This content has been marked as final.
Show 3 replies
1. Re: JavaScript Menus Appear Behind Flash
Newsgroup_User Mar 31, 2009 6:40 AM (in response to andrewmcgibbon)All Active content on a page will always rise to the top, so to speak,
including Flash, certain form elements, Java applets, and Active X controls.
This means that each of these will poke through layers. There is not a good
cross-browser/platform reliable way to solve this issue, but if you can be
confident in your visitors using IE 5+ or NN6+, then you can use the Flash
wmode parameter (however, Safari does not support this properly!).
PVII article:
http://www.projectseven.com/support/answers.asp?id=127
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"andrewmcgibbon" <webforumsuser@macromedia.com> wrote in message
news:gqr9fs$ad0$1@forums.macromedia.com...
>I am creating a page with a flash file embedded below a navigation bar with
> drop-down menus. The nav bar was created in Fireworks and imported. The
> problem is that the drop downs are appearing BEHIND the embedded Flash
> file so
> you can't see them. I have been looking all over for a solution to this
> without much success. If anyone has any ideas I would be appreciative if
> you
> share them.
> Regards,
> Andy
2. JavaScript Menus Appear Behind Flash
jazzguy2 Mar 31, 2009 9:18 AM (in response to andrewmcgibbon)We are using a 3rd party app to create a flash slideshow. Here is the code used to display the Flash. I'm not certain how to add this solution given this code:
var so = new SWFObject("slideshow.swf", "gallery", "587", "408", "6", "#000000");
so.write("flashcontent");</script> -
3. Re: JavaScript Menus Appear Behind Flash
andrewmcgibbon Mar 31, 2009 11:55 AM (in response to andrewmcgibbon)In this instance, the solution is this:
var so = new SWFObject("slideshow.swf", "gallery", "785", "119", "6", "#000000");
so.addParam("wmode", "transparent");
</script>
