Johnwhite Level 1
                                  Hi Leo Mari
                                  I make this by myself, it works.
                                      var myObjects = myDoc.pageItems.everyItem().getElements();
                                            myDoc.pageItems.everyItem().locked = false;
                                              var myLayers = myDoc.layers.everyItem();
                                              app.changeObject();
                                              app.changeObject();
                                              app.changeText();
                                              app.changeText();
                                  thank you for your help.
                                  thank you so much
                                  Regard
                                  John
                                  • 14. Re: Convert registration color to black
                                    Johnwhite Level 1
                                    thank you all.
                                    John
