1 Reply Latest reply on Oct 27, 2015 11:22 AM by S Hopkins
    How do i write a javascript code to open InDesign and import template paragraphs & character styles
    karthiks94217840 Level 2
      Dear Friends,
      I am leaning stage in the java script code friends.
      My Requirements:
      I want to open Indesign (Previous_edition_InDesign_file), than import the selected template - all paragraphs & character styles. That styles all delete and replaced with old  Previous_edition_InDesign styles.
      Advanced thanks friends,
      Karthik S
        • 1. Re: How do i write a javascript code to open InDesign and import template paragraphs & character styles
          S Hopkins Adobe Community Professional
          Karthik,
          Hope the following discussion and script helps:
          First: define location of template. I suggest (if you have admin privileges) to use a folder named Templates inside the application folder.
          If the name of the template is not hard-coded in the script, you will need to have the user supply the name. Here we will assume the name of the template is hard-coded in the script.
          var fileName = "NameOfTemplate.indt"
          var folderPath = app.filePath + "/Templates";
          try {
             var fileRef = getFileRef (folderPath, fileName);
          } catch (e) {
             alert (e);
          Next: make sure the document you want updated has been saved with possibly a backup file
          var docRef = app.documents.item(0);
          Here's the script:
          //assumes target document is open. Change name for template name for variable fileName.
          var fileName = "MyPublication.indt"
          try {
              } catch (e) {
                  alert (e);
          //by default, globalClashResolutionStrategy is LOAD_ALL_WITH_OVERWRITE
          docRef.importStyles(ImportFormat.TEXT_STYLES_FORMAT, fileRef, GlobalClashResolutionStrategy.LOAD_ALL_WITH_OVERWRITE);
              //function returns reference to file if both folder and file are found
              function getFileRef (folderPath, fileName) {
                  if (Folder(folderPath).exists == false) {
                      throw ("Folder referenced not found");
                 var filePath = folderPath + "/" + fileName;
                 if (File (filePath).exists == false) {
                     throw ("File referenced not found");
                 return File(filePath);
